Question about Lingo Global Traveler Translator
I just installed new batteries, but unit will not turn on. Unit has not been used for over one year.
    Problem Solver:
  • 16 Answers
Check for any battery leakage in the battery portion if there is any remove the new battery scratch the terminals of the device with any sharp thing and try starting it again
Posted on Aug 30, 2010
Brookstone Boom Bucket BL646 battery won't charge
The battery in these units lasts about 3 years. If your unit is new, be sure the unit is ON (indicated by orange light in front) while being charged. Also, be sure to turn it OFF when not in use or the battery will be depleted (even if not used).
The good news is that the battery is easily replaceable. Removed the 4 phillips head screws from the bottom of the unit. With a little persuasion the bottom will come off, and expose the battery. Pull the battery out until the terminals are exposed and remove the wires attached to them. You can use needle nose pliers to assist if they don't come off easily.
Purchase a replacement battery online or at your nearest batteries plus store, install and continue to enjoy your boombucket.
The battery is 12V 3.3AH/20HR Lead acid type.
May 29, 2012 | Computers & Internet
Belkin F6C1500-TW-RK discharged new batteries, won't recharge
This sounds like a battery issue...I would have the unit and batteries tested at your nearest batteriesplus store... www.batteriesplus.com
May 07, 2010 | Belkin (F6C1500-TW-RK) (F6C1500TWRK) UPS...
Batteries only last 8-9 weeks even when unit is on hold and not used. Battery indicator shows no bars. I pull the batteries and checked them with a battery tester they test not "good" but "oK". I'v had the...
You should always remove the batteries if the unit will not be used for the next 24 hrs.Placing the unit in the hold position merely prevents the unit from doing anything except for keeping it in the mode its in while in the hold position.this is handy to keep it from being accidently turned off or stopped.the recorder maintains data such as time and date through an internal clock.this clock must be powered or you would loose your time and date and other settings.
Mar 25, 2010 | Sony ICD-B5 Digital Voice Recorder
Havent used my ti-inspire since last school year.wont turn on
Here is what the TI knowledge base says about a calculator failing to turn on
For the TI-Nspire™ Family:
  1. Remove thekeypad (for TI-Nspire) or the battery door (for TI-Nspire CAS) andremove at least 1 battery from each column of batteries. After 2-5seconds, reinsert the batteries and turn the unit on. This will causethe unit to reboot the operating system.
  2. Remove the keypad(for TI-Nspire) or the battery door (for TI-Nspire CAS) and remove atleast 1 battery from each column of batteries. After 2-5 seconds,reinsert the batteries and LEAVE THE UNIT OFF (do not turn on and thenback off). Hold down [Home] [Enter] [P], and while holdingthese keys, press [On]. The device will boot up as in the previousreset, but will display a menu with the following options. Please tryoptions 1, 2, 3, and 4 in that order. ** The [Home] key is located atthe top right of the TI-Nspire keypad and has a picture of a house onit.
Note:TI-Nspire family model options 2 and 4 above require that the OS be installed. The reset menu will only display if the unit is off and batteries have been removed/replaced as described above.
1. Cancel - The most non-intrusive reset option; no changes are made, the unit restarts.
2. Delete Operating System – The operating system will be deleted without deleting any documents.
3. Delete Document Folder Contents – This will delete the user’s documents, but will not delete the OS.
4. Complete Format – This will delete the OS and all documents for a total erase of memory.
Hope it helps you solve the problem.
Aug 30, 2009 | Texas Instruments TI-Nspire Graphic...
Franklin BIB-1450 cannot turn on.
Turns out the batteries that I tried were dead. Bought new batteries and installed them. The Franklin BIB-1450 now works. Yay!
Jul 31, 2009 | Franklin BIB-1450
CP685AVR/BF685 Power Contro.
It is likely the battery. These batteries are designed to last 3-6 years in a UPS. The good news is that if it is the battery, it is completely user replaceable and you'll have a Cyber Power unit that works just like new with a new battery. What may have happened is that the battery was weak, and you may have had a slight dip in the AC power. This caused the Cyberpower unit to switch over to the weak battery which couldn't handle the load. The unit then turned off. When you press the "ON" button, the unit will go through a self-test that checks all of the components and the unit will not turn on and be functional unless all of the components come back with a PASS, including the battery. If possible, test the battery with a voltmeter, it should read around 13.5, but not lower than 11.5v DC. However, with the unit over 3 years old, it almost certainly the battery. Here's a link to a replacement battery for the CP685AVR: http://www.batteryinternational.com/cyber-power-cp685avr-ups-battery-ups-batteries-f1.html
Hope this helps.
Jun 28, 2009 | CyberPower (CP685AVR) UPS System
Don't know how to recharge the batteries while they are installed in the radio.
Had to repeat depressing the 'Reset' button at least 4 times before the set would come on. This may have been due to fact that the unit had not been used in almost a year. Also found that the set was shutting down when the status of the battery charge was checked. This was most likely caused by two defective batteries. Put in a new set of 4 rechargeable batteries and unit is now working fine.
May 19, 2009 | Kaito KA1103 SW/FM/AM Radio
Unit is switching to battery power for now reason.
Any UPS monitors the incoming AC level to determine if it is needed or not.  I think the APC unit doesn't know any more when it is needed; it's sick.
Sep 23, 2008 | NEC APC Smart-UPS 1400 (050-01803-000) UPS...
Lingo Global Traveler Translator Logo
152 people viewed this question
Top Lingo Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
k24674
Shehu Pro
Shehu Pro
Are you a Lingo Office Equipment and Supply Expert? Answer questions, earn points and help others
