I just bought a used Samsung LCD TV , model : LNT4671F. When we bought it, the picture and everything was perfect and working fine. When I brought it home and turned it on, there was severe color distortion in the middle of the screen. After leaving it on for a while and/or tapping the back of the tv a couple times, the color distortion in the middle of the screen disappears and only the top right corner of the screen's colors become distorted. Eventually a single vertical black line appears on the right side of the screen and stays there. This pattern varies everytime we turn the tv on and off. We took it to a repair man who says that it is the "signal bulb" or "signal board" (he has a strong accent, i'm not sure which he said) . Any idea what the problem is and would I be able to purchase and install the replacement parts myself? He is asking $385 for parts and labor. Any help would be greatly appreciated!
  • Televison & ... Master
  • 17,130 Answers
In the first placce buying a used LCD is not a good buy unless you have got additional warranty on the set since the change in the technology and spares are at a faster pace which might not give you value ffor money in case of a failure.
But not to worry I have few suggestions which you can look into only if you are familiar with electronics.
Check the main board after removing the rear panel for DRY SOLDERING which happens in most sets in a perriod of time due to constant heating and cooling of the solder joints. These joints are a major trouble and as you mentioned tapping brought back to life some complaints this is an area of doubt.
SO using a good soldering iron and ONLY if experienced attempt to solder the sections suspected of dry joints in the main board.please take care not to bridge connections to end up with a tampered set.
Look into the sections of the convergence IC, the powerr panel and drive panel, solder and correct.Since the set worked fine this can be the only reason.
Posted on Aug 30, 2010
  • Donald DCruz
    Donald DCruz Aug 30, 2010
    The last part , If the set worked at the place of purchase then why such a failure? So check this out and see .As I said repairing an old set is without guarantee.So before any more money is spend take another opinion and do the checks that I had reccommended.
Cable
I tried to connect my PC with LCD TV using an HDMI cable.
PC did not detect my TV; however everything works fine with VGA cable. VGA cable is the perfect choice.
Jul 08, 2013 | Toshiba Satellite L305D-S5974 Laptop
My Samsung TV 46" LNT4671F
Hi:
This is due to low voltage getting to the Inverter board or the Inverter board on the bad side is not lighting the lamps. Usually bad capacitors or the power supply and the inverter will cause this symptom. You may want to replace both inverters boards on this model, new models have one inverter board for both sides of the backlight.
Nov 10, 2010 | Samsung Televison & Video
Samsung LCD -no picture/sound from any input source-Cable,DVD,PS3
Use the menu button in the front screen of your tv.Maybe your remote control need a battery.
Jul 24, 2009 | Samsung LE40B650T2 40 in. Full HD Crystal...
Connected samsung dvd vcr combo to samsung lcd series 6 tv via componet cables dvd works fine vcr playing but no picture help me. gordy
all i did was disconnect the component cables and connect using the rca cables and everything worked fine.
Jul 06, 2009 | Samsung Televison & Video
Samsung LCD tv - Turns on and off by itself.
Since you have another TV with the same problem you can try using an antenna(indoor model ok) to see if the cable is causing the problem. If not return TV before the warranty expires.
Mar 03, 2009 | Samsung LN46A850 LCD TV
When I turned the tv on only vertical lines appeared
I talked to a Samsung support helpline and it needs to be taken to a service center for repair.
Mar 02, 2009 | Samsung LN-S3238D 32 in. LCD HDTV
SAMSUNG LCD WONT TUNE INTO NORMAL TV STATIONS
You need to have a licensed antenna repairer out to fix your antenna. Just because your old tv is receiving enough signal to JUST get a picture doesn't mean your new tv will, A new tv doesn't mean you will get a perfect picture if your antenna is dodgy
Dec 30, 2007 | Televison & Video
Pink display
It seems the DV-S5950 has an incompatability with HDMI through Samsung TV's.
I work for an electronics store in Australia, and had same problem when running this DVD player on my Samsung KA40A650.
I tried it on my brothers LA40M51 and the same thing happened. Tried it at work on the A650 display model and same thing again. Then I tried it on the LG LCD that was next to it, and no problems. Also tried the DV-S5950 display model at work and it did the same thing.
It's not a general Yamaha issue, as we bought a new (higher model) Yamaha DVD player and it worked perfectly fine. I also tested the cables, and it wasn't them either.
It seems that that specific model of DVD player from yamaha just doesn't like the HDMI inputs on Samsung TVs...
Nov 26, 2007 | Yamaha DV-S5950 DVD Player
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
