Question about MagLite Mag-Lite& Flashlight
I have a 6 d cell maglite. when i removed the end cap 3 batteries came out number four is stuck in the maglite. how can i get it out?
  • 377 Answers
Not sounding good. I have had the problem in the past with Mag lights and though they are good, I always seem to have battery corrosion problems. What I have done is to get a non-metalic rod, wooden doweling has worked for me, carve a bit of a blade at the end, sort of like a long screw driver and work it into and between the batter and flashlight case. Not so hard as to deform the flashlight, but to try and break the seal between the corroded (I assume) battery and the case. Spray in some WD40 and work the dowel in and around the battery. Stop on occasion and tap the open end of the flashlight on a heavy rag laid atop a piece of wood to try and jar the battery loose. By repeating this process I have been able to remove corroded batteries, but not necessarily save the flashlight, as some times the on/off switch is corroded as well. Once you get the batteries out you may be able to clean the inside with some abrasive (steel wool?) to clean out the corrosion, but as I said, you may not be able to save the light. Best of luck!
Posted on Aug 30, 2010
Replace batteries
Marcia Boal... hello,
If our battery has corroded it may be impossible to get the end (opposite the light) cap to come off. The light is designed to be moisture resistant... Likewise even penetrating oil cannot get in...
To guarantee long reliable service it is best to put a tiny dot of grease on the threads on assembly.
Maglite Solitaire makes a wonderful little flashlight...
(all metal construction... single AAA battery)...
((Mini = 2 AAA batteries... opens the same)).
Basic colors included black, red, silver & blue
but this particular light was also quite popular for commercialization... often displaying many BIG NAME
COMPANY LOGOs.
The initial closure of the end cap can be quite loose to be effective because of it's O-ring design... however some folks put the end cap on too tight...
The
It might take some serious force to get it open again.
Consider using a piece of leather in a pair of pliers to avoid marring the case. Reassemble without over-tightening.
Hope this helps!
Maglite Solitaire Incandescent 1 Cell AAA Flashlight Black Basic Handheld...
Amazon com Maglite Solitaire Incandescent 1 Cell AAA Flashlight Blue Home...
Maglite Solitaire LED 1 Cell AAA Flashlight Red Basic Handheld Flashlights...
Maglite Solitaire LED 1 Cell AAA Flashlight Silver Basic Handheld...
Aug 19, 2016 | Camping, Backpacking & Hiking
I had two maglite flashlights, 1 is a (2)D cell light and the other is a (3) D cell light . I went to replace the batteries and I can not get cap off the back ends of both. I think the batteries may have...
the batteries will only go out the bottom -- any attempt to remove the top pieces will most likely result in damage to the light itself. to help in the removal of the BOTTOM cap -- you can try and use a little heat from a propane torch ( not much ) and if you place the end cap into a vise you should be able to get both hands on the top part and give it a good twist. -- if the batteries are if fact corroded in there, get a 2x4 and place it on the gound and tap the flashlight down on it,, this may or may not shake them loose,, all just depends on how long they have been in there. good luck.
c...
Jan 01, 2011 | MagLite Mag-Lite& Flashlight
How do I change the batteries in a AA maglite?
Remove the end cap by turning counter-clockwise and pulling cap off. It may be a pretty tight fit so you can wrap a rag around base cap and use pliers to loosen. Use rag or duct tape to protect finish on your light end cap. The threads are very fine so after you have removed end cap and replaced batteries be careful not to cross thread when reinstalling end cap. I hope this helps you. Thanks.
Dec 17, 2010 | MagLite Mag-Lite& Flashlight
1 "D" cell battery is corroded and stuck inside.
Here are the instructions:
http://www.maglite.com/pdf/CustServ/CD_switch_repair_8_0410212004718132.pdf
If you remove the tail cap (the part that you unscrew to put the batteries in the flashlight) and the head assembly (the part that has the light bulb) you should be able to push the battery out. Wear some of those disposable latex gloves as that chemical that comes out of the batteries is very corrosive. Or at least wash your hands really well before touching anything, especially your eyes. Good luck.
Nov 16, 2010 | MagLite Mag-Lite& Flashlight
I have a 3AA LED mini maglite with stuck batteries. The best I can tell they have not leaked. I tried freezing the unit as well as heating the barrel to no avail. Is there a way of removing the bulb...
well, I have a 3 cell mini maglite AA with a corroded battery stuck up next to the LED. I have searched but not found a way to remove the LED to push out the battery with a dowel. The best solution I read about was to drill a hole in the battery and insert a large screw and pull it all out.
(My Maglite is from 2009 or 2010, but I think they made this model in 2011, 2012 and 2013- this is for SEO!)
Sep 13, 2010 | MagLite Mag Lite Led 2 Cell Aa Flashlight...
Battery stuck in 3 AA battery Minimaglite
The battery has to make contact with the bulb as well as the end cap, so if you take the end cap off and the batteries don't come out that end I recommend pulling the bulb assembly apart and taking them out that end. And the next time you put batteries in coat the outside of them (not the terminals) with electrical grease (like you put on car batteries) to prevent them from sticking in there again. Note: if both ends are removed you can use something like a screw driver to push the batteries straight through and out the other end.
Jul 04, 2010 | MagLite Mag-Lite& Flashlight
Battery case does not open
make sures its being turned to the left, and if it will not come off, wrap duct tape around it to protect it and use large vice grips or pliers to get it off. Vice grips would be better as the lock but dont' lock them down too tight as you can dent the cap.
Jun 30, 2010 | MagLite Mag-Lite& Flashlight
Flashlight only works when end cap is partially on. Will not work when cap is fully screwed in. New batteries installed.
Some models of the famous MagLite use this 'feature' as the on-off switch. I have several such myself.
Thanks foryour interest in FixYa.com
please remember to vote
thanks
a
Dec 05, 2009 | MagLite 3 Cell D Blue Flashlight S3D116
Keeps turning itself off when adjusting beam
It sounds like the spring in the tail cap may be depressed which would cause intermittent contact with the negative end of the Batt. Shake the flashlight vigorously, you should NOT hear ANY noise. If you DO, take the end cap off and pull on the spring, you are trying to stretch it out a bit, replace the cap and shake it again. Go through these steps until it is QUIET when you shake it.
Also make sure there's NO CORROSION at the Positive and Negative ends of the contacts.
Maglites are pretty user friendly and the best light money can buy. I have the rechargeable model which I carried for 21 years during my tour in law enforcement.
Anyway, if it still refuses to work properly, go to; www.maglite.com they are based in California. They will help you get it going. Good luck. :)
Apr 12, 2009 | MagLite 3 Cell D Blue Flashlight S3D116
MagLite Mag-Lite& Flashlight Logo
340 people viewed this question
Top MagLite Electrical Supplies Experts
ken skalski
Karl Kittsteiner
ray gallant
Are you a MagLite Electrical Supply Expert? Answer questions, earn points and help others
