Question about Olympus VN-3100PC Digital Voice Recorder
The erase button is not working and my PC does not detect it
    Genius:
  • 1,218 Answers
If you have lost the manual go to www.olympusamerica.com.
Posted on Sep 07, 2010
Why Can't I add another remote to a merlin mt60p
If you purchase additional transmitters, the garage door
opener must be programmed to accept the new remote
code.
Program the Receiver to Match Additional Transmitter
Codes:
Using the orange "LEARN" Button:
1. Press and hold down the transmitter button you wish to
program to the opener. The orange LED will flash to
indiciate it is receiving signal from the transmitter.
2. Press and release the "LRN" button.
3. The sourtesy LEDs will flash once.
Ensure the door is clear of obstruction, then test the
transmitter.
Using the Motion Detecting Control Panel
(optional accessory):
1. Press and hold the button on the hand-held remote that
you wish to operate your garage door (1).
2. While holding the remote button, press and hold the
LIGHT button on the Motion Detecting Control Panel (2).
3. Continue holding both buttons while you press the push
bar on the Motion Detecting Control Panel (all three
buttons are held) (3).
4. Release buttons when the opener light flashes. It has
learned the code. If the light bulb is not installed, two
clicks will be heard (4).
Now the opener will operate when the transmitter push
button is pressed. If you release the transmitter push button
before the opener light flashes, the opener has not learned
the code.
To Erase all Transmitter Codes:
To deactivate any unwanted remote, first erase all codes:
Press and hold the orange "learn" button on opener until
the learn indicator light goes out (approximately 6 seconds).
All previous codes are now erased. Reprogram each remote or keyless entry you wish to learn.
http://gomerlin.co.nz/getattachment/2949a1dd-74ab-4576-850d-4f40de28fbe3/mt60p-installation-guide part 27 from installation manual page 15
May 05, 2014 | Building Materials
My iphone old 3g 16 gb black erase all setting contact 2 hour erased itune not detect device connect to computer apple log only not program how to restore
Connect your device to the PCHold the central button and the sleep/wake button for 10 seconds. It should work.
Aug 28, 2011 | Apple iPhone 3G
I wanted to erase all my contacts and info from my phone that i was planning to give away. i clicked on settings on the iphone's screen, clicked on general and then on reset and then erase all content...
I'm assuming you have a jailbroken iPhone. The reset all button just does not work properly on a jailbroken iPhone. What you have to do now is to plug it in your computer, Run iTunes then hit restore. If the phone can't be detected, enter DFU Mode. Follow instructions here so your pc can detect the iPhone.
http://www.fixya.com/support/r8568726-enter_dfu_mode_iphone_ipod_touch_ipad
Jun 22, 2011 | Apple iPhone Smartphone
My 1996 cavalier wont pass inspection as the analyzer cannont communicate with my vehicles computer, what does that mean, autozone computer wont work either . i have no idea what to do, mechanic said it...
Testing your OBD2
Before You Begin
Since all vehicles are not the same please refer to the manual supplied with the OBD2 code reader for vehicle specific instructions.
Is your vehicle compliant?
All cars and light trucks manufactured since late 1995 should be OBD2 compliant. Two factors will show if your vehicle is definitely OBD2 equipped:
  • There will be a note on a sticker or nameplate under the hood: "OBD2 compliant”
  • There will be an OBD2 connector as shown below
Pin 2 - J1850 Bus
Pin 4 - Chassis Ground
Pin 5 - Signal Ground
Pin 6 - CAN High (J-2284)
Pin 7 - ISO 9141-2 K Line
Pin 10 - J1850 Bus
Pin 14 - CAN Low (J-2284)
Pin 15 - ISO 9141-2 L Line
Pin 16 - Battery Power
Where is the connector located?
The connector must be located within three feet of the driver and must not require any tools to be revealed. Look under the dash and behind ashtrays.
Important info about OBD2
  • Can diagnose/check engine problems in all CAN and OBD2 vehicles (1996 and newer) and many of the most popular OBD1 (1981 to 1995) vehicles
  • Features unique patented all-in-one screen display and LED display for quick emissions check
  • Automatic refresh updates data every 30 seconds when connected to the vehicle - an easy way to verify repair completion
  • Code definition can be displayed in English, French and Spanish
  • Can be Flash updated with a standard Windows® PC
  • Features memory/battery backup for off-car review and analysis
Connecting
Connecting the OBD2 Code Reader is as simple as locating the DLC connector. The DLC connector is usually found under the driver side (left side) of the dash. The cable attaches only one.
