Question about Fellowes Cordless Optical Keyboard/Mouse 99666
Keyboard Everything on the keyboard works except the letters...and numbers, but everything else does, what do i do?
    Novelist:
  • 150 Answers
If the letters and numbers don't work, what is left ?
Keyboards are electronically organized into a matrix of rows
and columns. An internal processor monitors the columns
as it activates the rows one at a time in rapid succession,
or vice versa.
If a complete column or row is bad (electronically) then
a subset of keys will not work. For a PC, the detected key
strokes are encoded into special binary codes called
"scan-codes", which are sent to the PC over a serial cable
or a wireless link.
The operating system then employs several layers of
translation to determine which keys you pressed,
based on the language and location, as well as the actual
application actively running at the time. Also the keyboard
itself is programmable and re-configurable by software running
on the PC, such that the letter "A" for example, can generate
different scan-codes, depending on the selected keyboard
layout.
On laptops, multiple functions and the numeric number-pad
are overlaid over the main alphabetical section, such that a
single key can serve many functions, depending on the current
operating mode.
1) Make sure you don't have a software problem, and that your
keyboard is not stuck in some bizarre or foreign operating
mode.
2) Make sure that the wireless keyboard's batteries are not weak
or dead.
3) Make sure that there is a clear communication path between
the physical keyboard and the USB transceiver plugged into
the computer. CRT monitors and large metal objects will
interfere with this signal.
4) Reset the keyboard: Unplug the USB cable, and plug it
back in, or re-boot the PC.
5) If these easy checks don't fix it, contact the manufacturer,
or replace the keyboard, as these things are generally not
electronically serviceable
Typically the processor/controller is a single proprietary chip,
the circuit board has multiple layers which are very hard to
trace or repair, schematics are non-existent, and the switch
mechanics are very finicky and delicate. The actual
key-switches can use dozens of different principles, including:
capacitance, inductance, carbon pressure pads, conductive
foam, printed pressure bubbles, reed switches, optics....
you name it.
There is no practical way to repair these things, and at an
average price of $25-$100 for a new keyboard, it
is hardly worth it.
Martin
Posted on May 08, 2008
When I type a letter on keyboard it keeps repeating the letter
The key might be sticking down, which is probably a defect in the product. I tested an ihome keyboard (Bluetooth) and everything except the spacebar was prone to sticking itself down, no pop spill or nothing. So, I recommend to return the keyboard if you still have the receipt and get a Bluetooth Apple keyboard instead, as ihome is good for their docks, but their keyboards suck!
Feb 02, 2013 | iHome Bluetooth Keyboard for iPad 1 & 2,...
My ZTE Warp keyboard goes crazy. adds letters, changes words, adds punctuation, capitals, etc. I hit one letter and two or more shows up sometimes. I have changed my settings but nothing helps. Its...
found it,
when texting click on the double arrows directly below the text window.
Then click on the wrench,
then click on "language and settings".
select your language then click "keyboard input".
uncheck everything except for "Keyboard"
also click on"Auto-Selection" and turn it off
also click on "word Completion" and turn it off.
Enjoy your texting!
Dec 09, 2012 | Computers & Internet
My keyboard on my laptop replaces the letters with numbers and/or characters when i click them, like when i press "I" i get the number 5, or w, o, p, l, k, I get fancy characters
Go to the control panel first and check the Regional settings and languages icon. Look in there and make sure all the settings say either "English- United States or just United States.
If everything is correct there, hold down the Fn key and tap the Num Lock key, then try the keyboard again.
Oct 07, 2009 | Dell 0Y3740 Keyboard
Wireless keyboard, some buttons work, some dont
Usually this happens due to the distance between the keyboard and the computer/receiver (if you have one). It could also happen due to interference from another wireless device like a cordless phone. Try reducing the distance, remove any source of signal interference and check.
If this doesn't work and the issue remains with some specific keys, it could be a hardware problem. To be sure, try another wireless keyboard if you can. If it works, its a hardware issue for sure.
Your Technology Partner
Aug 27, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Keyboard on gateway W323-UI1 does not work
yes the keyboard can be replaced on laptops and notebooks.
Apr 15, 2009 | Gateway (4000274) Motherboard
KEYBOARD NUMBERS
There should be a button called "numlock" which will enable to you use the keypad to the right of the keyboard, however, you don't need to "lock" the keyboard to use the numbers on the top row.
Apr 15, 2009 | Dell 0Y3740 Keyboard
Numbers keypad not working
unplug keyboard/ uninstall the keyboard driver and device/ plug keyboard back in should auto detect
Sep 03, 2017 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Number lock
the laptop is switching numlock on, you need to disable this in the laptops BIOS
Nov 09, 2007 | IBM ThinkPad R40 2722 Notebook
Keyboard
hold shift and hit the numlk key
Apr 17, 2007 | IBM Thinkpad 560 Series Laptop 20h4241...
Fellowes Cordless Optical Keyboard/Mouse 99666 Logo
195 people viewed this question
Top Fellowes Computers & Internet Experts
Gary Paul
Level 1 Expert
Are you a Fellowes Computer and Internet Expert? Answer questions, earn points and help others
