Question about Sewing Machines
I have a Kenmore 12 stitch machine. How do I adjust the stitch to be longer?
  • 202 Answers
I beleive your stitch length knob is on the right hand side. The numbers mean stitches per inch. The higher the number the shorter the stitches.
Rick
Posted on Sep 05, 2010
How do I correct stitch length mechanism to produce 6 stitches per inch?
the stitch length is governed by the cam action connected to the walking foot
that means that the stitch length is governed by the amount of material that is pulled through in the period of time that the needle comes up and goes down
normally the cam action is set by the stitch length lever/ reverse lever
if there is a necessity for a longer stitch, the cam would have to be changed on the drive shaft underneath
That will require a discussion with a sewing machine mechanic to determine if there are cams or other linkages that can be fitted to alter the stitch length for the manufactured maximum
Oct 09, 2016 | Sewing Machines
12 wt thread
12 wt thread generally will not work well in the bobbin...
"Aurifil 12wt Thread
Aurifil 12 wt thread is ideal for hand quilting, big stitch hand quilting and machine quilting. 12 weight thread creates a more defined and often primitive look. It's great for designs that use a longer stitch length if using a machine. When machine quilting with 12 wt thread, use 40 wt in the bobbin, increase your stitch length, lower your tension, use Topstitch size 90 needles and stitch slowly."
May 08, 2017 | Bernina Activa 140
Hi i want to buy a sewing machine wich one is best. kenmore or brothers sewing machine
I would prefer Kenmore, enmore makes perhaps the largest selection of mechanical machines. The very cheapest Kenmore sewing machines, like the Kenmore Mini (*est. $100) and Kenmore 15208 (*est. $120), stick with a four-step buttonhole, and have just six and eight stitches, respectively. The Kenmore 15212 (*est. $150) and Kenmore 15218 (*est. $170) both have a one-step buttonhole. The cheaper Kenmore 15212 has 12 stitches. The slightly more expensive model has 18 stitches, including a smocking stitch, overcast and elastic stretch stitch in addition to the basics. Both Kenmore sewing machines are good, basic models, say reviews. Both have just a 90-day warranty, however. Bear in mind that Kenmore sewing machines are made by different Asian companies each year, resulting in varying degrees of quality; this also explains the low prices. Some users report difficulty with tension and light fabrics.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 03, 2010 | Kenmore 19365 Computerized Sewing Machine
I have an old sewing machine in my attic, i just recently put it to use. but i cant seem to find the reverse stitch button. im only 14, it was my moms sewing machine. but shes no longer with us, so im...
I've got a Kenmore sewing machine and the back stitch is a button/lever on the front of the machine. It has to be held down when you want to back stitch, because when you let it go it stitches forward again. Hopefully that helps, I'm not sure what yours looks like. ( I couldn't find pictures of your model online anywhere.) :)
Aug 08, 2010 | Kenmore 15358
Stays in one place and won't move kenmore 12102
Make sure the stitch is set to a sewing stitch, (not a buttonhole stitch).
Set the stitch length dial to a longer stitch.
Make sure you have you feed dogs set to the "up" position.
Apr 06, 2010 | Kenmore 12102
I have an old kenmore 12 stitch sewing machine that the needle sometimes looks like it wants to more and other times it just sits there. the shaft that runs across the inside under the top cover will not...
Sounds like your machine is in need of a good cleaning and oiling. If you aren't handy with taking apart things and getting them back together I suggest taking it to a sewing machine repair place. In the meantime you can try oiling any spots you can access. Use sewing machine oil, found at any sewing/fabric store and even most Wal-Marts.
Nov 23, 2009 | Kenmore Sewing Machines
Stitching is too loose
hi! this particular problem is common when tension and stiches adjustment does not match and complied to fabrics your trying to sew,there a is hard way to find manual specialy to old ones. but if you want it may help you some i got here on manual sears 1803.if your control look similar to this in figure5180e2c.jpg there are stitch control one for straight stitching and one
on special stitching.the small dial near needle is tension dial.You can set tension on # 3 to 5
stitch dial as in figure7a4913a.jpgif you are
sewing a straight stiches set to # 8 to 12 trial are needed somtimes to acquired smooth sewing,Be sure no mechanical problem regarding in machine operation.try to sew a cotton fabric for trial then if sewing another fabrics sudden adjustment should be done.If your machine is equipted by auto tension just select on the fabrics.well small information can sometime helpfull ...nice sewing
Mar 18, 2009 | Kenmore Sewing Machines
Top thread tension tight
March 12, 2009
kenmore 385.17922
i have started using my machine again (after several years) and am doing patchwork.. all has been fine, and suddenly the bottom thread (bobbin) is looping. i've adjusted the tension nob from 4 (where i had it) to 5...back to 4.. 41/2....3 1/2....5 1/2... on and on and the bottom thread still keeps looping.
i've read and re-read the manual...and the only suggestion it gives is to adjust the tension button.
it's not working...... what else can i try??
thanks
eva
Mar 11, 2009 | Kenmore Sewing Machines
Kenmore 14 stitch machine
Adjust the width selector to zero
Mar 16, 2008 | Sewing Machines
Sewing Machines Logo
64 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
