Question about Coleman Heating & Cooling
AC fan motor will run, compressor will run, but the OFF position it doesn't turn off right away and also if I push on the selector switch (Hi Cool, Low Cool, etc.) it slows down the fan. After a couple of minutes the whole thing turns on/off sporatically
  • 32 Answers
Could be a burt wire at the compressor terminals or a bad capacitor I would look at the capacitor
Posted on Aug 30, 2010
Ac fan not running, but compressor runs on and off
switch/ fuse possible if it has one, if not one of the wire going to the motor was severed, or the start up capacitor of the motor if it also has one.
Jun 04, 2013 | Frigidaire FAX054P7A Wall/Window Air...
My Dometic roof top ac doesn't cool. Fan runs fine, no COOL air. With thermostat in off position. Checking the voltages I found 118v at the breaker. At the run relay, 118v going in and a coupl
Please reply with Model number of bottom of AC unit ( upper) . Can be seen from inside usually. Thermostat model, plus if controls are at the ceiling assy or at thermostat on wall.
Jan 17, 2013 | Dometic Rooftop RV Air Conditioner
Hi,I have a travel trailer 37ft. Problem with my ac, the fan starts good but my compressor does not kick on. My next door neighbour says it's the compressor that is done. Could you help me?
see this causes and fix it. God bless you
Motor Trouble Cause Diagnostic Procedure Repair Procedure Electrical Power is Off Check that all service switches for the equipment are in the "on" position.
Check for voltage at the pump motor or pump controls. If no voltage is found, check for voltage at the electric panel.
If power is on to the building, check fuse or circuit breaker serving the electric motor that won't run.
Check for local reset button on the motor (popped out = off )
Check for other power reset or power off buttons such as an access door compartment safety switch that turns off power to the equipment (found on A/C blower compartment doors)
Turn on "off" switches.
Replace bad fuse. Reset circuit breaker; if necessary replace bad circuit breaker.
Let hot electric motor cool down, then push in its reset button.
Be sure all safety interlock switches such as on compartment doors are depressed and that the doors are securely shut. Replace a bad safety switch.
See
ELECTRICAL POWER SWITCH FOR HEAT
FAN AUTO ON Thermostat Switch
WATER PUMP ELECTRICAL SWITCHES
CIRCUIT BREAKER FAILURE
ELECTRIC PANEL INSPECTION
Blown fuse, tripped breaker Replace fuse or breaker - does the pump run and keep running normally? Be sure proper breaker or fuse size in ampacity is installed - ELECTRIC PANEL INSPECTION Low voltage to the motor Check with VOM at the pressure control switch or at the motor wiring Be sure the proper size of wire is used for the ampacity and length of circuit; Test for low voltage to the building. Loose, improper, or broken motor wire Check wiring against the motor installation manual diagram, check all connections for tightness, shorts, burns, damage Rewire or repair or replace wWhen a sealed compressor motor has "burned out" this means that the internal wiring of the motor has become irreparably damaged: the compressor motor windings may be burned and shorted together or shorted to the steel shell of the motor, or the windings may have burned and simply become "open" or disconnected. If the motor has burned out in either of these ways it needs to be replaced.
Oct 08, 2012 | Dometic Rooftop RV Air Conditioner
I turned on the ac and the light does not work, the vents are not blowing and the car is running hot. I have a saturn SL 1996
First check the 15 amp HVAC fuse located in the main fuse block inside the car on the passenger side of the center console, under a cover. If the fuse is good, then the problem may either be the HVAC blower switch (which is the fan blower selector switch), the fan blower motor resistor, or the fan blower motor. An auto repair manual will explain and illustrate for you the steps on how to check each of these components.
