Question about Lowrance GlobalMap 4800 GPS Chartplotter Receiver
Lowrance Globalmap 2000
Hi there,, how can i replace or clean the exsiting screen on the lowrance Globalmap 2000 ?
please help
  • Anonymous May 21, 2008
    How do I clean the exsiting screen on the lowrance Globalmap 2000? It appears to be hazy inside.
The screen is the weak point of the 2000's.  I have one myself, and without warning a number of "lines" appeared on the screen, getting progressively worse over time.
Perusing other forums, it seems we're not alone.  Unfortunately the only "solution" I've found thus far is to purchase a new head unit (eBay is a terrific source!).
Posted on Jun 01, 2008
Hello, I need help. I bought a boat that was equipped with a Global map 2000 broke, I bought one from Ebay because the United States in Spain can not be found. I have a global map 2000 s / n 2087954 version 2.0 - a c-map map link s / n 1786020 - a Sat-1 s / n 1791813. I read that according to the internet version of the global map 2000 need a Sat-st for the transponder on. Can you tell me if version 2.0 of the global map 2000 can work with Sat-1? Thank you in advance for your help. country: Spain
Posted on Sep 08, 2011
My Lowrance 5500c powers up gets to aquired satelites and then stops on that page.No buttons work and the power has to be disconnected to turn off.
It is an old unit, it has been discontinued, there are no software updates for it.
Technology has moved on with larger High Definition displays, colour and side imaging. Time to retire it and look at Humminbird. I have the 998 HD Si. That replaced a 798 before it. Lowrance have the Chirp equivalents if you want to stick with Lowrance.
Or you could return it and see if they can fix it
http://www.lowrance.com/en-US/Products/Chartplotter/GlobalMap-5500C.aspx
I did find your manual :>)
http://www.lowrance.com/Root/Lowrance-Documents/GlobalMap5500C_0151-271_012105.pdf
Oct 03, 2016 | Lowrance GlobalMap GPS
How can a lowrance 5300 globalmap iGPS be used as a fishfinder.
Sadly, the 5300 does not have fishfinder/depth capability.
If you require it, the link below is for the owners manual for your unit.
Sorry I couldn't have given you happier news.
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/GlobalMap5300ciGPS_0152-191_120506.pdf
Feb 24, 2015 | Lowrance Globalmap 5300c Igps 5" Screen...
Lowrance globalmap 2400 on/off button stuck, unit tries to turn on then screen is blank, tried wiggling back and forth no luck, should i send it in for repair and where to...live in carroll county, md....
You can try a hard reset:
1. Turn unit off
2. Press and hold ZIN, ZOUT, and PWR until you get the "WARNING, DO NOT RELY..." message.
If that doesn't work, try installing the latest updates from http://www.lowrance.com/en/Downloads/Product-Software-Updates/
If it still doesn't work, and you can't get through to Lowrance by phone, try emailing them by going to http://www.lowrance.com/en/Support/Product-Support/Contact/
It probably won't be worth repairing the unit. You will be better off putting that money into a current unit which will be much better than the 2400 and probably less expensive than the 2400 was when it was new.
Mar 23, 2009 | Lowrance Globalmap 2400 GPS Receiver
Lowrance not reading navionic
Make sure that the 5200c is set to read the Navionic card. You can set that under Map Data.
Mar 08, 2009 | Lowrance GlobalMap 3500C GPS Receiver
LOWRANCE 5200c
i need help to mine does the same thing
Nov 08, 2008 | Lowrance Globalmap 5200c Color...
Gps
upgrade it firmware usnig the download support are in the main page of ur product u will find it there!!
Sep 10, 2008 | Lowrance GlobalMap 3300C GPS Receiver
Globalmap 2000 sonar not responding
Not enough info to diagnose your problem. It sounds like a networking problem. I couldn't find a manual for the sam-st module so I'm not sure how you have it hooked up. Typically with these devices only one would be hooked up to the SONAR module, and it would then share the data with the other display via an ethernet or NMEA2000 network. The erratic behavior of your bluewater could be due to some sort conflict with the current coming from the GlobalMap2000. Do you get the same problem when the 2000 is turned off? Have you tried running the GlobalMap2000 with the bluewater turned off?
Aug 04, 2008 | Boating
Lowrance will give me a mob position but will not set automatically for running positions stay 0
I would like to help but I'm not sure I understand the question.
Are you saying that when you push the zoom in and zoom ou key at the same time you get a correct position, but you can't see a box that gives your real time position?
Is your map page set to show data on the right side of the screen? If not, press the page key and select the map/data page. This should give you some information on the screen which includes your current position, updated every second.
If I missed the mark with this answer, please give me some more details so I can help.
Jul 21, 2008 | Lowrance GlobalMap 3500C GPS Receiver
Open Questions:
Lowrance GlobalMap 4800 GPS Chartplotter Receiver Logo
1,031 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Wbix
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
