Question about Whirlpool Washing Machines
My washing machine goes crazy in the spin cycle . it loses balance no matter how much the load is . flipped it on its side appears the springs are fine.
    President:
  • 1,554 Answers
It is almost impossible to advise you without the make and exact/compete model number of the machine and without the problem being described properly. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
Posted on Aug 30, 2010
My washes machine spins to slow then gets off balance an stops.how can I fix it ?
It may not be the clothes but the suspension springs and rods, counterweights etc
see pics
Jun 10, 2015 | Simpson Washing Machines
My washer is going crazy on spin cycle its smacking the sides of the frame
The drum in your machine rests on a gimble type mount and is balanced by extension springs. If one or more of the springs have stretched out, are broken, or have unhooked it could be the cause of your problem.
Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
Maytag washing machine gets out of balance
Maytag uses an auto balancing mechanism, based on the rear legs. These legs should move freely. Lay the machine on its side, and try to move the rear legs. If they won't move and appear rusty, then spray penetrating oil on both legs and move them until they move freely.
Sep 27, 2009 | Washing Machines
During the spin cycle the machine made a loud thud and now during spin cycles the machine pounds and slams yet when the machine is off the basket spins freely and without obstruction... any suggestions?...
It is doutful the basket or drum has warped. With such a loud thud and still doing it when you use the machine, it appears one of the balance springs or its mounting has broken loose. This will require opening the shell of the machine. Some models have a 3 point suspension, others have a 4 point suspension. This broken suspension point will account for the fact that you can spin the drum feely by hand yet it goes crazy when spinning with a load.
Because it is a front load unit, you must be careful or have a certain level of knowledge to open the unit and reclose it with the drum, seal, and facing all lining-up and not binding. As always, unplug the unit before taking it apart. Good Luck. Macgivor
Sep 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Unstable tub
There are springs inside the unit that stablize the tub during spin. If the springs are not attached correctly the tub will be off balance. Sometimes the Balance Ring loses it's fluid due to a crack or leak and the washer will spin off balance. THis requires a service tech to dissemble the machine.
Nov 27, 2008 | Kenmore 24032\24036 Top Load Washer
GE WSM2780W Stacked Washer spin cycle
With no clothing in the wash tub take the following steps:
1. remove the front cover from the wash tub
2. run a full cycle of laundry and observe the tub's behavior
Potential Solutions:
A. If the tub begins to shake wildly during a full wash cycle with no clothing in it then you will need to adjust the 3 large springs on each side of the tub until the unit is working in a more-balanced position. This is simple to do by hand. If the tub appears to be shaking too far forward, then unhook the 2 large springs in back so they are tighter. Then run a full wash cycle again with no clothing.
* note: there are smaller springs too - you don't have to adjust these to fix your issue
B. If the tub works fine with no clothing during a full wash cycle, then try to load your clothing in a more balanced fashion. For example: if your wash load is only a small kitchen or bath rug then when the unit spins it will spin off balance with a wet & heavy item on only one side of the tub.
C. If you'd like to replace the 3 large springs, I can get you the part numbers. There are specific springs for both sides of the wash tub and they are different part numbers. The full replacement of the 3 large springs can be done by hand.
thanks,
Chris I.
Sep 24, 2007 | GE WSM2780W Stacked Washer / Dryer
Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
May 19, 2007 | Kenmore 24872 Top Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
