Question about Microsoft Wireless Optical Mouse
Mouse Right click doesn't work
My mouse moves around but suddenly it no longer works when I try to click with it. It happened all of a sudden today. First the right click worked but the left click wouldn't but now both aren't working and I've tried restoring my computer to an earlier time but its still not working.
  • 2 more comments
  • aminaie May 08, 2008
    The mouse I'm using is a normal standard mouse that plugs into a similar port as the one for the key board which is a round port in the back and its a regular mouse with a ball and just two keys and a scroller in the middle. The mouse moves the pointer but since two days ago when I had a virus on my computer the mouse first acted like I was holding the left botton to drag something and would stop high lighting everything and then it stopped clicking with the left click altogether. Now the left click does not work either except when I open Firefox. My computers a PC and I was able to I think get rid of the virus and I restored my computer to an earlier time but the mouse still won't click. It works when I first turn on my computer but once my computer's done loading everything it stops working again. I'm guessing it might have to do with something that's being loaded after I turn on the computer.
  • rickky Jul 22, 2008
    Yeah, I have the same thing on my laptop (using a touchpad; both double tapping the touchpad and using the buttons don't work any more) don't think that it's a hardware problem. My computer's also slowed down quite a lot since the problem started.
  • nilarkhine56 Jan 26, 2009
    my left click and touchpad is not working anymore
  • Anonymous Mar 20, 2014
    left click of dell laser mouse is not working can anyone help plzz
    Novelist:
  • 144 Answers
Hello!
o Install fresh batteries. Try brand new-high quality batteries you absolutely know are fresh and working.
o Install the latest software. Totally remove all software and reinstall from scratch.
o Try a different port and Resynchronize your device to the receiver. Try plugging the mouse into a different USB port try powering down the computer and using the PS2 port for the mouse instead. Mice in my experience overall work better using PS2 ports on PCs that have them.
o Clean the mouse lens. This problem may occur if you are using an optical or laser mouse and the lens on the mouse is dirty.
Posted on May 08, 2008
    Novelist:
  • 150 Answers
Replace the batteries and check to see that there is a clear path
between the wireless mouse and its transceiver.
Keep the transmitter well away from older style CRT monitors, and make sure that the USB connector is properly plugged in.
You can also try to reset the mouse by unplugging the USB
connector and plugging it back in. There is no need to reboot
the PC, because USB is hot-plug-and-play.
1) The mouse consumes very little power in standby mode.
When the mouse moves or you press a button, the mouse
wakes up, it's internal processor begins to crunch
coordinates, and the RF transmitter is briefly activated.
This surge in power quickly depletes a weak battery, and
the mouse begins to malfunction. After a short rest, the
battery partially recovers (this is due to chemistry) and
the mouse may work for a few seconds again.
For some reason, my Logitech mouse fails quicker, when
I press buttons, rather than just move the track-ball, and
the buttons are the first to malfunction.
(No I have not analyzed the circuit and the internal mouse
software to determine the exact reason it does this ::)
Anyway, replacing the "AA" battery should help.
2) The location of the little RF transciever, which connects
to the computer using a USB cable, in relation to the mouse
is also important.
a) The communication signal weakens with the square
of the distance.
b) Metallic objects will block the signal.
c) CRT monitors emit powerful, wide band interference,
polluting large segment of the radio frequency spectrum.
This interference can over-power and corrupt the faint
communications between the mouse and the transceiver.
3) If these obvious measures fail, you may have a defective
mouse:
a) The fault is most likely in the mouse, not the transceiver,
but do check in the control panel => mouse settings
to see if the mouse is communicating, and the battery
status.
(Most mouse drivers do report these things)
b) If the mouse is at fault, you can disassemble it by
removing a few small Phillips screws. Pay special
attention to any mechanical linkages, springs and levers,
to make sure you put it back together correctly.
c) Pop out the tiny circuit board, and locate the mechanical
micro-switches. See if they work when you manually
activate them.
If they feel intermittent or flaky, you may try to clean them
with a spray contact cleaner, or replace them, but given
the price of mice these days, this may not be worth it,
save for the psychological boost/and or satisfaction.
Martin
Upon disassembly of the mouse check for dirt in the microswitch. Blowing mine out with compressed air solved my problem.
Posted on Oct 09, 2008
5 Suggested Answers
SOURCE: changed batteries, mouse no longer works
what is the receiver?
Posted on Apr 02, 2008
yooperbud
  • 8637 Answers
SOURCE: MS Optical Mouse 4000 problem; computer mouse pad no longer functional
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Hope this helps. Bud
Posted on Jan 19, 2009
thbestofme
  • 64 Answers
SOURCE: Mouse won't work after battery change
hi, try to perform the steps in the article below from HP.. http://tinyurl.com/y8ek43e and also try to perform a diagnostic test on mouse. if its a HP computer to do so.. go to Start -- All Programs -- PC Help and Tools -- Diagnostic Tool..
once the tool is open go to Communication.. and run a test on mouse.. if ur unable to use it there.. then if ur system is under warranty.. call HP and get the mouse replaced..
let me know if this was useful to u regards, guru
Posted on May 05, 2010
  • 239 Answers
SOURCE: my mouse creative wireless is not working
sounds like you need to resync the mouse to the wireless receiver that is connected to the computer.
