Question about Philips 37PF9631D 37 in. LCD HDTV
My Philips 37PF9631D/37 is about 4 years old. During the last few months, the picture has begun to grow darker and not as clear. Possible causes?
  • paul_bough Aug 30, 2010
    the problem is not the backlights (ambilights). They work fine and I can turn them on and off as desired. The problem is the picture quality. It's getting dark. I can turn up the brightness setting, but that dosen't help very much.
    I have a Philips flat screen TV model 37PF9631D/37. This is an "Ambilight" model. It is about 4 years old. Over the past month or two, the picture has begun to get dim (dark). The Ambilight feature works fine (I can turn it on or off as desired). What could be causing this?
  • 979 Answers
Hello Paul, hi, your TV's LCD screen is powered by a back light that slowly slowly getting old/dim, until this lamp goes to off permanently, this need a replacement lamp, need also to check the inverter circuit that powers this lamp. Once replaced, the TV will go back to normal operation.
Posted on Aug 30, 2010
  • Philips Master
  • 5,416 Answers
Sounds like a backlight failure. http://www.shopjimmy.com/catalogsearch/result/?q=37PF9631D%2F37 has the Ambilights from TVs of this model that were damaged in shipping (so they were only used in the factory quality control testing). The backlight usually fails slowly (while the inverter that powers them fails quickly).
These fit on the edge of the LCD panel.
(on some units the backlights are under tape sandwiched into the frame of the LCD Panel. I haven't dealt with swapping the Ambilight on this model though.)
Posted on Aug 29, 2010
  • Cindy Wells Aug 30, 2010
    Then I do not know the answer. In general a dimming backlight is a common LCD issue. (Symptoms of inverter failure and video board failure are no image at all.)
    I wish that I could be of more help.
I have a Philips 37PF9631D/37 which has 6 times blinking red light syndrome. After opening up it appears there are two 250V 820 uF capacitors that may be faulty. Are these safe to...
Look for bad capacitors on power supply board they will be vented or swollen on top.
1000uf 16v 3300uf 10v 330uf 10v. Look for boards on shopjimmy.com
Also check the fuse on the inverter board it maybe bad.
Oct 15, 2011 | Philips 37PF9631D 37 in. LCD HDTV
Where can i find a service manual for the philips 37 pf9631d tv i need a schematic for troubleshooting thecomponents on the boards
What type of defect? most of these are board level repair.
you can purchase the manual from encompass electronics if you need it.
Feb 18, 2011 | Philips 37PF9631D 37 in. LCD HDTV
Philips MCW770/37 stereo will not power on any longer.
Hi ,
This is just a suggestion. Check your speaker wires at the back and at the speakers. A shorted speaker wire will cause a tripped breaker.
May 19, 2010 | Philips MCW770 CD Shelf System
My tv picture is light and hard to see and will periodically shut off.its only abput 5 yrs old/
For a Philips LCD TV, that's at least two years longer than they typically last. The most common problem with Philps TVs is the power supply board, which could cause the TV to shut-down by itself. The picture being too-light could happen for several reasons. In general, a repair shop needs to figure out what's wrong.
Nov 02, 2009 | Philips Magnavox 42MF521D/37 Television
Screen is getting darker
The most likely cause is the blue and green tubes need to have the cooling fluid changed. After many years the blue and green get clouded with algae. The red tube won't have the problem due to the red spectrum kills the algae before it has time to grow.
The way to replace the fluid for is to completely remove each CRT from the set, remove the drain plug, drain the fluid out the tube, disassemble the lens, give it a good cleaning; then reassemble; add fluid; and reinstall in set. If you check with the site www.TvRepairKits.com they are working on a kit that includes the fluid and photo instruction guide.
Dec 14, 2008 | Philips Magnavox 9P6034C 60" Rear...
Color fading in picture
you need to replace the coolant in thr CRTs( picture tubes) Vert common problem in phillips. You can get the enitre repair kit at the following link which has the coolant and instruction CD for phillips coolanrt change. Heres the link its under the repair kit section.
http://servicemanuals.vstore.ca/
Jul 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips 37 LCD Service Manual
http://www.eserviceinfo.com/most_popular/list_5800.html
https://www.manualsparadise.com/Sho...model=M31429247
https://www.completeservicemanuals.com/panasonic/digital-camera/lumix-dmc-fz5-service-manual/prod_86.html
http://www.user-service-manuals.com/Sony/UP.shtml
http://www.schematicsforfree.com/
Mar 09, 2008 | Philips 37PF9631D 37 in. LCD HDTV
Picture getting darker
The tv has a room light sensor,
shine a bright light at it , does picture get brighter?
other wise when it is cool open the bulb door , is it coated or blackened, Don't touch bulb at all.
and a heavy covering of dust on internal mirrors will cause the same effect.
you will need help to clean it.
Jan 26, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
UNABLE TO BRIGHTEN PICTURE
Your CRT coolant needs to be changed. Thats whats giving you the dim picture. You can also clean the projection mirror on the inside this often helps. But the coolant will need to be changed to get back the bright crisp picture. Hope this helps.
Jan 20, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips 37PF9631D 37 in. LCD HDTV Logo
236 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