Reading the LCD Display
april08_img2-small.gifClick to enlarge
Before you start testing, take a good look at the LCD display. The illustration above explains what the various icons mean and how the DTC (Diagnostic Trouble Code) will be displayed. The unit is self-powered by three-AAA batteries and will let you know when they are running low. When connected/receiving power from the vehicle, the CAR Icon will display.
The OB2 code reader is a very simple tool to use. Once it is connected, turn the power on. Once the ignition is switched to the on position, the code reader is checking the system for any stored DTCs.
The meaning of each DTC can be found in the manual supplied with your code reader.
Example: the code reader displays a DTC PO309, Cylinder 9 misfire was detected.
P0298 Engine Oil Over Temperature P0300 Random/Multiple Cylinder Misfire Detected P0301 Cylinder 1 Misfire Detected P0302 Cylinder 2 Misfire Detected P0303 Cylinder 3 Misfire Detected P0304 Cylinder 4 Misfire Detected P0305 Cylinder 5 Misfire Detected P0306 Cylinder 6 Misfire Detected P0307 Cylinder 7 Misfire Detected P0308 Cylinder 8 Misfire Detected P0309 Cylinder 9 Misfire Detected P0310 Cylinder 10 Misfire Detected P0311 Cylinder 11 Misfire Detected
Once you know what the problem is, you have to determine what's causing it. In this case the intake manifold gasket was faulty. Once the repairs have been made, it is time to clear the DTC and check the system to verify the repair.
Clearing the Diagnostic Trouble Code (DTC)
Clearing the DTC is very simple. Press the ERASE button on the code reader. A message will display on the screen; "SURE" for conformation. If you wish to clear the DTC press and hold down the ERASE button again until a message appears on the screen "DONE". If you did not wish to clear the codes and hit Erase by mistake at the screen message "SURE" simply press the link button to return without erasing any DTCs.
When you clear the DTC(s) from the PCM (Power train Control Module)you also clear ALL of the other gathered information that the PCM has collected, including Freeze Frame, Drive Cycle data, manufacture specific enhanced data end everything stored in memory is erased - just like if you cleared the Cache files on your PC.
The vehicle's PCM will need to re-learn the information that was erased. Don't be alarmed!! This is easily accomplished just by driving the vehicle. All you have to do is get driving.
Good luck and check the OBD 2 connection port.
Dec 02, 2009 | 1996 Chevrolet Cavalier
I cannot even find the eraser in one note
In One Note 2003, the eraser is to the right of the pen.
If for some reason you cannot see it anymore, you may reset ONE NOTE to its default options.
To do that (for ON2003) you click Help>Detect and Repair. In the window that pops up put a check mark in the box Discard my customized settings and restore default settings.
This should restore your toolbar.
Better yet, look for the small down arrow (with tooltip :toolbar options) and click it.
>Add remove buttons >Standard .
In the window that unfolds, make sure that the eraser is cheked. (For OneNote2003)
Hope it helps
Aug 21, 2009 | Motion Computing M1300 Tablet PC
How do I erase on my vn 5200PC ? I have tried pressing the erase button and then pressing Ok. That does not work. I have tried pressing erase button twice and then pressing Ok. That does not work. The read...
if the problem persists you could plug it to the pc and open your device and manually deleting or formating the device, formatting the device will erase everything on it
Aug 08, 2009 | Olympus Audio Players & Recorders
Card works well on phone but not detected by pc
sir please format your card using card reader
Dec 30, 2008 | PNY 2GB microSD Memory Card
PC cannot detect Sansa e260
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
Apr 20, 2008 | SanDisk Sansa e260 MP3 Player
Media player does not detect device
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Apr 10, 2008 | SanDisk Sansa E280 MP3 Player
My creative zen v plus is not detected by my pc when connected its screen has reddish lines neither it is shutting down nor it is working
Using the instructions below try Cleanup first, if that doesn't work... (if you have a backup of all your music on your computer), try the format option
This is from Creative's website:
Zen V Plus and Zen V
  1. Detach your player from the PC if it is connected, and turn off the player.
If the player stops responding, you can reset the player. To reset the player, gently
insert a thin object into the Reset hole located below the power switch.
2. Press and hold the Play button while powering on your player.
3. When the player displays the Creative logo, release the Play button.
It will display the following options:
Clean Up
Scans the player and removes invalid links from its music library.
Does not affect music files themselves.
Format (All) Caution! Erases all content!
Save a copy of your player's content before formatting.
Reload OS/ Firmware Caution! Erases your player's firmware.
DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install.
Reboot Reboots the device.
Message Edited by Jason-CL on 09-11-2006 12:02 PM
Forum Administrator
Creative Labs
Jan 05, 2008 | Creative Labs ZEN V Plus MP3 Player
Olympus VN-3100PC Digital Voice Recorder Logo
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
