Question about Poulan Pro 22" Self Propelled High Wheel Mower
I have a poulan Pro 550 series that i bought in October MFG Id# 96124000201 Ser# 042309M 003682 and have only used this season on my lawn. It seems to have no compression when I try to start it now. It is new and I was wondering if you have had any recalls or reports of the same problems.
5 Suggested Answers
SOURCE: the poulan pro 550 series is what i have and the
i have a poulan pro 550 series and my string broke
Posted on Sep 25, 2009
Dolfoff
  • 148 Answers
SOURCE: Poulan 550 mower idle problme
Check air filter, replace if needed.
Check engine oil level and condition. Add/change as needed.
Check spark plug. Clean and re-gap if needed (.030 gap)
Drain the fuel and replace with fresh premium grade gasoline. If your local station has a notice on the pump regarding Ethanol content, drive to another station!
Most owner's manuals specify 89 octane or higher and most warranties become void if E85 fuel is used.
And finally, Oxygenated fuels are not your mower's best friend. :-)
Hope this helps.
Posted on Oct 05, 2009
SOURCE: Poulan 550 Series push mower won't pull start
Poulan 550 series self propeeled mower. Mower starts and stops running after 10 seconds. Gas tank full. Filter cleaned.
Posted on Sep 17, 2010
  • 59 Answers
SOURCE: I have a poulan pro
tilt the mower down by the handle, and underneath on the bottom of the motor you will find a drain plug. it has a 3/8 square hole in it. This is the oil drain plug.
Posted on Sep 25, 2010
How much oil is needed for my Poulan Pro 550 lawnmower?
Briggs and Stratton call for 20 oz but warn to confirm the level with the dipstick reading.
Jun 11, 2014 | Poulan Pro PR550N22SH 22Inch Briggs ...
Replacing the muffler on the poulan pro 550 model number 961240002 00
there is two ways to mount mufflers on small engines. one with two bolts through the muffler to the block or threaded to it. if you don't see bolt heads then you unscrew the whole muffler.
Aug 06, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
My poulan pro 550 series is vibrating a lot when I started. And the front wheel drive is not working anymore.
you need to unplug the spark plug then turn the mower on its side sounds like you hit a rock and bent something and if you bent the crank the belt might have fallen off
Jul 01, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
What is the proper spark plug size for poulan pro 550 series
Go by the numbers on the original plug. The gap should always be set at 0.30.
May 24, 2012 | Poulan Pro PR550N22SH 22Inch Briggs ...
My sister bought a Pro 550. Got a good deal but there was no manual with it. Brand new from Walmart. Was working fine. used it twice. No problems. Boyfriend came by. Said she was suppose to put the whole...
Option #1:If its less than 90 days old return it to walmart.
Option #2: drain the oil and refill with the correct amount. Contact Puolan or a poulan dealer for a manual.
locate the model number and look for your manual here
http://lawnandgarden.manualsonline.com/manuals/mfg/poulan/961240002.html
Eric
Jan 19, 2010 | Poulan Pro " Pro" Self Propelled Mower
Poulan Pro 22" Self Propelled High Wheel Mower Logo
85 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
