Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
GE Harmony gas dryer wont heat
Sometimes it works, other times not.It seems that the gas heating is not igniting. Any help or information would be greatly appreciated.
  • 770 Answers
Post your email i will send you the servuice manual on it
Posted on May 08, 2008
I have a GE profile Harmony gas dryer model #DPGT750GC1PL. the dryer runs but there is no heat or air coming out of the vent. diagnostics do not indicate anything wrong
see this causes and fix it. God bless you
There's no heat dot_lineone.gif 1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Oct 02, 2012 | GE Profile Harmony DPGT750GC Gas Dryer
My GE dryer only heats up sometimes
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 17, 2010 | GE Profile Harmony DPGT750EC Electric...
My dryer heats sometimes and sometimes it dont. Can anyone solve this.
heatman101
Oct 17, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
G.E. Profile Harmony Dryer heats then won't heat
heatman101
Oct 10, 2010 | GE Profile Harmony DPGT750EC Electric...
My GE Harmony dryer has stopped heating. All of the cycles work (air comes out), it just wont get hot.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 17, 2010 | GE Profile Harmony DPGT750EC Electric...
No heat when dryer is turned on. Could it be ignition coil?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 13, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
The dryer tumbles however there is no heat. I have checked the venting, the gas line and the internal vent...also the settings. When I remove the rear venting hose, I smell gas. Led to believe that the...
heatman101
Jun 17, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
GE Profile gas dryer tumbles but NO HEAT, not ignitor
heatman101
Apr 30, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
GE Harmony no heat, gas isnt turning on when ignitor glows on
Not the gas valve. the flame is not getting lit.
The electronic ignition is not heating up.
Do you notice the igniter is no longer glowing?
It must be replaced.
Sep 25, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
DPGT750GCPL heat issue
What do you mean by "215 or 20 seconds"?
May 11, 2017 | GE Profile Harmony DPGT750GC Gas Dryer
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
81 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
