Question about Dometic Rooftop RV Air Conditioner
We cannot get our remote to turn on the ac unit. We cannot get it to work with the button beside the unit. There is power to the unit. We think it may be programed wrong & don't have any instructions. Any suggestions?
  • Dometic Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 30, 2010
How to reset factory stereo panasonic sc-vk825d
Turn the unit off then back to ON. Alternatively, turn the unit off, disconnect the AC power supply cord, and then reconnect it
OR....
While stopped and "DVD/CD" is the source, press and hold [L STOP] on the main unit and[h10] on the remote control until "Initialised" disappears from the television.Turn the unit off and on again. All settings will return to the default values
Jun 30, 2016 | Panasonic Audio Players & Recorders
Previous tenant left ac window unit Haier HWF05XC5, but took the remote. Can I manually turn on this ac unit? when turning the power button, only the fan turns on, I'm unable to switch to AC
According to the Model Number you listed, it's a Mechanically or Manually Controlled AC unit. There is no remote control for it.Please be certain the Model Number you listed is correct and get back to me.
If it's the correct model number and it's manually controlled. You should have 2 rocker switches. One is to turn the power ON & Off. The other is to set the Fan Speed either on Low or High. Then there is a dial, numbered 1 to 10 to set the cooling level. 1 is min cool and 10 is Max Cool.
If the controls on your unit match what I described above, it's a manually controlled unit. No remote.
I hope this helped you. Please advise. Thanks.
Jul 11, 2011 | Heating & Cooling
Remote won't communicate with machine
Try the following until you achieve results:
1. Make sure power is turned on
2. Check batteries in remote are working
3. Lift front panel of A/C unit and press the test button beside the electrical cover on the right of the unit.
4. If unit still will not start then the computer control card is most likely damaged and needs to be replaced
Apr 27, 2010 | Fujitsu Heating & Cooling
Anyway to turn on pioneer pdp 4350 with no remote?
If I'm thinking correctly, there are buttons right side of the TV. Besides the power buttons on the front of the TV and the box, there is a Standby/ON button. Somewhat hidden, but it's there. The top button on the right should turn the whole thing ON.
Mar 02, 2010 | Pioneer PDP-4350HD 43 in. Plasma...
I have a GE small unit that is 5 to 6 years will not start up
About the only thing can suggest is see if a lamp or other will work in the outlet that you have the AC unit plugged into.
May 07, 2009 | GE AJCQ08ACB Air Conditioner
Remotes won't turn on
ok,you changed the battery already but did you synchronize the remote to the console?beside the battery of the remote is a small red button.did you try to press this button? as well as the red button on the console?it is located on the memory card port of the wii.try it first,let me know
Dec 25, 2008 | Nintendo Wii Console
Haier HWR05XC5
I have 2 of these ACs one remote is missing and the other was dropped in water. You can use the AC. Plug the unit in and hold the on/off button down for about 20 sec.or until the unit comes on. The cooling unit will come on but you will not have any control on the temp or fan speed, but you will have cool air and not just the fan running.
Jun 07, 2008 | Heating & Cooling
Our AC won't come back on after i turned the power at the wall off and then on again. It was all working brilliantly till then and now i can't get a bit of life out of it. I can't even tell if any power is...
To OzAnday
If the light indicator of your unit have light with power "on", then there is a problem with the unit. May the fuse of your pcb is open or the pcb itself has a problem. You have to call a qualified technician to check.
To floscar
Reset the rest button of your remote control, but if it wont work may the remote itself has a problem or the receiver board.
Dec 31, 2007 | Fujitsu 24C1 Air Conditioner
Marantz Remote control model RC-18SR
Does the SOURCE ON\OFF button still work? If so, you can still use the remote to turn the receiver on and off by first pressing the AMP button (so that the remote window says AMP) and then pressing the SOURCE ON\OFF button.
Dec 23, 2007 | Audio Players & Recorders
Unit Powers on but Screen is not working.
I had the same problem before. I thought the mechanic broke my radio. The power button will not work on the radio, right? I couldn't turn it on or off, but the blue lights stayed on all the time. What I found out is that I had to put a new battery in my remote because it died at the exact same time. Crazy, huh? But anyways, you have to use the power button on the remote or else it will stay black forever. Once you turn the unit on with the remote, it will prompt you to enter your password. Like guest said before, if you didn't set your password before, then the default code is 0000. I hope you get that thing working!! -kev
Sep 24, 2006 | Panasonic CQ-VD7001U Car DVD Player
Dometic Rooftop RV Air Conditioner Logo
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
