FixYa.com
Tags:
JVC AV-56WP74 56 in. Rear Projection HDTV-Ready Television
Jvc tv model av-56wp74 (by 2 users)
posted by lovelle40 on May 08, 2008
when I tried to turn my set on the speakers would pop in rythem and then stop,at this point the blue power light on the front would start to blink and no picture or sound.
I read your solution that it might be the power transformer,if this is so is it the board that the power cable is conected to Part #ssb-9068a?
please write me back at lovelle40@hotmail.com
thanks
mac
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by nancyiram, posted on May 23, 2008
tv went black while making a popping noise then i unplugged the tv because it would not turn off with button when turned back on there was no noise but the button was blinking a blue light and would not turn off without unplugging it
Solution #1
posted on Jul 07, 2008
Not Rated (0)
easyab
Rank:Master Master
Rating: 79%, 5 votes
1024x768 Normal 0 Won’t start
The power supply has an automatic shutdown circuit that senses a shorted component and excessive current flow.
If you can access the convergence board and remove the plugs one at a time (red, blue or green) for the convergence output, the TV may start up and show a picture with the unplugged color misaligned.
This confirms a short in the convergence output. The convergence IC failure can show up as coloured outlines or power supply shutdown.
If this does not help, then there is some other short circuit in power or deflection circuits. You need a technician to troubleshoot HV or power problems.
Replacing the output amplifiers (located within the Convergence IC's) allows the pictures to line up correctly, and no more color outlines or power shutdown.
This is the most common fault in all makes of rear projection TVs.
Some models of TV require major disassembly and considerable shop/manufacturer's support to repair because of their design that causes other power supply or vertical deflection problems. The poorly designed products require a "bench" repair that can typically cost from $350 t0 $700.
Some TVs are designed for on-site repair and have more reliable circuit design that does not usually cause damage to other parts of the TV when convergence chips fail. The ones that usually allow reliable on-site repair are JVC, Samsung and Hitachi.
It is normal to have some resistors in the circuit burn up or increase in value from the heat (from 2.2 ohms to 5 or 10 ohms). These resistors must be replaced with the right value or the chip may fail again.
This is not a simple repair like changing batteries or a fuse. Reading through the other posts shows many that try and end up with bigger problems.
Your JVC uses STK 392-110 IC's. Misinformed people replace the IC's with other "new and improved" IC's, like STK 392-150. These are devices with different characteristics and require different value resistors in the circuit. Replacing with the STK 392-150 will cause overheating of the resistors and a damaged IC.
If you are in Calgary, I can help. If not, get someone that has experience working on your JVC. My website is below with some costs and explanation.
calgaryconvergencerepair.weebly.com/convergence-explanation.html
Good Luck,
Easyab
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these Projection Televisions problems?
JVC AV-56WP74 56 in. Rear Projection...
red color trouble
my projection tv has a red... Answer This...
no sound
where do i solve this one Answer This...
JVC 56in. is broken
My rear projection tv isbroke... Answer This...
52 inch jvc projection tv, cant...
i cant get any movie to fit the... Answer This...
jvc projection tv
I have a 56 projection tv that... Answer This...
Repair Service
Find Projection TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
