Question about Yamaha NS-BP4500 System
I want to buy a receiver compatible for this NS-BP4500 speaker systerm. Which Receiver should I buy?
  • Luvlybrain May 08, 2008
    what is DSP system?
  • Anonymous Mar 31, 2014
    Will bn buying a yamaha rx -va30 amplifier so don't know which cable to use or buy for an existing speaker?
  • 236 Answers
If you have the manual for the speakers please try to get the specifications. i suggest that you get a yamaha DSP system for this also.
Posted on May 08, 2008
  • Redentor Rivera May 08, 2008
    A Yamaha receiver is good, DSP is a model that provides multi channel surround sound effects. for that you will need more speakers too. but check the specs of your speakers before you get the receiver, make sure the power handling of speaker matches the receiver amplifier.
You have asked a big question with lots of possible answers.
I am not familiar with your receiver so I don't know the important things about it - such as the power output and the required speaker impedance.
There are other important things to consider too, such as where you live, are there close neighbours, what sort of noise do you like to make and how loud and equally importantly how much room do you have; are the speakers to stand on a shelf, on the floor or be suspended from the ceiling?
Generally the bigger and more solid the speaker cabinet the better the sound is but that would be useless if you have room for only bookshelf speakers.
You said budget speakers. If you want quality sound then budget speakers are the last thing you need - you would be better going to buy some decent used speakers from a garage sale or buying yourself a couple of decent drive units and fitting them into a pair of concrete drain pipes or even lavatory pans or constructing your own cabinets or if you have lots of space just a pair of infinite baffles.
If buying used speakers there isn't much choice; you have to have what is available within reason but if you are buying new it is best to know what you want. There are two basic types of cabinet - the infinite baffle, a closed air-tight cabinet that if well constructed and big will make mediocre drive units sound better and the fashionable type just now, the tuned bass port cabinet that must be well designed and have decent quality drive units.
Both those types could house one, two, three or even four drive units and perhaps a crossover and/or peizo tweeters.
I suggest you do some research and sleep on what you have learned and then ask your question again including a great deal more information.
Oct 02, 2016 | Yamaha Audio Players & Recorders
Speaker wont connect to bluetooth
Go to your Bluetooth settings and forget the device. Then re-pair it for a fresh connection. This worked for me
Apr 12, 2014 | iSOUND 1690 TWIST WIRELESS SPEAKER &...
No sound from my speakers
Make sure your source is properly assigned and switched to respected input. Your speakers should also be engaged.
Mar 11, 2014 | Insignia Ns-r2000 200w 2ch Stereo Receiver
I have a Yamaha RX-385 receiver. I want to increase the number of speakers I can use from the receiver. I am considering buying a speaker selector that says it can connect 4 sets of speakers I can run to...
This speaker selector is standard accessory equipment for home audio equipment -- just follow the instructions with the unit.
The speaker selector unit has circuitry which prevents the amp from being overloaded by connecting too many speakers in parallel to the receiver. The receiver will have to be run at a higher volume level to drive all the additional speakers at the same volume as two sets of speakers, but this will not damage the amp in so doing.
Jul 17, 2011 | Yamaha Audio Players & Recorders
I just purchased a yamaha RX-V767 receiver. I have a polk surround sound speaker system 5.1 that have an impededance of 8 ohms. The receiver has an impedece adjustment knob on it. would it be safe to...
No, you don't want to do that. The Ohm output on the amplifier must match the speakers. Run 8 Ohm speakers on 8 Ohm and run all your speakers on the same impedance (Ohms). Your gonna burn your amplifier up if you run different impedances.
Mar 24, 2011 | Yamaha NS-A60X Main / Stereo Speaker
Can't run tv sound from my Vizio M190VA tv through my Insignia NS-R2000 receiver so it will play through my speakers in the ceiling which are connected to the receiver. Is it possible to do what I am...
I have no idea why manuafacturers or users think a TV is a good place to originate sound in this Cable Box age. The Cable/SAT box is for all intents and purpose a hi-fi multichannel audio source like any other audio component, where the TV's audio was probably an afterthought.
With that in mind, source the TV-related audio directly to the NS and skip all that zig-zagging of audio all over the room before it gets to your ears.
I also recommend taking all high-end video directly to the TV/monitor from whatever sources you have. Added cabling (and cost) doesn't help. Let the specialty devices each handle what they master.
Does that help?
Mar 18, 2011 | Insignia NS-R2000
What size receiver do i need for these speakers and how easy will it be to install?
Hi,i guess you can use anything receiver from 300 watts below,so that it will not blow off the speaker .
When ever the watt of the receiver is bigger than the speaker,you will make sure that the volume range at which you are driving the receiver is not to high,cause it can damage the speaker..
Have a nice day..
Feb 17, 2011 | Yamaha NS-AW350 Main / Stereo Speaker
I want to hook up my bose speaker systerm to my new vizio tv
Real easy, get a RCA audio cable (red and white ends) that is long enough to go from the tv inputs to your receiver inputs. Plug one end into the audio out on the back of your tv, then plug other end into input on your receiver (tv, cd or vcr). Now everything going to tv will output to receiver also. You may have to go into the TV menu and under audio, set audio output to fixed. Then you can change the volume on your receiver which is best way to go.
**Advanced** If your TV and receiver has optical capability you can use an optical cable instead.
Good luck,
Mar 23, 2009 | Vizio VW42LF 42 in. LCD HDTV
I have a fm-am receiver #ns-R2000, I push the power button & it shuts down immediatly, What could be the salution?
The receiver is going into a protection mode. This happens because there is a failure either inside the unit itself or in something attached to it (such as the speakers).
A quick and easy thing to try is to disconnect all of the speaker wires. If your NS-R2000 now stays on, carefully examine all of the speaker wiring to be sure it is not shorted. Also check the speakers to be sure they work properly.
Oct 20, 2008 | Insignia Audio Players & Recorders
Check the impedance ratings of your speakers. Sherwood, the actual manufacturer of the NS-R2000 receiver, suggests that you use speakers with an eight ohm impedance if you have only one pair attached. If you have two pairs of speakers attached, the impedance rating of each pair should be sixteen ohms.
This is because Sherwood wired the receiver such that an additional pair of speakers is placed in a parallel circuit to the first set. When this is done, the impedance (resistance) of the load seen by the amplifier drops. As resistance drops, you get closer to a short circuit (no appreciable resistance).
Many other receivers wire the speakers in series, which causes the impedance to go up.
Personal experience seems to suggest that the amplifier is OK with a four ohm load on it. It does run warmer with a four ohm load, which is what you'd expect. It's when you have multiple sets of four ohm rated speakers that you will get into trouble, as this means the receiver only sees a two ohm load. This will cause overheating and shutdown.
At this point the power transistors in the amplifier may have been damaged. It may require repair. Fortunately, replacement parts are readily available (though not from Sherwood or Insignia). If it continues to shut down, stop using it. You could end up burning out your speakers.
Jan 09, 2008 | Yamaha RX-V2400 Receiver
Yamaha NS-BP4500 System Logo
175 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
