Question about Dell (E210882) Motherboard
Replaced system hard drive with older drive that had OS loaded. I booted sys and changed passwords. System asks for system pw upon boot but does nor accept pw. I cannot access system.
  • Dell Master
  • 27,725 Answers
Press either delete or f2 during the boot up process to enter BIOS you can change or remove your password from there
good luck
Posted on Aug 30, 2010
How do i change the boot sequence to my OS hard drive only
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your hard drive)
hope this helps
Aug 24, 2011 | Asrock M3A770DE ATX AM3 AMD770 DDR3...
My operating sys. was shoeing that some files were found and seen as corrupt or bad and advised me to back up my important files. I then downloaded the Windows 7 Starter Iso and burned the media disk. I...
To reset the BIOS password: You can sometimes remove and then replace the CMOS battery, other times this may not work.
The CD not booting: Did you burn the CD as an ISO (image file cd) or just a regular data CD? My guess is that is was not burned as an ISO which it needs to be to boot.
Mar 02, 2011 | Acer Computers & Internet
How to test a hard drive to check controller cannot load or format mine or from cd and do not have boot disk can you help
What is ur OS and board? Upon starting click on "del" to go to BiOS and go "BOOT" sequence, choose CD ROM as ur 1st boot sequence! Exit w/ save changes! Now ur ready to install a new Windows OS, insert a OS cd and re start ur desktop! upon starting "START CD ROM" click on "enter"! Let ur windows do everything and follow the instructions!
Taaa!
Nov 08, 2010 | Computers & Internet
I have a gateway 400 VTX that powers on to the Bios screen then goes to another screen that says operating system not found. I have tried to load the os cd and it looks like its loadind and says windows is...
Sounds like u need to go into CMOS (System Setup) upon boot & make sure that the HARD DRIVE is the FIRST item in the BOOT ORDER and NOT your CD DRIVE. Also, make sure your Hard Drive shows up in the CMOS. If it does, then note what it says about the hard drive as it boots... If it is a bad hard drive, then nothing will install to it unless it is fixed or replaced.
Sep 22, 2010 | Gateway 400VTX-3501335 Notebook
Boot system error, insert boot disk..
If you are using windows,System files(boot.ini, config.sys, autoexec.bat, msdos.sys, io.sys) might have lost or corrupted accidentally. You can fix it easily by connecting your hard disk to any other system having windows. boot from the host computer's operating system. open my computer, select folder options from tools menu. select second tab (view) scroll down to uncheck "hide protected operating system files (recommended)" and click ok. now go to C drive. Now you can see the system files mentioned above. copy all the required files to your hard disks partition's root and shutdown. now take out your hard disk and connect to your computer and re-start.
another method is to make a bootable pendrive (visit: http://www.esnips.com/doc/0882f54e-3445-41b6-830d-e43fd7d02dc2/Active+Password+Changer+-+Boot+Disk+Creator
to download application to make bootable pendrive.) copy all the system files from another computer. boot your system using this pendrive and select option 3 to exit from the menu to prompt. copy all the files to your OS partition and now reboot. this will solve your problem (you may need to change bios setting to boot from usb). for further details you can contact av_balajee@yahoo.com
Mar 01, 2010 | Compaq Presario SR1810NX Sempron 3200+ 1.8...
I have a staellite pro a200 and its asking for hdd1 password . and i need some help on this or the password if possibal. thank you r.s.hussain
Is this before or after your OS boots up? PW crackers such as OPHcrack will give you most or all OS passwords; BIOS-set passwords can be reset with boot-level tools on external media as long as the machine will boot from them or you can reset the BIOS to boot from them- if I remember, you can password the HDD in the BIOS independently of the BIOS PW protection. If you cannot access the BIOS, you'll have to open the case, remove the motherboard battery, and possibly manually reset on the MB.
Aug 12, 2009 | Computers & Internet
At start no operating system found
By your description either the drive has died or somehow the BIOS has been changed to not be able to see the drive. Can you run setup on startup to get into the BIOS? From there you should be able to see if the BIOS is detecting the drive. Mose BIOS setups have a selection to automatically detect the drive. I would try that.
Mar 15, 2009 | Compaq Presario 1800T Notebook
System become hang when operating sys. is load. and if load then after few day it says boot failure and hdd. detect but not support what is the problem in my system. i already change my hdd. and ram but...
Make sure you have your hard drive selection on cable select on the back of you hard drive. Also did you change the ribbon cable when you changed hard drives?
Mar 12, 2009 | Asrock P4I45GV R5 Motherboard
Dell d600 video problem
Forget the non-sense.
  1. Remove the battery
  2. Open the RTC Battery compartment
  3. unplug the RTC battery
  4. Press the power button to dissipate stray voltage
  5. Re-install RTC battery and cover
  6. re-install main battery
  7. Re-boot and enter set-up to change date time etc.
Apr 17, 2008 | Dell Latitude D600 Notebook
Dell (E210882) Motherboard Logo
46 people viewed this question
Alun Cox
