Question about Apple iPhone Smartphone
IPhone Freeze - Panic: We are hanging here
My iphone has frozen in the boot script, showing the message Panic: We are hanging here.
It is possible to identify it is a Kernel problem.
Do you think is it possible to fix? Any suggestion?
  • 1 more comment
  • bis3946 Dec 25, 2008
    dosent work form me
  • snvu6 Jan 08, 2009
    i have same roblem not work my phone
    thanks
    son vu
  • patje_ko Mar 02, 2009
    I can restore my iphone any more, when I try instalkl the new firmware version, itunes gives me a error 14. And somtimes iPhone gives me a panic kernel screen with: we are hanging here...
    Please help me!
    Patryk
    Novelist:
  • 144 Answers
Hello!
try this simple steps to recover your iphone:
-- Turn off your iPhone by holding the "Sleep/Wake" button for about five seconds and then sliding the red slider.
-- If your iPhone is already off, there's no need to turn it on and then off again.
-- Once it's turned off, press and hold the "Home" button and plug the iPhone into your Mac or PC.
-- Keep holding the "Home" button until you see a yellow triangle and text which says "Please Connect to iTunes".
-- New iPhones will show a dock cable next to the iTunes icon.
-- You can now release the button.
-- Open iTunes (if it's not already open) and you will be told that "iTunes has detected an iPhone in recovery mode".
-- Click "OK" and you will be taken to the iPhone pane. --
-- Click restore and you're done.
Depending on the extent of your iPhone's ills, it may take some time to do a full restore. Once you're done, however, you should again have a perfectly working iPhone.
Posted on May 08, 2008
  • 1 more comment
  • pnutz84 Apr 30, 2011
    That doesn't fix the problem, I have put my iPhone into DFU mode and restored many times but after a while the phone crashes and once in a while the debug message shows up when trying to restart
  • sheridan_634
    sheridan_634 May 09, 2012
    My phone is doinh the same thing & it is driving me crazy. Whats the solution?
  • kishoresvk
    kishoresvk Feb 20, 2013
    cant Activate my Iphone after process
Plug it into you computer (or any other power source) then hold HOME and SLEEP it should restart, problem solved, however this issue may arise again, simply repeat the process, this worked for my iphone at least
Posted on Mar 05, 2012
  • 4 Answers
Ok guys i have taken my iphone to service and what thay did was gives me a brand new iphone... this problem cant be solved!!
Posted on Jul 14, 2009
  • Jeffrey Velasco Mar 02, 2011
    is your iphone still in warranty??
    Problem Solver:
  • 6 Answers
Hi mi name is Oscar from Guatemala I have the same problem with my iPhone want to know if has solution please help me!
Posted on Jun 17, 2008
My iPhone 4 can't boot (Kernel panic). I replaced the dock cable because the iPhone didn't charge. Could this be a hardware problem?
Usually software but hardware failure can also cause it.
Outlined in the User Guide are restart, reset, restore from backup, restore as new device. If none of these work you will need to have it serviced.
If it was hardware, it's mostly unfixable and hopefully it's under warranty.
I doubt replacing the dock cable caused a kernal.
Apr 12, 2013 | Cell Phones
I phone 3 freeze just showing apple
It sounds like you are stuck on boot. Hold down the power/lock button and home button together until the phone turns off and the apple logo appears again. Your phone should boot up normally.
Feb 13, 2013 | Apple iPhone 3G
Screen frozen
Try a hard reset first. (menu and on/off button together for 5sec) if it boots again, but then doesn't repspond touch sensor screen needs replacement. Take it to the apple store and see if they'll give you a replacement. If they don't there are third party iPhone Repair Services that can fix it for you. There are also free iPhone Repair guide that show you how to fix it yourself.
May 15, 2010 | Apple iPhone Smartphone
My new 3gs iPhone does not keep text messages. If I go to another function and go back to Msgs everything is gone.
i think you should try to restore your os again, its possible some scripting has not setup/install properly or have been disordered, solution for this i would recommend restore.
Jul 03, 2009 | Apple iPhone 3G
Is it possible to take out battery of iphone 3g? phone hang up
actually there is no batttery on the iphone to remove. The battery is hard wired to the phone board itself. However if you hold down the home key AND the power key down at the same time for about 15 seconds it resets your phone as if you removed and reinserted the battery.
May 02, 2009 | Apple iPhone Smartphone
Error 1604 and Kernel Panic
confirm that your firmware is compatable with your iphone.
if you have a 2G the firmware should start with 1.1 if you have a 3G the firmware should start with 1.2
apparently unlocked or jailbroken phones with the wrong firmware will brick in this manner.
not to worry, your not the only one.
do a web search for error 1604 and you will see solutions such as this below.
  • Problem: I cant restore my custom firmware. I just get error 6, 1, 2, (something low).
    Solution: This has multiple causes. Generally, you are not in DFU mode. See DFU guide. Winpwn solution after ruling out the above: Delete the device file (x12220000_4_Recovery.ipsw) in your iTunes folder. (Search for the file). This can also be caused by using the incorrect firmware image (a 3g on a 2g for example).
  • Problem: I am in DFU mode and I just get error 1604, 1602, 1601 (some 160x). I am pulling my hair out! What do I do?!
    Solution: This one sucks. There’s no single answer for it. Here are some possible suggestions:
    • Validate you are using the correct firmware. You can get this if you are using an incompatible firmware (3g for 2g for example).
    • Restart your computer and try again.
    • Try another computer
    • Try switching USB ports
    • Uninstall and reinstall iTunes 7.7
If you are not able to get out of DFU mode even after trying one of the above fixes, click here to follow the comments on BigBoss’s website.
Apr 17, 2009 | Apple iPhone 3G Black Smartphone
IPhone 2G hangs at "slide to unlock" - restore not helping
2g solution
3g solution
if it still gives you problems then you have a hardware issue, apple won't touch a jailbroken iphone so hopfully you have the apple care protection. Restore it to factory settings and try to take it in for service.
Feb 04, 2009 | Apple iPhone Smartphone
Iphone Frozen in Boot Screen
hello again!
try to restore option first on your iphone.
step 1: Make sure you have an Internet connection and have installed iTunes 7.4 or later from www.apple.com/itunes. .
Step 2: Connect iPhone or iPod touch to your computer.
Step 3: In iTunes, select iPhone or iPod touch in the Source pane and click the Summary tab.
Step 4: Click "Check for Update." iTunes will tell you if there's a newer version of the iPhone or iPod touch software available.
Step 5: Click Update to install the latest version of the software. Or click Restore to restore iPhone or iPod touch to its original settings (this erases all data on iPhone or iPod touch). Follow the onscreen instructions to complete the restore process.
May 08, 2008 | Apple iPhone Smartphone
Booting on iphone
Hey there, I would try getting the phone in bootloader/diagnostic mode ( the yellow triangle screen) and then use iBricker to boot the phone.. u may want to try it on a different pc if you can..
Hope it helps
Z33m
Dec 06, 2007 | Apple iPhone Smartphone
Iphone frozen
Hi there, i need more information, like define frozen? doesnt turn on? its on but doesnt respond? etc..
Z33m
Oct 27, 2007 | Apple iPhone Smartphone
Apple iPhone Smartphone Logo
24,414 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
David
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
