Question about Carrier 38BRC048 Air Conditioner
NO COOLING I HAVE A LESS THAN 2 YEARS OLD AIR CONDITIONING (MODEL#FA4BNF036) THAT HAS STOPPED COOLING. I SEE NO LEAK AND HAS BRAND NEW FILTER. IT'S A SINGLE UNIT FOR CONDOMINIUMS. i THINK THAT THERE SHOULD BE A WARRANTY STILL, BUT TO GET TO SERVICE IS BEING A PAIN. CAN ANYONE PLS GIVE ME AN IDEA HOW TO GET IT WORKING AGAIN? tHANK YOU
  • CAAAPEREIRA May 08, 2008
    Yes, I can hear the fans running, but I will have to open the panels to verify everything else. The thermostat shows cools and I have programmed it for the temperature to hit 70F. But the temperature does not go below 79F. Does these kind air conditioning have internal fuse? My apartment lights blinked yesterday and I notice that after that the air conditioning stopped working properly. I pressed the "Reset" button on the digital Thermostat which displays "cooling" but it acutally does not! Thanks for the fast post
If you feel the fan running specially the fan thats outside,that means the thermostat is sending the signal for cooling, if your compressor fails, what it will do it will get very hot!!! to the point that it will shut its self off, for safety, (Internal overload)my recomendation is, turn the power off, take one panel off, and touch the top of the compressor, that will tell you if has try to start or not. if its hot, leave it off for a day, then go back and turn the power on, it will try to start.
Posted on May 14, 2008
    Problem Solver:
  • 7 Answers
Hmm.this will require a few questions for you to answer. first does all the fans run, condenser fan??? indoor blower? and does the compressor humms, when you turn it on?
Posted on May 08, 2008
Brand New 2 weeks old 4 ton Trane compressor leaks a lot of water onto pad
If the unit is running in cold weather than there is ice building up on the coils located outside. This is normal in that the unit is running in heat pump mode heating inside and cooling outside, After the unit detects the ice build up it briefly reverses the cycle heating the outside coils melting(defrosting) the ice which you observe as water on the pad.
The video gives you an example of the defrost cycle!
2012 Trane XL15i Heat Pump Defrost Cycle Steam Show
Dec 21, 2015 | Heating & Cooling
Our American Standard Allegiance 13 A/C is less than 2 years old and we are getting cool air from our ducts but not cold air. What can be done to fix this?
it sounds like (1) your air filter needs to be replaced or cleaned, (2) your a/c system has a small leak that needs to be repaired by a certified a/c tech
Jul 21, 2011 | American Standard Heating & Cooling
My air condition blocks some ice in the system, causing not enough cool provide.
Water leak /Icing in your evaporator is the common problem in split airconditioners.. It happens due to:
1. Air filter block 2. Evaporator coil Block. 3. Less rpm of blower motor. 4.Drain line blocked.
To rectify, service the unit completely. If blower motor less rpm, replacemotor capacitor.
Dec 18, 2010 | Heating & Cooling
How to determine evaporator icing problem of air conditioning units
Due to :
1.. Evaparator coil dust blocked. 2. Air filter blocked. 3. Less rpm of fan motor. 4. Short of gas. 5.Filter drier chocked 6. Compressor less pumping.
To rectify:
1 & 2.Clean air filter and evaporator. 3. Replace fan capacitor. 4.Check for gas leak and recharge. 5. Replace new filter drier, vacumize and gas charge.
Dec 16, 2010 | Heating & Cooling
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Water leaks into cabinet fron filter
You need a new filter housing to stop this from happening. You can repair this yourself and save a ton of money!!
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 7 PM CST with your brand and model number and we will get the correct part out to you asap. We also provide part removal/installation instructions for you when you get your parts through us.
We hope to hear from you soon and we hope you have a terrific New Year! Thanks, Ella
Jan 08, 2010 | Refrigerators
Noisy unit, not cooling well, water drip from air intake
First please check the air filter and clean it and refix it.
Please check the refrigerent level next if it continues. Refrigerent leak will result in poor cooling and enhance the noise level.
The compressor could be defective and might take high power to run and only replacement of the compressor could improve the working condition.
In case the unit is more than 5 years old it is wise to replace it with a new unit and save your power bill.
Jul 06, 2009 | Dometic Heating & Cooling
No cool air and oil in one of the drain lines
I would say that you have a refrigerant leak. The oil was pulled out of the compressor and leaked out with the refrigerant.
Jan 17, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Help!! No cooling, just fan!!!
sounds like the unit is low on charge.you will need a pro to check it
Aug 04, 2008 | Heating & Cooling
you probably have a defective contactor or start capacitor on condensing unit. if you pretty handy with wiring go to the condensing section open the panel. you should see a contactor (it's the little black piece with all the wires) check the condition of it. next to it is a capacitor and by the problem that you describe it could be that. check it if it looks bloated there's your problem just go an get an combination capacitor and wire up. (make sure the power to unit is off first. any other questions email me @ hvac.tech7872pr@gmail.com
May 09, 2008 | Carrier 38BRC048 Air Conditioner
Carrier 38BRC048 Air Conditioner Logo
190 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