Posted on Mar 01, 2009
My Evoluent 4 mouse doesn't work with WIndows 7
win 7 driver has stopped working
uninstal the driver for the mouse , find the web site for the manufacturer of the mouse , get the download for that model and compatibility with win 7 , down load and run
win 7 os is no longer supported by Microsoft so driver bugs and other glitches are not being fixed
Jan 22, 2018 | Evoluent (VM2-LBB) Mouse
The mouse appears to be on but the pointer on the screen does not move. The keyboard is still working. The re-set button does not correct the problem. Re-booting the computer does not work.
The same thing happened to me today. Somehow, something uninstalled my setpoint mouse software?!?!
While I was actually using the mouse?!?!
(it just stopped moving all of a sudden)
Don't ask me how/why this happened but I fixed it by unplugging the MX1000--both power and usb connection, plugging in an old serial mouse, rebooting the computer, opening mouse properties, going to the Mouse settings (in Control Panel), clicking the Setpoint tab, telling it to look for an update to the Setpoint program, letting it download and install the program automatically, then unplugging the old serial mouse, plugging in the MX1000 (usb first, them Power) and Voila'! Working as it should once again, even without a reboot. :o)
I love this mouse--perfect size, fast, programmable, accurate, long battery life, Perfect!
Aug 06, 2010 | Logitech MX1000 Laser Cordless...
My mouse wont work on my home PC all of a sudden
Some Computers take longer than others to recognize that there is a
mouse plugged into the computer. If it is a USB mouse try plugging it into a different port or, if a disc came with the mouse, run the disc and install it manually. If all that fails consult a experienced HP consultant. Hope this helps and please don't forget to rate.
Feb 23, 2010 | HP Computers & Internet
Right'click option has stopped working
Try another mouse If it works then it is your mouse. They are really cheap so you can pick one up a Wal-Mart really cheap..
Oct 10, 2009 | Microsoft Wireless Optical Mouse
HI,
REALLY DEPENDS ON THE AGE OF THE MOUSE AND HOW OFTEN YOU USE THE RIGHT CLICK FEATURE. LIKE MYSELF I USE IT CONSTANTLY. UNFORTUNATLEY IF THE RIGHT CLICK NO LONGER FUNCTIONS AND YOU USE THE MOUSE ALOT LIKE ME THE MOUSE IS SIMILAR TO A KEYBOARD IN THAT IT HAS ONLY SO MANY TACTILE TOUCHES BEFORE IT HAS WORN ITSELF OUT. YOU CAN HOWEVER GO TO CONTROL PANEL IN YOUR OP SYSTEM UNDER MOUSE ETC AND DIAGNOSE A SOFTWARE INCOMPATIBILITY BY RECALIBRATING THE MOUSE. IF THIS DOES NOT WORK IT IS MOST LIKELY TIME FOR A NEW MOUSE.
GOOD LUCK, HOPE THIS HELPED!
Mar 30, 2009 | Computers & Internet
My wireless optical mouse is no longer working
You replaced the batteries. Okay. Did you install drivers for the mouse from a CD? Are you using Windows XP? Do you notice any change if you use the mouse on a darker surface as opposed to lighter surface? If the computer installed the drivers for you, then you might want to delete them in Device Manager (might be called something like HID-Compliant Mice. Single click on that entry, press the delete key. You might have to reboot your PC after that. From there you might have to unplug, then plug in the mouse again and you should notice the driver reinstalling. Give it a second and all should be good.
*Access the Device Manager by right-clicking on My Computer, select Properties, go to the Hardware tab and select Device Manager.
Mar 20, 2009 | Computers & Internet
Magnifier doesn't work
Try going to Control Panel and click on the mouse icon. Then the mouse properties will appear showing the mouse. In the left column,move your cursor over the right side button click on the drop down and select magnify. Hopefully it will now work.
I had to move the magnify function to the left button because it was to sensitive on the right.
Nov 27, 2008 | Microsoft Wireless Laser Mouse 5000
I have a desktop i purchased new in aug 2007 windows vista, i havent had any problems, working perfect, all of a sudden the mouse will not move, i tried to re-do the mouse and the tried another mouse,...
Vista also has some funny issues w/ updates. try restoring to an earlier day or waiting until all the updates have been installed. Happened w/ my wifes laptop.
Apr 19, 2008 | Computers & Internet
It's not working right....
The BenQ M310 mouse needs to "sync" with the USB receiver. Need to push the two buttons at the same time, or maybe the one in the mouse first then push the button in the USB receive so the two can "sync" to each other. This may solve this problem. Good luck!
Feb 16, 2008 | BenQ M310 Wireless Mini Optical Mouse
Microsoft Wireless Optical Mouse Logo
9,890 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
