Question about NewSoft Presto! PageManager 6.0 for PC
Cannot install Pagemanager 6 in Windows 7 - NewSoft Presto! PageManager 6.0 for PC
I tried installing presto page manager 7.15. Its taking lot of time to install,so i manually stopped it by ending the process. but in control panel in "add or remove programs" it is present. i...
Go to the directory that it is located in and manually delete everything in that directory. Then if you have something like CCleaner, you can use the registry cleaner to remove all the registry entries.
May 14, 2017 | NewSoft Presto! PageManager 6.0 for PC
Tip
Run your Windows xp Software on Windows 7 and Vista
Are your software not compatible with Windows 7 and Windows Vista?
Do you need to install driver from Windows XP to Windows 7 and Vista?
Here is how you do it. ^^
This is just a simple trick to show you how to run your installers and software to your Windows 7 and Vista.
Steps to run incompatible application to Windows 7 and Vista:
729dcf7.jpg.
1. Go to the installer/installed application
2. Right click the .exe and click properties
3. Click the Compatibility tab
4. Check the Ru n this program in compatibility mode for:
5. Choose the Operating System you like (most probably it will by Windows XP)
6. And try running the software again.
on Jan 24, 2010 | Computers & Internet
Photoshop Elements 6 won't open in Windows 7.
chek for compatability with windows 7.or you could try installing under administrators rights.that might do it failing these you could have a corrupted program try re-installing the whole program.
Aug 22, 2010 | Adobe Photoshop Elements 6: Windows
How can i install visual basic 6 on the windows 7
please get the new version of the visual studio ... the visual studio 6 is not compatible with windows 7
Jul 02, 2010 | Microsoft Mlf Visual Studio Enterprise...
Install photoshop elements 6 for windows 7, it does not open at all after installation.
You have to wait for the information about the compatibility of the Adobe Photoshop Elements 6 and Adobe Photoshop Elements 7. You can upgrade to Adobe Photoshop 8 which is completely compatible with Windows 7. You can check the compatibility here. Check event viewer for the error message, for this click on start menu type Event Viewer and press Enter. It would be better to check with Adobe for what operating systems that Photoshop Element 6 would be supported. However you can try installing Adobe Photoshop Element 6 in a fresh installed Windows 7.
I hope this helps.
Apr 21, 2010 | Adobe Photoshop Elements 6: Windows
After installed the Window 7, MF4360dn scanner is not working!
Hi there
Not work you need to find the windows 7 printer driver for it and it could be a job trying to find one as they are still selling there printers with xp drivers only, sorry.
Feb 21, 2010 | Canon ImageCLASS MF4370dn Laser All-in-One...
Presto pagemanager-error-unable to create named pipe code 123
I have the same problem. I think that Genius it doesn't have the new drivers for Windows 7.
Jan 16, 2010 | Office Equipment & Supplies
SCANNING WITH A BROTHER DCP 7020
I cant find the machine DCP-7020 but I think this machine is the same with model MFC-7420 if you have the installer CD follow these steps:
For USB Interface Cable Users
For Mac OS® 9.1 to 9.2
& Software
1 Turn off and unplug the MFC from the AC outlet and disconnect it from your Macintosh, if you already connected an interface cable.
2 Turn on your Macintosh.
3 Insert the supplied CD-ROM for Macintosh into your CD-ROM drive.
4 Double-click the Start Here OS 9.1-9.2 icon to install the printer and scanner drivers. If
the language screen appears, select your language.
5 Click MFL-Pro Suite to install.
6 Follow the on-screen instructions, and restart your Macintosh.
7 Connect the USB interface cable to your Macintosh, and then connect it to the MFC.
DO NOT connect the MFC to a USB
port on a keyboard or a nonpowered
USB hub.
8 Plug in the power cord and turn on the MFC.
9 From the Apple menu, open the Chooser.
10 Click the Brother Laser icon.
On the right side of the Chooser, select the
MFC to which you want to print.
Close the Chooser.
The MFL-Pro Suite, Printer driver and Scanner driver have been installed.
To install Presto! PageManager, click the
11 Presto! PageManager icon and follow the on-screen instructions.
Presto! PageManager has been installed and the installation is now complete.
You can easily scan, share and organize photos and documents using Presto!PageManager.
Dec 11, 2008 | Brother DCP 7010 Multifunction Laser...
How to scan to email
dear customer,
these are some of the ways to do it.. hope its useful..
VistaScan - Scan to Email
VistaScan's direct email link requires either a MAPI (Microsoft Exchange compatible system) or VIM (Lotus cc:Mail system) messaging program - these are commonly used on corporate networks and aren't installed on normal consumer PCs - home and small business users can scan-to-email via PageManager or by attaching images as described below.
VistaScan 3.1 scan-to-email preferences for the commercial MAPI and VIM messaging systems - to reduce the size of file attachments the JPEG file format is recommended.
