Question about Kenwood KDC-MP5028 CD Player
How do I bypass the "Enter Code" message on a system that was purchased with the vehicle?
My car was serviced at a repair shop and returned with the "Enter Code" message. The stereo came with the '03 van. I have no code.
  • 1,512 Answers
Hi TANJIASTREAT
I have written a Tip on how to overcome this problem. Checkout here
You do need the remote control to reset the code... If you dont have it, then you may have to go to a Kenwood Authorised service center. They will be able to do it for you. A FixYa rating would be tops for sorting this one out for you :) Cheers
regards
robotek
Posted on May 08, 2008
My 2003 buick century custom has dashboard lights on--how to reset Service Vehicle Soon, Trak light off, Abs light?
You need to have it checked for DTC'S - diagnostic trouble codes to see what the problem is ,then diagnosed , then fixed ! Then the light's will go off ! This means taking it to a qualified repair shop .
SERVICE VEHICLE SOON
The IPC illuminates the SERVICE VEHICLE SOON message in the DIC when the powertrain control module (PCM) detects certain malfunctions that are not related to the emissions system. The IPC receives a class 2 message requesting illumination from the PCM.
Sep 08, 2016 | 2003 Buick Century
Why won't security system let me do anything?
Is the SECURITY light lit on the dash ? If so there is a problem with the anti- theft system . An a code is stored in what ever module controls it . There is a way to by-pass it . go to you tube an search GM VATS , Pass key , pass lock how to bypass .Or you can take it to a Chevy dealer or some other repair shop. Just depends on how much money you want to spend. And if you bypass the system your vehicle won't be protected from theft anymore !
Nov 24, 2015 | 1997 Chevrolet Tahoe
Have gone through a series of repairs on my truck and now have a P0308 code and a check engine light.
Welcome to the club .Obama motors .
I have read your post .The problem is realated directly to fuel deliverery.You had problems with the EVAP system .Misfire on #8 cylinder . The vehicle is olny 2011 but you have a lot of milage for 3 years . I would check the fuel filter first thing a lot of fuel has run through it .The fuel pump could also be an issue however they normaly last 10 years or so but depending on how much winter driveing you do the road salts they now use are much worse then they use to be as far corration check the connecters to the pump.
What I can say is most of these codes you are getting have nothing to do with the problems you are haveing there just side effects of how the VCM .controls information and the air horn had nothing to do with your problem nor did your dome light .The olny other thing could be a problem with the injuction system the regulator or an injector. Try the fuel filter first but it is in the fuel system
Mar 17, 2015 | 2011 Chevrolet Silverado 1500
I have a 2003 Acura MDX touring. I just had the timing belt, water pump, thermostat replaced as a maintenance repair (190K miles). The car was running fine when I took it to the shop for repair. Upon
I have 2 questions
Why would you not check for codes & make the proper
repair within a week of any check light,that is what is required
You say been on awhile,the vehicle had a fault code & system
problem & still does
Why would you have a timing belt & water pump installed &
any repair shop return your vehicle with a check light on
What sort of shop is that to return an undiagnosed vehicle
Neither you nor the shop seen to have any interest in
these check lights Why is that?
Mar 10, 2013 | Cars & Trucks
Replaced ignition switch vehicle will not start appears to be computer code
Is there a computer related code which I must enter via the radio ??? You don't enter anything through the radio !!!!! Having factory service repair info so you can read how the anti-theft system works an a scan tool to pull DTC'S - diagnostic trouble codes is the proper way to diagnose .
The theft deterrent system has been incorporated into the body control module (BCM). The theft deterrent is provided in order to prevent the vehicle operation if the correct key is not used in order to start the vehicle. The ignition key turns the lock cylinder. The cylinder rotation produces an analog voltage code in the Passlock™ sensor. This voltage code is received by the BCM. The BCM compares the voltage code to the previously learned voltage code. If the codes match, a class 2 message is sent from the BCM to the powertrain control module (PCM)/vehicle control module (VCM). The message enables the fuel injectors.
The design of the Passlock™ system is to prevent vehicle theft by disabling the engine unless the ignition lock cylinder rotates properly by engaging the correct ignition key. The system is similar in concept to the PASS-Key® system. However, the Passlock™ system eliminates the need for a key mounted resistor pellet. The components of the Passlock™ system are as follows:
• The ignition lock cylinder
• The ignition switch
• The Passlock™ sensor
• The Body control module (BCM)
• The security telltale
• The vehicle/powertrain control module (VCM/PCM)
Your best bet , take it to a qualified repair shop.
Mar 06, 2018 | 2002 Chevrolet Avalanche
My truck sys service stability system then when i come to a stop or slow down it sys stability system engaged ad shakes ad grinds..its done it twice since ive bought the truck in february..i just want to...
didnt specify vehicle besides truck and caddy --have vehicle scanned for a trouble code most auto stores offer this service for free --next check the abs sensors and hubs of vehicle for damage or wear
Jul 14, 2017 | 2004 Cadillac SRX
1999 Ford explorer i need to bypass lights & beable to drive & or have lights turn off
You don't cut,bypass or modify any vehicle
You diagnose the issues and return it to
factory built specs
I believe you have a module that controls all that
Just take to a repair shop
Mar 28, 2011 | 1999 Ford Explorer
Driving on a rainy day in nyc all of a sudden traction service light foes off traclink service message goes on and engine power reduce foes off and I'm left stuck on a bridge having to be towed off. What...
Living not too far from you,I will tell you, that your vehicle
doesn't care about nyc or the weather
Whenever you get any OBD2 Code , a System you should
study, if you own any vehicle,you retrieve the code,
then using the codes diagnose the system they pertain to
In your case an ABS System Malfunction, as well as, you went into
failsafe,thus your time on the bridge.
Without the vehicle to test,yes test,no one would know if you have one
system or more in trouble.
I would suggest a local repair shop,in my world, never a dealer,too
expensive and too much dog & pony show, for me
Dec 04, 2010 | Chevrolet Avalanche Cars & Trucks
Abs light is on and want to find out why is this a wheel sencer or could it be the abs pump this also turns off my allwheel drive
the abs light is tripped by any computer-recognized problem within the abs system. a wheel sensor tends to be the most common cause of an abs light. while the light is on, the standard brakes function normally but the abs system is completely bypassed. the best way to diagnose this is to plug the vehicle into a code scanner. any decent shop can perform this service, or you can purchase a scanner at an auto parts store or online. if you do go that route, ensure that the scanner you purchase specifically can interpret abs codes
Sep 29, 2009 | 2001 Pontiac Aztek
Message on dash 96 deville service traction control
check the brake fluid and make sure caliber is full of fluid. mine said that and it was because fluid was low.
Jun 02, 2009 | 1996 Cadillac DeVille
Kenwood KDC-MP5028 CD Player Logo
163 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
