Question about Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker
I have had 3 ice makers installed in my fridge all have gone out unsure what to do to fix this problem if the icemaker just needs replaced or if there is something else causing my ice maker not to work
  • 1,531 Answers
There may be a short in the wiring somewhere causing the ice maker to malfunction.I would try one more ice maker kit and replace all the components of the ice maker.
then have all the wiring checked.
Posted on Aug 29, 2010
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Tip
    How to install/replace Icemaker in top bottom fridge
    Start by unplugging fridge. Take 1/4 inch nut drive ( sometimes phillips ) remove bottom screw from under ice maker. Next loosen top to screws mostly out. The screws are located in brackets near the ice tray behind the front cover. Ice maker has brakets that the top screws slide into. Lift the icemaker up and out off the screws. Next disconnect the quick connect that is on the back wall of the freezer. Some models are hard wired into the icebox. If this is like yours than disconnect the quick connect from the icemaker itself. Take icemaker out of freezer and connect quick connect into or from new ice maker. Slide the new icemaker onto screws and into place. Screw bottom screw in and than tighten the top two screws. Place ice maker arm down so it can make ice. Give it 24 hours to cycle before it starts producing ice. Most of the time icemaker starts making ice within a couple hours. Plug in fridge.
    on Aug 01, 2011 | Refrigerators
    Ice maker makes knocking noice
    It would depend on the model of your fridge. Most fridges, you would just need to change the icemaker, but if it is a whirlpool or kitchenaid, you can just replace the module on the front of the icemaker (part number 8201515)
    May 19, 2012 | Electrolux Refrigerators
    Ice maker installation
    do you have a water supply line connected to the refrigerator? if so, it connects to the water solenoid, so you wont need to install that. if you have no water line, not only do you need to install that, but you will also have to check to see if you also need to install the solenoid assembly. if no solenoid is present, you will likely also have to run a plastic water line, ¼", from the solenoid up the back wall into the sleeve near the top of the back wall, which feeds the water into the freezer, into the icemaker.
    if you want to send a check, id be glad to post a video
    Mar 01, 2010 | Amana ABB1927DE Bottom Freezer...
    Ice maker issues - what to do next?
    I have not found Kenmore to do the best with the icemakers; however, you want to make sure that the lever on the side was replaced properly. They have a slot that they need to go into. The other thing that is important is to see if the motor is running on the ice maker. It could be at fault, but if that is the case those units usually are better off replaced as a whole, which runs around $200. You will probably get them cheaper through an appliance dealor rather than going through Sears and there probably is one in your yellow page section of your phone book...hope this helps.
    Oct 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    ICE MAKER QUIT MAKING ICE ON MY WHIRLPOOL FRIDGE
    I had a Whirlpool Model GD5SHAXNS in which the icemaker quit working about the same time (3 years old). I had water out the dispenser, I found that it was the icemaker itself failed not calling for water to fill it. I replaced it with a icemaker on-line for about $100 and problem fixed. I have been told his is a common problem with the icemaker in this model ref.
    Mar 26, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
    11 year old amana bottom freezer icemaker drips water when filling tray
    Hello dunc444444
    Welcome,
    You said, Bottom freezer works fine, but upper refrigerator has no cold air
    Is your freezer so full that it is packed to the top especially in the rear?
    Refrigerators and freezers share the air from the compressor and travel through vents in the rear of the freezer and fridge.
    Sometimes it can effect the cooling in the fridge if the freezer articles block the vents!
    The water overfilling in the ice maker is an ice maker problem only.
    When we install an ice maker there is a short white plastic tube that we push through the rear
    hole of the fridge which supply's the water to the maker, the outside water line attaches to this.
    That tube we push through the fridge must go in till it stops. And empties in to a little sistran at the rear of the ice maker. Make sure it did not sip out or backwards a little when you may have moved
    rolled the fridge out to clean under it!
    Also you need periodically to remove the front grill down in front of the fridge and gently run a refrigerator brush under the coils to clean out the dust that may block air flow over the coils.(the coils are metal black tubes that run back and forth along the bottom of your fridge.
    The vacuum will not reach in to that tight space. That's why they make a special brush for this chore.
    Let me know how you do?
    Huuum {
    Let me know.
    Huuum
    Please remember to leave a rating.
    Oct 05, 2008 | Amana ARB9059CS Bottom Freezer...
    Whirlpool fridge model WF-NL300 ice maker not working. No water in icemaker. Black water supply tube that fills icemaker was frozed solid with ice. I thawed it in a cup of hot water. Unsure if line could...
    Turn ice maker off for 24 hours to thaw out any additional frozen lines.
    Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
    Feb 29, 2008 | Refrigerators
    Amana ice-maker
    Very curious. When you say the tube to the ice maker was disconnected I am unsure as to which tube you are refering to. However hopefully a few pointers might help a damsel. Most units have the water supply enter into the cabinet through a two way water solenoid valve (i.e. one for chilled water one for the ice maker). It then normally enters the top of the freezer section for the ice maker. It then drops down inside the freezer section to the icemaker module. Therefore the only control over the water for the icemaker is the solenoid valve which is controlled by the icemaker "module". A trick is to switch the control at the solenoid valve so that you can use the chilled water dispenser to check if the water valve for the icemaker is working. If it is then you probably have a problem with the icemaker module or the temperature in the freezer section (which you would probably have noticed if that was the case). If you have a problem with the module then you normally have to replace the module as they dont like supplying spares for modules.
    Anyway hope this is of some help and good luck.
    ps model is normally near the salad drawer or top of the fridge section dependent on brand.
    Feb 08, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
    Icemaker stopped giving ice
    The best way to fix this is to replace the ice maker ($50-$95 Bucks).. Unless you have a really fancy set up where the "ice bucket" is located in the door of the freezer.(if so get back with me and I will advise futher... Goodluck!
    Dec 20, 2007 | Refrigerators
    Frigidaire 20.6 cu. ft. Top Freezer Refrigerator with Factory Installed Ice Maker Logo
    80 people viewed this question
    Top Frigidaire Refrigerators Experts
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Steve
    Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
