Question about HP DesignJet 1050c InkJet Printer
Hi , I really need your help please.
I had really loud noise from the axis motor , I replace the belt and also the trailing cable but I still have the noise.. when Im turning the printr on th carriage try to run to the left side real fast.
Im not sure what to do, do you have any idea ? BTW I aplly oil also...
  • HP Expert
  • 141 Answers
Main pca in electronics module is defective.
must replace
Posted on Sep 09, 2008
System error 0B000D 00000005
Hi, I believe this error occurs when there is no 24 volt supply to the PCB. Go back and check you have plugged all the connectors back in correctly.
Sep 29, 2014 | HP DesignJet 1050c plus InkJet Printer
HP DesignJet 1050c plus InkJet Printer hangs up on axis test and ink droptest also paper axis test
Take print out of configure page, check the usage of paper axis, spit on,carriage,service station, and others includes FW.. identify which was crossed beyond 100%,replace them..update FW..confirm once be fore replacing the spares...
Oct 05, 2011 | HP DesignJet 1050c plus InkJet Printer
When spinning making a loud noise
you can check the damage on axis bearing Bosch, exactly is behind close to the fan belt pulley. You have to replace it.
Jul 26, 2010 | LG WM-1480FHD Front Load Washer
Error-check printhead path 2
After plot one ploter going to print head check mode on dsj 1050.
May 17, 2010 | HP DesignJet 1050c plus InkJet Printer
Makes a loud noise like a grinding noise then smokes comes out and it smells like burning rubber? When I take the (rod) brush off with the belt then run the vacuum there is no more noise? Please help me...
Your belt is worn and stretched and so it is slipping on the motor drive shaft. That is why it is noisy and smells like burning rubber. You simply need to replace the belt. You can get replacement belts here:
Replacement Vacuum Belts
Nov 30, 2009 | Vacuums
Error code showing on my HP 1050c plotter
The error stands for : 24V source test failure.
And i'm sorry to say but the service manual then tells you to try the following:
- Replace the scan-axis motor assembly.
- Replace the paper-axis motor assembly.
- Replace the service station assembly.
- Replace the main pca.
- Replace the ISS pca.
- Replace the power supply unit.
- Replace the electronics module.
(only replace one component at a time)
Yeah then you have to guess which part to start with.
Maybe anybody else on this forum knows more about the error and has a better idee about the part you should start with.
Just take a good look at the machine, and check which sections of the start up works before the error is prompted.
e.g. If the carriage moves then you could say that the scan-axis motor is probably ok.
Good luck....
Sep 07, 2009 | HP DesignJet 1050c plus InkJet Printer
Loud Loud Noise and a jumping machine on spin mode
hi it may be the belt problem ...better to change it thank u....
Jun 03, 2009 | Candy Washing Machines
Loud noise kenmore washer
  • Hi,
  • try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 22, 2009 | Kenmore Washing Machines
99 Grand Prix Heater only works on 5 makes a Loud noise
hi there
it sounds to me that you have two problems the
loud noise is the heater motor bushings is worn out causing the loud noise and vibration
also you will have to replace the resistor
once the motor is replace and the resistor replace all should be ok
Mar 09, 2009 | 2000 Pontiac Grand Prix
HP DesignJet 1050c InkJet Printer Logo
282 people viewed this question
Ben Johnson
