Question about LaCie Ethernet Disk mini USB 2.0 External 250GB Hard Drive
LaCie 250GB Ethernet Disk Mini (300938U) Won't Power Up
I've had this unit for a few years. It was connected to a router via ehternet cable. About 6 months ago it stopped powering up. It would only power up when connected to a computer via USB. So I've had it hooked up that way since then. Now tonight the blue power light began flashing quickly. I powered down the computer and the LaCie unit also powered off. Upon starting up the computer the unit would not power up. The blue power light flashed very faintly but the power button will not start it up.
I had read somewhere that the power unit and/or on/off mechanism in it sometimes fails. Is there a way to repair or replace that? Or assuming that the HD is dead is there is a way I can get the data off the disk? Could a professional repair man open it up and hook it up to another unit or computer and copy the data off it? Any hints or suggestions would be very appreciated. Thanks!
IB4G2008
  • 3587 Answers
SOURCE: Unable to locate Lacie Ethernet Disk Mini on the network
Lacie's out to lunch..you may be experiencing the old drivers are shot issues..get em from the main site, and reinstall, ok?
Posted on Mar 24, 2008
SOURCE: LaCie 250GB Ethernet Disk Mini (300938U) Won't Power Up
Hi
External drives of this type are usually internal drives with case power supply etc. You should be able to open the box remove hard drive connect as a 2nd hard drive to PC either sata or ide depending on drive PC should recognise drive at boot up then you can access files and back up to CD, DVD, hard disk. If you are not comfortable doing this usually local PC repair shop will do for small charge. Assuming of course that the hard drive itself is not dead, just the power supply for the external case.
Hope this helps
Posted on May 21, 2008
SOURCE: powering up my Lacie ethernet disk 250
When I had this problem it turned out to be the power supply unit. Lacie replaced it - if you are out of warranty you can buy them for about £25 - and this solved the problem.
Posted on Oct 16, 2008
Geekman
  • 32281 Answers
SOURCE: Lacie 250GB Hard Disk is not being recognized by PC (Windows XP)
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
Posted on Jan 03, 2009
coldsilver20
  • 113 Answers
SOURCE: lacie edmini 250 GB will not power up
sounds like a faulty power circuit within the external housing. remove all screws and the drive from its housing. you now hold in your hand an internal hdd. remove all jumpers, if any are present, and install this drive on the same cable as your master hdd. now when u boot up to my computer window, you will see two hdd named C: and D:
Posted on Jul 01, 2009
I have a Netgear WNR2000 v4 router. We recently had a power outage.Power came back on in 5 seconds.The cable modem is fine,however the router ONLY shows me a solid green light for power, nothing else.
I would just do the reset, this should allow you to access at factory defaults. (I hold button in for 10 sec).
A solid green (power?) light is good
LAN ports should only light if connected
WiFi port should light if set to active
Mar 02, 2015 | NetGear Computers & Internet
My Bernina 210 Activa won't power up. I had it tuned up by a Bernina tech a few months ago and this is the first time I've pulled it out. No power/nothing. Seems like I'm just missing som
seems silly, but did you remember to plug it in? If you used a power strip, did you remember to make sure the strip is turned on?
Make sure the connection is plugged into the machine.
Good luck
Jan 23, 2013 | Sewing Machines
Cannot restore factory settings
You need to consult a qualified Technician.
Apr 17, 2017 | NetGear WGR614 Router
Hello, I've had my D-Link router for about 5 years now. The model is WBR-1310. The connection worked fine up until today. I took off the connectivity between the router and my PC about 6 months ago,...
If the default password on the D-Link has been changed then-
To reset the D-Link back to the default settings -
Press and hold the RESET button at the back of the router with the power ON untilthe LEDs flash at the time the release the RESET button.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. Now configure the wireless card in your computer/laptop withthe router's wireless settings.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Jul 21, 2011 | D-Link 802.11g Wireless Router WBR-1310...
My Samsung SPN-4235 had the picture go out several months ago. When the power button is pushed, it just flashed on and off. It wouldn't power on for 6-7 weeks, came back on for a few days, then started to...
The flashing led is on the logic board and it indicates communication from the main bd to the logic bd via the lvds cable --your problem would best be analyzed by verifying the va - vs - ve - vset -and vsc voltages - then if all are good it could possibly be the y-main or the x main bds
Feb 06, 2010 | Samsung SPN4235 42 in. Plasma HDTV
Problem with powering the monitor up. It just flicks off.
The operating system would not stop it from powering on.
It should power on even if disconnected from a computer.
You are probably in need of having the powerboard redone. Possibly a failing inverter.
If you know how to take it apart and can get some pictures to me at bammbamm@ptd.net , I may be able to see the problem.
Jun 20, 2009 | Samsung T220HD LCD Monitor
Hi
Hope this helps
May 07, 2008 | Computers & Internet
LINKSYS WRT54GS Router
I have the same router, the cable your receive your internet through should be plugged into the internet port on the router and another cable should be connecting your pc to another port on your router. after that run the setup software for the router. That should work
Dec 28, 2007 | Linksys Wireless-G WRT54GS Router...
LaCie Ethernet Disk mini USB 2.0 External 250GB Hard Drive Logo
50 people viewed this question
Top LaCie Computers & Internet Experts
Raj Patel
Tony
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
