Question about Senco GT90 Clipped Head Gas Framing Nailer
Senco GT90 CH Nailer intermittent in operation
3 Suggested Answers
  • 25 Answers
SOURCE: driver sticks down of senco pin nailer
This problem can happen because of several reasons.
Most likely the driver stuck, and not able to move.
First with the tool disconnected from the air supply check to see if there any nails jammed in the nose piece.
If the driver is stuck down, try to push it up. Will it move?
If there are no problems visible at this point you will have to open the tool up, and see if anything looks out of place.
To examine the inside of the tool, unscrew the 4 bolts on the cap of the tool. Gently remove the cap, it may be spring loaded but once the bolts are loosened, there is no reason to be afraid of the parts springing out. Be careful not to let the parts that are in the head cap fall out. Also take care not to rip the gasket. Keep in mind, the less parts inside that you disturb the better so be careful.
If the piston driver does move. Does it move freely?
Sometimes when a driver hits a very hard knot in the wood, or if a nail is hit. The thin driver may bend. If it is moving but with resistance. Use a thin object to push the driver upward from the nose. It will come out of the head cap end.
Check to see if the driver is straight and square to the piston. If it is bent, you may need to replace it. Sometimes you may be able to bend it back enough to allow the piston driver to move freely.
If this solves your problem. To reassemble:
Replace the driver in the correct position. Replace the gasket if it is loose. If parts came out of the head cap, reposition them into the cap. Replace the head cap on to the tool. Replace the bolts, stagger as you tighten them to depress spring loaded parts evenly.
Hook the tool up to your air supply check for air leaks, and fire the tool.
If the driver does not move: Examine to see what is seizing the piston and reply back.
I hope this works!
Posted on Apr 19, 2009
rowdy45176
  • 2176 Answers
SOURCE: Senco SN4 nailer not feeding
ther isn't a spring, it works on air to pull the driver back up. Have you tried oiling the tool as recommended (about 6 drops a day) If not then you have a problem with either o rings that are dried out or worn so they cannot keep the suction required for the tool to operate properly. Might also be a bent driver (doubtful). Go to Senco.com and type in your model number and they list rebuild kits for this tool. If you need more assistance let me know and if I have helped with your request would you please rate this accordingly.
Posted on Sep 12, 2009
Trigger
There is no adjustment that can be made to make the safety work or not. When new, the SCN45 had a safety system that prevents the nailer from firing unless it was pressed against a surface. If your gun fires without the safety being compressed, it has somehow been bypassed either by being jambed or tied in the firing position or the trigger lever is wedged so it can't operate properly. Below is a site that has a great breakdown of your tool that you can reference to see what parts may be missing. This is an older tool and many parts are no longer available.
Senco SCN45 Coil Nailer Parts
Dec 31, 2013 | Senco SCN45 Coil Nailer, Contact or...
Air nailer vnot operating. blowing air from top close to handle
Your nailer has worn or broken o-rings in the top end. You need a rebuild kit (Senco part number YK0360) to get your gun going again. They are available through most online, after market parts stores. When you get it, remove and replace each seal and o-ring one at a time so you get them all back in their proper place and use all of the grease to lube the o-rings. Use all of the parts in the kit, if one o-ring or seal is damaged the others are not far from failing.
Jan 25, 2011 | Senco FP620 Framepro 602 2" - 3 - 1/2"...
SENCO Framing nailer suddenly decided not to fire. Air escapes from top of gun when trigger is pulled
You have some worn/broken o-rings inside the gun. You need Senco repair kit #YK0360 to fix it. Fairly easy to replace the o-rings, just be sure to put lots of lube on the rings as you put it back together.
Nov 29, 2010 | Senco FP620 Framepro 602 2" - 3 - 1/2"...
Air leak top of gun senco oil less coil nailer scw40r. unclehhotmail.comowd@
Nailer scn40r is an oil less coil roofing nailer. If it will not fire and leaks out head then most likely problem is diaphragm torn or pinhole. Replace firing valve part # BAO120 for good as new operation.
Order parts from www.toolpartsdirect.com
Oct 16, 2010 | Senco Tools & Hardware - Others
I have a Senco Accuset nailer - #A125B None of the 1 1/4 nails from Lowe's will fit, they are all a little off. The box says they fit 'any' nailer. Am I doing something wrong?
try a contractor supply, or find a senco distributor in your area, there used to be one in my hometown of Hayward, Calif. Tey carried fasteners for all models.
Sep 22, 2010 | Senco 2D0001N FinishPro2N1, 18 Gauge Brad...
GT90CH fires but no nail after twenty shots.
a bit of air tool oil might help, make sure you are not getting condensation in the line, otherwise you may have to dissassemble to clean
Jul 27, 2010 | Senco GT90 Clipped Head Gas Framing Nailer
I have an older model senco finish nailer that continuously blows air out the exhaust what is the problem?
probably a split or stuck o ring. You can go to Senco.com and download a breakdown and purchase a rebuild kit for this tool.
Mar 27, 2010 | Senco Finishpro 15 Finish Nailer & Sls15...
Sep 11, 2009 | Senco Air Tools & Compressors
SENCO SHF 50 floor nailer won't consistently sink cleats
Some Senco tools reqire oil.  there is oil specially designed for tools.
Aug 01, 2009 | Senco SHF50 2" Hardwood Flooring Nailer...
Senco GT90 Clipped Head Gas Framing Nailer Logo
126 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Trippy Tripp
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
