I steped on the power cable to my laptop and now the cable doesnt charge. i think it is in the plug in area there alot of wiggle in the computer any way to fix it?
  • 2,567 Answers
The DC jack, where you plug the power adapter cable, might be loose or defective, & needs to be either re-soldered or replaced.
In order to do this, the laptop needs to be disassembled & the motherboard taken out. Also, the motherboard needs to be checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Sep 08, 2010
I had to replace a old cable it had a short.! Got a new one nothing happen.!it not charging period.!
Please tell us the make and model number so we can help. Normally a charger does not have a replaceable cable to the laptop - only the AC cord to the power plug can be replaced. I've purchased replacement adapters and the AC power cord doesn't work correctly in the adapter unless I push it in very hard or wiggle it to make a connection. Some replacement adapter also have a plug to the laptop that is not sized like the original and also needs to be wiggled to make a connection. Please provide the information if you still are having problems.
Oct 06, 2014 | Computers & Internet
My charger is lose an it sometimes charges an sometiems doesnt
sounds like a short. could be the charger, but could be the connector on the laptop. does it wiggle at all?
if you isolate the cable (don't wiggle the plugged in part) and move it around, can you cause the charging to stop and start by bending your cable? if so, it is definitely a short in your charger and you'd be best off ordering a replacement if you don't want to deal with the hassle.
Oct 16, 2013 | Acer Aspire 5736z 4460 Laptop
HP Elitebook 2530 Pindicator says battery charging but battery not charging
Could be a back power brick or DC jack yes. Power off the computer and remove the battery. With the battery out plug in just the power brick and turn on the computer. If the computer doesn't power on gently wiggle the plug into the laptop and repeatedly hit the power button if it comes on briefly then off again you dc jack is loose. If it doesn't come on at all then its the power brick. If the laptop comes on gently wiggle the plug into the PC. Powers off while wiggling DC jack.
Jul 09, 2012 | HP EliteBook 2530p Notebook
My laptop won't charge. I have an acer aspire 5315 that won't charge, I had problems with the charging adapter before so I thought that was the problem and replaced it, the replacement worked for...
For a test -Remove the battery from the laptop. (leave it out) -Plug in the adapter and turn the laptop on. -Gently wiggle the adapter plugged in
If the computer powers off the solder and/or pins have broken loose from the DC jack. This is very common. Average repair bill is around $150, if your in the Denver Colorado Area I can do the repair for about $50
If it won't turn on while you wiggle the adapter and hit the power button then the adapter is bad again sadly
Jul 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
When i plug in power charger, it says the computer doesnt recognize charger, and the computer wont charge. I have to plug it in a few times, then the battery will charge
Hello.
The most common reasons are the power adapter/cord and power jack.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Jun 13, 2010 | Dell Inspiron 1521 Notebook
My Inspiron e1505 does not charge the replacement battery Gd761
The problem could be the power jack of the laptop and/or the connections inside the laptop.
Try to plug the power adapter slowly and try to wiggle it. It you feel that the power jack is wiggling, then the problem is a loose power jack that is why it won't charge. And you need to have a tech tighten that up for you.
Have a great day!
Oct 05, 2009 | Dell Computers & Internet
Power cord cuts in and out
There are two places the trouble can be happening, at the adapter plug or at the power jack in the laptop. To determine which one is causing the power loss, hold the plug in the computer steady with your fingers while you wiggle the adapter cable. (If you have access to a voltmeter you can measure the voltage at the plug while you wiggle the cable to see if remains steady.)
If the charge light flickers it's the adapter cord that's bad. Because the wire flexes so much at the plug, it can break inside the insulation and cause the power loss. You either need to replace the adapter or repair it by cutting off the bad end and installing a new plug.
If the charge light remains on with the plug held steady but flickers when you wiggle the plug itself, the trouble is on the main board in the computer. The solder connections at the power jack have broken from the plug flexing and need to be repaired. This involves opening up the computer and getting at the solder side of the main board. It's tedious but relatively simple. If you are not experienced with soldering on small electronics, leave this to a professional shop.
Apr 23, 2009 | Acer (56.04145.901) (5604145901) Power...
Power chord won't charge laptop
If you need to wiggle the cord in order for it to charge, then you have a problem.
If you have to wiggle it at the computer, you probably have either a bad plug on the adapter or the power connector on the motherboard is going bad. This situation will not cure itself. It will only get worse.
Check the voltage at the end of the power adapter cord (the plug where it goes into the computer). If it's constant even when you wiggle the plug, you're gonna be looking for a new motherboard soon. I have actually replaced the power adapter on motherboards, but it's tricky--you have to be really good with a soldering iron!
Mar 22, 2009 | Dell Inspiron 1525 Notebook
Battery problem...
This issue can be caused by any of the below possibilities. 1.- Computer AC / DC cable is bad not allowing the computer battery to charge.
2.- Battery is bad.
3.- Battery charger board is bad.
Solutions:
Verify that the AC and or DC cable is not bad by testing the computer only with the power plug connected and the battery out of the laptop.
2.- Battery is bad
It is possible that if the power plug is good that the computer battery is bad. Leave the computer connected to the power with the battery connected in the computer for at least one hour; if the battery does not charge, consider having the battery and/or the laptop serviced or repaired.
If the computer and/or battery is not in warranty consider just replacing the battery as it is very likely that it is just a bad battery.
If the battery has been replaced or an alternate battery from an alternate identical laptop does not work in the computer, it is likely that the power or charger board within the laptop is bad. It is recommended that the laptop be serviced or repaired.
This will fix your problem.
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 14, 2008 | Dell Inspiron 6000 Notebook
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
