First download and install
Pheonix. Nokia
Phoenix Service Software 2011 - Download secondly Download flash file from this link Nokia flash file or 6300 file and install it to C / programme
files/pheonix..after finished this installation open pheonix Inside the interface at the> left top <there you see
"File" click there and choose "open file" and
then select the approprait Product type i.e"which is written in the
back banel inside the battery of every Nokia(Type RM-000).After doing
this again at the left top count from "File"1..2..3..the 4th one is
"Flashing" press there when you click there you'll see three
icon just select the "Firmware Update" again you'll see
another interface.Look at the product code there should be blank and put your
"mouse tool" at the straight end from the "Product Code"
there is a Botton and choose the code which is written in the
back side of your phone.e.g CODE:0000000.if the same code does not found
just take one.After this you can see "Dead phone USB flashing"
click that box.Now this is the last stage... Connect your phone with the USB
to your PC and let the driver install ...wait for a moment.(If your phone working).Lastly after just
finished (In case your phone is Dead,unable to switch on in normal mode start from here) Connect the phone to pc without powering...insert good battery and Click the "Referbish"
after this, a message will prompt you "press power botton"
press it and wait untill the phone will Restart automaticlly in normal mode
10-15 minutes.If you cannot understand just make a Reply thanks for
visiting fixya.Good luck
