Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
5PK shows up in digital readout - Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
    Top Expert:
  • Raypak Master
  • 8,502 Answers
Check safety circuit ans gas pressure and ignitor if ok pressure switch
Posted on Nov 30, 2017
I have a Lincoln 305g with digital readout and the amperage readout is fluctuating wildly but is not effecting amperage to the stinger,is it possibly just the digital readout that needs replacing?
Most likely the coil that is sensing output at the lead terminals. Check it with a hand held Amprobe (digital) to see if out put is stable at the leads.
May 15, 2017 | Lincoln Cars & Trucks
On model PLEF398DCH Frigidaire Professional Series electric range, my digital readout for the right side burners works fine. My left side digital readout is inoperative, but the burners work fine. Is there...
Good Afternoon Lee,
I understand that the left hand side digital readout is not working on your Frigidaire range, model# PLEF398DCH. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Sometimes there can be a miscommunication between the different boards inside your appliance. Once you restore power, you will need to set the clock and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 27, 2014 | Frigidaire Kitchen Ranges
My treadclimber 5000 treadils stops runing when I get step on the right one
Recalibrate the machine if speed is not registering, belts stop turning or the display readout shows an "err, LS, OS" on the face. Calibrate the Bowflex TreadClimber 5300 by plugging it in. Stand on the foot platforms, or floor mat. Do not stand on the walking belt. Insert the safety key. Press the "start" key when "CAL/PRSS/STRT" shows on the readout. If readout fails to show the "CAL/PRSS/STRT" symbol, turn off machine and turn it back on. Press "ENTER" and then "DOWN SPEED" at the same time until "CAL/PRSS/STRT" shows up on the display. Belts will start and stop during the calibration; do not be alarmed. Do not make any adjustments or interrupt the display of numbers as the unit goes through the calibrations. When the machine is finished calibrating, the readout will display "CAL...PASS" and you can press the "POWER" key to get out of the calibration section
sincerely.
Nov 25, 2011 | Bowflex Treadclimber
Digital readout not readable
Try a new one. If it works, the scale is broken.
Jun 30, 2010 | Taylor Precision Products Taylor Precision...
No mileage showing digital readout thanks
It is registering, but the light is burned out. You can probably use a flashlight on it and see a faint glow of numbers, but you just need a new bulb. Your radio is probably only half lit on the readout, too. Common problem with Pontiac sunfires. Dashbulbs. Cheap fix, but time consuming.
Nov 17, 2009 | 2001 Pontiac Sunfire
The numbers on the digital readout are partly
If the display is showing "partial digits" on the display, it means a scale is excessively shaken (sometimes during shipping) it's possible for the LCD to become partially separated from the PCB (Printed Circuit Board). On many models you can gently press on the LCD and it will reconnect. However on many scales it's difficult to reach the LCD (without removing the cover) and thus the scale will often have to be returned to the manufacturer for repair. Contact them at 1-800-326-6247 for the Conair appliance customer service center.
Sep 09, 2009 | Salter 9007 Glass Lithium Digital Scale
My ge humidifer AHH140LK61 is showing a "P1" readout
Unit is defrosting – Allow the unit time
to automatically defrost. The error will
clear after the unit self defrosts.
Dec 02, 2008 | General Electric AHK30LK Humidifier
Casio Wave Ceptor Watch Model WV 109 HA
I found a hand setting mode. Press lower left button 6 times until the readout shows HS. Press and Hold Upper Left Button (A) until flashing. Press lower right button (D) to move the hand forward. Press upper right button (B) to move the hand backwards.
Apr 22, 2008 | Watches
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
79 people viewed this question
Top Raypak Pool & Spa Experts
Paul Carew
Jim Goldsmith
Jim Goldsmith
Craig Butler
Craig Butler
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
