Question about Garmin Minn Kota MK 440 On-Board Charger CHARGERS
Hello, I have a Minn Kota 440 4 Bank Charger. I recently heard it spark when I plugged into my 115V AC power source. Since then I have no charging light indicator and no actual charging occuring. I tried reseting power source today and as I plugged it into 115V I heard a sizzle sound. I have checked all connections including 115V power and everything appears to be correct and in tact. I am still getting correct voltage from batteries to motor but draining fast. I am afraid I have a short in the 440 charging unit...... Any advice would be greatly appreciated. Brad
  • 905 Answers
Hello Brad / Colee
The voltage converter in the charger has gone out (violently). Do not use this charger in your craft anymore. There is no longer any kind of guarantee of isolation, and galvanic corrosion may be accelerated if the boat is sitting in the water and you try to charge batteries.
Replace the charger. Your craft and your lives aren't worth the risk. You can try contacting Minn Kota to see if there might be some kind of warranty assistance.
Posted on Aug 31, 2010
Minnkota endura c-50 shear pin size
You can get the appropriate pins in the prop not kits sold by minn Kota or thru major retailers.
Trolling Motor Replacement Props Minn Kota Motors
You will find prop nut kits here just follow the link.
Sep 28, 2014 | Minn Kota MinnKota MK110P Marine Portable...
ONLY THE check connection light comes on. There is
I am having the same issue with My Mk 210 charger and have tried contacting Minn Kota two times for help? Have you had any luck finding the solution ?
Jul 27, 2010 | Garmin Minn Kota MK 440 On-Board Charger...
Minn-kota wiring battery charger 4 bank trolling motor e-drive
call the 800 number for minn kota on the head of your unit for questions or technical data. they will send you a copy of your manual also if you dont have it. i am not sure what your question is so ask them to save yourself time.
Jun 01, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Battery charger
I have seen the threaded terminals on batteries where the threads do not go all the way down the terminals far enough to actually provide enough threads to tighten down wires!...whew..
Make sure the charger wires terminals are actually crimped on the wire and not the insulation..seen that too.
Jul 03, 2009 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
Boat battery charging issue
Hook up a differant bank and see if it says charged, check volts of battery must read 12.6 volts to be fully charged. If it dont bad battery
Jim OMC Retired Mech
Jul 01, 2009 | Boating
Wiring diagram for a minn kota mk220 2 bank charger
First. the +/positive/hot wires go to the respective/separate +positive/hot side battery terminals.. and the -/negative/ground wire go to their respective/separate -/negative/ground battery terminals.
The wires from the charger are "paired out".. meaning the + and - pair must go to the same battery. .. you can't mix and match.
Feb 27, 2009 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
Garmin Minn Kota MK 440 On-Board Charger CHARGERS Logo
229 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
