Question about Goodman GDS80703ANA Open Flame Mid-Size Heater
It says the pressure switch is stuck open, how do I fix it?
    President:
  • 1,515 Answers
Hi, this will be a very easy fix for you if you try and follow what I am telling you to to. I will start and tell you what this is and does. This switch is a single pole one contact safety switch for the heater. It is normally open when heater is off, and supposed to close for heater to start. First, go to the indoor unit and remove the panel, you may or should have a flashing led and code chart that told you this. Take the panel off there to expose all parts and switches. If you take a panel off and all goes dead( no led light anymore ) then you have a switch on the perimeter where the panel sets that kills power when panel is removed for safety. Find it and use a good strong piece of tape to tape it down so you can work on it. It may not have one. Anyway, you will have what is called the inducer motor there in front of you, has a small fan on it. When you set the thermostat to call for heat this is the first thing that will be energized in the sequence of operation to remove old gases and to pressure up the heater box. You will see a clear poly type 3/8" tube coming from this motor and it will go to this pressure switch. These switch's can be different looking, but most are round the size of a large silver dollar with a barb on it and this tube attached to it. This is what the motor sends air to and close this single contact to tell the system that the motor is working and is safe to go to its next step in the start-up process. They sometimes will stick or sometimes fail. So, if the motor is running I am sure it will be on, turn the unit back off. Now, go back and remove the tubing from the part of the motor that goes directly to the switch, just that end. Now, just blow through it a little, puff, puff, puff, and you should hear it click each time. This should un -stick it. Inhale and exhale through this tube so it works the contact good. Now, put it back on and restart the heater. If the led light or code is not clear, turn off the breaker and let it set for a few minutes and turn back on. This will reset your circuit board. Now turn on the stat. Watch it go through its sequence of operation, motor, close switch, glow plug, gas valve will click and energize and burners will light and your off! Be sure to remove any tape if you had that switch. Now, if the motor was not running to begin with, we will need to take a different route on this. Very easy and good furnace. Please don't forget to rate me and leave a few words if you like as this will be very kind of you. Please keep me posted on the outcome and I will check in on you. Good Luck, but you can do this on your own I am certain of it!
Sincerely,
Shastalaker7
A/C, & Heating Contractor
Posted on Aug 30, 2010
Lg wm2016cw
Check that the pressure switch tube is connected to pressure switch. Check that the water inlet valve is not stuck open. To check start washer, turn washer off, if water continues to flow the valve is stuck open, replace.
Aug 01, 2014 | LG WM1814CW Front Load Washer
Model m1mc 090a bw furnace pressure switch open. inducer motor is pulling .45 w.c . the intake pipe above inducer is only pulling .1 w.c. . checked for venting and intake blockages found non. removed...
did you check the hose from the inducer to the pressure switch? HAVE you unplugged the unit from the wall outlet to reset the board? DO you have a voltmeter? If you do you can run voltage across the switch and if you get 24 volts you are open.
Oct 23, 2013 | Coleman Intertherm Nordyne Miller Furnace...
Hotshot over heating
there r three devices which can cause overheating.
1)-thermastat(stuck in close circuit
2)-pressure switch and or flow switch stuck in close circuit.
3)-fuel solenoid stuck open located at fuel pump
Aug 03, 2013 | PressurePro Pressure-Pro Hot Shot Series...
Goodman Gas Heating A/GPG13 Not Heating - Pressure Switch Stuck Open
Clear the little hole where that hose go to the inducer case
Feb 10, 2013 | Goodman Manufacturing Goodman...
"switch stuck open"
Pressure switch stuck open , check tubes are on tight not split on the connections to the pressure switch, sound like you will need a new one
Dec 31, 2011 | Dayton Gas Furnace Heater
Pressure switch stuck open. I'm getting three blinks. Is is possible to fix this myself.
Hi, yes you can. The pressure switch is just stuck open causing the unit not to fire up. Find the small inducer motor that should be running, if its not and you have the panel off, you have a switch for the panel to kill the power when you take it off. You will have to tape it down with duct tape to restore power.You will see a clear plastic air tube coming from the motor and goes to this pressure switch. Pressure from the motor is what opens and closes the switch. Unplug it at the motor and blow through it several times. You will hear it click. Do this back and forth and it will break it loose. This will solve the problem. Kill power to reset unit. Start it up and your done. If it continues to do this, get a new pressure switch at a appliance parts house. Let me know the out come and please be kind when you rate me as I know you will. Good Luck,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
May 15, 2010 | Goodman GMS90703BXA Heater
Code 3 - pressure switch stuck open. What do I do
where vent motor is there is usually a hose coming off which oressurizes when vent motor comes on, take hose loose **** or blow in it, take tooth pick and stick in all ports where hose connects (could be clogged) when sucking on hose you shoul hear pressure switch click each time you pull a vacumme, if fan has switch on back of fan as some Goodmans have the vent motor may need to be replaced.
Oct 27, 2009 | Goodman GDS80703ANA Open Flame Mid-Size...
Furnace code light flashes 3 times /pressure switch stuck open
Check the intake and exhaust plumbing for any obstructions. I had same issue, turned out to be ice in the air intake plumbing on outside of house. This may be the problem. The pressure switch can be tested by pulling hose from purge motor that goes to switch and applying a small amount of suction. The switch should make a clicking sound.
Dec 19, 2008 | Kitchen Appliances - Others
F o8 in my washing machines
heater relay stuck check pressure switch, heater and module connections poss pressure switch fault
Jan 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Heating & Cooling Logo
443 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