MAPI programs include Microsoft Outlook 97 and 98 (which can also be used with normal Internet mail accounts) and the latest Netscape Messenger client.
Outlook 98 is a commercial software package (not included with Windows), with support for Internet mail systems, Exchange Server or Lotus cc:Mail messaging servers. outlook98.gif
VistaScan 3.1 application used with Microsoft Outlook 98 - scan-to-email is selected as the destination for the image When VistaScan is used with either a MAPI (Exchange) or VIM (ccMail) mail system it will detect the presence of the software via the Windows registry and automatically launch the client and a new message window, with the single file attached - the message must then be written and sent before the scanner driver can be used again.
Sending images to Email Clients using Presto PageManager 4.0
Presto PageManager is a useful way to capture and archive scans before sending them to another program (eg image editor, word processor) or to print. A few email programs can be linked with PageManager, allowing an image to be "dropped" on a Application Button to automatically open a new message with the scan attached. Microsoft Outlook 98, Netscape Messenger (aka Netscape Mail), Lotus cc:Mail and Eudora Pro 3.0 can all be added as email applications - Outlook Express, Compuserve and AOL cannot be directly linked (these are limitations of the mail programs, not of PageManager!).
pmoutlookbutts.gif comm46butt.gif OutLook Express cannot link with PageManager - a new email won't be opened when selected. PageManager adds an Outlook Express button automatically. Outlook 98 will correctly open a new email and attach the scan(s). PageManager won't setup Outlook 98 automatically, it needs to be Registered as a new application. Netscape Mail will correctly open a new mail with attached scans when selected. The Application Button is setup automatically by PageManager.
Preparing Files for Email Clients
As many Internet email programs do not support Exchange or cc:Mail, the two commercial mail systems integrated with UMAX software, you may have to prepare your scans: the images to be sent need to be saved on your hard disk in a suitable file format, ready to be "attached" to an email.
In general it is better to send as small a file as possible by email, as the image has to be transferred to the Internet over a relatively slow modem link - most users prefer a compressed file format such as JPEG (.jpg). This compresses your scan to a fraction of the original size, although it does slightly reduce the quality of the images.
There are three ways you can save your scans to disk:
1. If you use the VistaScan program (Start, Programs, VistaScan 3.x, VistaScan) you have several choices in the "Scan To" box (Advanced mode).
Click on the Floppy Disk icon - this will then use the settings in the VistaScan preferences:
For emailing scans we recommend the JPEG format - check where the scans will be saved (which directory). File names are created automatically - scan1.jpg, scan2.jpg etc.
2. If you normally scan your images in to PageManager you can export them to your hard disk - right-click on the thumbnail view and choose 'Save As...':
Choose a file location and select the "Save as type" file format.
3. If you are aquiring the VistaScan driver via any other application (eg Adobe PhotoDeluxe) then you should have options to save the images and to change their formats - please refer to the instructions for each application for for further advice.
Attaching images to an Email
All email client programs will allow you to combine file atachments and your text in to a single message for sending - although there are small differences in the way attachments are encoded you normally only need to customise options if sending to someone with an Apple Mac, which supports slightly different graphics file formats. Below are instructions for attaching files in some of the more common email programs:
America OnLine (AOL) (3.0I)
In the Email menu choose Compose Email (Ctrl+E):
At any time while you write and address your email you can click on the Attach icon on the left of the window - this then lets you select the files to be sent.
Compuserve (CIS) (4.0)
In the Compuserve program choose "Create New Mail" from the Mail menu:
During writing and addressing your mail message you can click on the button "Attach File:" - this lets you browse your computer to select the scans to be sent. To make finding the files easier, change the "Files of type" setting to "Graphics Files". Once the files are selected Compuserve shows a second window of encoding options - the default (Binary) will be suitable for almost all emails.
Microsoft Outlook Express
Outlook Express is one of the most common Internet mail clients, and is included with many Windows 98 systems and on ISP disks - this basic mail program also lets you attach files to your emails. Click on the Compose Message button:
While writing your email message you can click on the paper clip icon (shown above) or choose "File Attachment..." from the Insert menu.
Netscape Mail / Netscape Messenger (Communicator 4.6)
The most recent version of Netscape Mail can be linked to PageManager or the VistaScan driver, however many users want to attach scans in the normal way - click the New Msg button to open a Composition window:
While writing your email message click on the Attach button and choose File... - locate and select your scans.
Jul 09, 2008 | HP PSC 1610 All-In-One InkJet Printer
Open Questions:
NewSoft Presto! PageManager 6.0 for PC Logo
125 people viewed this question
Top NewSoft Computers & Internet Experts
David Payne
David Payne
Are you a NewSoft Computer and Internet Expert? Answer questions, earn points and help others
