Question about Microwave Ovens
How do you clean gas burners, stove top -dirty gas burners
  • 8,197 Answers
On the links below will help you clean the burners.
http://www.thriftyfun.com/tf506804.tip.html
http://www.ehow.com/how_4760745_clean-gas-stove.html
Good Luck
Posted on Aug 29, 2010
Elec-ignighter on gas stove top not working
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 20, 2011 | Microwave Ovens
I am disassembling a Kenmore stove top gas burner to clean under the stove top. To do so you actually need to unscrew the burners, which I've done, but then I need to unhook the spark electrode, which...
The electrode is held onto the burner head with a screw through the mounting tab. They can get crusted over and it's not always easy to see the screw head, but it's there.
Jul 04, 2011 | Microwave Ovens
Ignitors continue to pop altho all four knobs are in off position Kitchenaid gas stove top Model #KGCT305X Serial #XB2806974 ir X52606974
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Apr 21, 2011 | Microwave Ovens
I was cleaning my gas stove near the knobs and now it keeps sparking until i turn it off. will it eventually dry up and work again?
Usually but not always....
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair
heatman101
Feb 06, 2011 | Microwave Ovens
The gas flame on my 4 burner Chambers stove top is very low. When we try to adjust the air flow the flames increase for a moment but then return to being low. What could the problem be and how can we fix...
I had the same problem after a melted butter accident... I shut off the gas under the stove by a valve. Then I took the burners off and cleaned every orifice I could find. Still no luck. Then I cleaned out the main orifice right out of the controls for the burners, it was tiny and had to get a very small pipe cleaner made for an air brush gun. That did the trick! But now I have soaring flames and I'm trying to figure out how to adjust them back down.
Jan 11, 2011 | Microwave Ovens
Top left burner (propane) does not seem to be receiving gas when trying to ignite it with electrical igniter (control knob). However the burner can be lit with a match when the control knob is turned past...
The igniter usually sparks for all burners on the stove at the same time. Usually a little water or gravy, or such has gotten on the little spike that stick up and throws the spark to the burner. If you will take a small brush, like a tooth brush and carefully clean around the little spike it normally starts sparking again. As it is right now, you should be able to see the spark on all the burners whenever you start any of the burners. Check to see on the one that is not lighting, I think you will find that it is not sparking at all right now.
Sep 21, 2010 | Microwave Ovens
I have a kenmore stove whose burners wont light. oven works fine. burners will spark but no gas comes out. recently I turned off the power to the stove by turning the fuse off. what do I need to do to get...
If the gets give no gas then sounds like a Thermocouple, this is a device that allows the gas to come on after a period of time ensuring that the pilot is lit and heated up this thermocouple, once it heats it then allows gas to enter and ignite the main burner..hope this helps ,please leave feedback.
Apr 12, 2010 | Kenmore 66469 / 66462 / 66464 Microwave...
Stove won't stay lit!!
So, you cleaned the burner per the manual (or the one you looked at when visiting the appliance store,) and it still flames out right after coming on? Sometimes things catch in the works and there are a few methods to clear them out (e.g. at the controls) depending on the model. Beyond that,in order to disconnect the stove and check the inlet filters, you might want to call the appliance or gas co for a technician. No use having leaks, searching forever for the main shutoff valve, etc.
Mar 24, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
98 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