Even after pushing the ac light switch on, the fan blower selector switch has to be turned on as well (working) because it provides an electrical path to the positive side of the battery to complete the circuit and turn the ac light on. What the ac light switch does is provide the electrical path for the ac compressor clutch to come on through the ac control relay which is controlled by the car's PCM(computer) when you want ac, but the ac light switch still needs to run through the fan blower selector switch to receive its power. You can turn on the fan without the ac light switch because it gets its ground path(negative) from the blower motor. So the blower motor has to work in order to provide a ground path for the fan blower selector switch to be functional. You could have a faulty blower motor which is why no air blows through the vents. The fan blower motor is located inside the car on the passenger side underneath the dash at the bottom end of the glove compartment box. You'll see it. It's right above where a person rests their feet on the floor. Therefore, if your 15 amp HVAC fuse is good, check to see if you have voltage at the blower motor connector. Unclip the connector and with the ignition on and the fan blower switch moved to any one of the first 3 selections, check for voltage using a multimeter. The voltage will vary because there is a blower motor resistor. Voltage should be higher on setting 3 than 1. If you do have voltage at the blower motor connector, check for a faulty blower motor. The auto repair manual will tell you how to do it using jumper wires.
It's normal that your car is running hot because the radiator fan works in conjunction with your ac compressor. If the ac is on, the radiator fan will be on and therefore the engine coolant temperature will stay in it's normal operating range. If the ac is off, the radiator fan will stay off as well and the engine coolant temperature gauge will begin to rise and show pretty hot (especially at idle). It will do this up until a certain degree then the radiator fan should turn on thermostatically and stabilize the temperature. It's scary and I know what your saying because it does that to my car if my ac isn't on. Don't worry it won't overheat.
May 29, 2011 | 1996 Saturn SL
Coleman AC compreser work but fan dont
If the selector switch is broken, you need to replace that first. This will cause the fan not to come on if there is an open in it. After replacing the switch, if you still have to fan operation, it is possible that you have a bad fan capacitor, part# 1499-5461, or a bad fan motor, part# 14683099. Replace the capacitor first before spending the money on a motor. An easy way to check is to see if you can start the fan motor by hand while turning it on a the selector switch. If the motor starts this way, replace the capacitor.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic 57915531 Air Conditioner
One day my RV Coleman ac just quit running on low cool but every other setting works fine. Any ideas?
Is your Air Conditioner run with a wall mounted thermostat or the ceiling pack controls? If it is the ceiling pack controls, then your selector switch has gone bad and needs to be replaced. This is located in the ceiling pack itself and is relatively easy to do. You can easily test it with an Ohmmeter, going through these steps:
To check the selector switch, remove wires from the terminals
and rotate the switch to the proper position and read
continuity as follows:
Terminals Switch Position
L-1-3 Lo Heat
L-1 Lo Fan
L-2 Hi Fan
L-1-4 Lo Cool
L-2-4 Hi Cool
* If you do not wish to remove the wires from each terminal,
disconnect the 9 pin plug from the a/c unit.
Hope this helps,
Jeff
Jun 27, 2009 | Coleman Mach 15 Air Conditioner
Dometic ac in RV
Do you have a wall mount thermostat? Thats what I would look towards first since its easy to get to. Don't let your compressor run with out the fan you can burn it up. I would just use the breaker as an on off switch intill you can get it looked at.
Jul 25, 2008 | Dometic Rooftop RV Air Conditioner
High cool not working
Compressors on these units runs at only one speed. The change to high cool is only a change in blower speed moving air faster over the cooling coil. I would have the running capacitor for the fan motor checked. A bad capacitor can cause your type of problem. The other problem could be that the high speed winding in the fan motor is bad. Try it operation in the fan only position through the two speeds. If it works in the low and high speed for fan only your problem could be in the selector switch.
Jun 23, 2008 | Dometic Rooftop RV Air Conditioner
Duo-therm by dometic ac rv unit
I suspect that you have a bad selector switch for the on, off, low fan, high fan operation. If the selector switch is put into the off position everything should stop completely.
Apr 30, 2008 | Dometic Rooftop RV Air Conditioner
Carrier home heat
If the unit is manual control there are two knobs in the control the thermostat and the selector switch. If your selector switch is in fan position the fan will run and the compressor will be "off"(even if you "off" and "on" your thermostat), if your selector switch is in cool position and your thermostat is in "on" position the compressor and fan will both run. But if the thermostat is in "off" position and your selector knob is in cool position the fan will run but the compressor will be "off".
Nov 08, 2007 | Heating & Cooling
Heating & Cooling Logo
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
