Question about Panasonic PT-51G44 51" Rear Projection Television
PT-51G44 I own the same tv. The problems started with the top part of the picture being distorted. The top part of the picture would look as if it were bigger than the rest. Sometimes it would be ok and sometimes it could be fixed by turning it off and then back on. After a while the picture began to smoosh itself into a single white line across the middle of the tv, and now there is just a little collage of colors in the middle of the screen on the left side.
    Genius:
  • Panasonic Master
  • 1,689 Answers
Some of the components in the vertical deflection circuit area, and possibly in some other areas as well, have become thermo sensitive with age and use.
An experienced TV tech can troubleshoot the set to locate the defective parts and change them.
Jerry G.
Posted on May 09, 2008
My Panasonic projection tv has a green haze to the picture and curved lines down the screen
It sounds like you may have a convergence problem.
I will attach a few photos here of typical convergence problems; no two sets look exactly the same but you will know if your problem is like them.
If you find you have this problem I can tell you what is involved and needed for this repair.
Before you rate this information let me know what you find.
SD TECH
Aug 15, 2011 | Panasonic PT-51G44 51" Rear Projection...
I have a Sharp TV 21" is vertically making the pictures stretched. What could be the reason and kindly advice me how to fix it. Thanks very much.
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 24, 2011 | Panasonic PT-51G44 51" Rear Projection...
The picture on my 13 yr old panasonic PT-51G44 ia darkening. Is this fixable or do I need a new tv?
Yes,the tv is fixable.When was the tv projection lamp been inside this tv was replaced in this tv,when was it the last time the bulb was replaced?The last time the probjection lamp was replaced about 1 1/2 or 2 years ago?The tv on an used at leat 4 or 5 hours a day?The projection lamp life is over.Require a new projection lamp.
Aug 02, 2010 | Panasonic PT-51G44 51" Rear Projection...
Expanding picture
Call the service rep who did the work. They replaced the failed parts, but did not find the original cause of the failure. You should tell them that! Replacing the parts without finding the original cause will only cause the present work done to fail again.
Jerry G.
Mar 22, 2008 | Panasonic PT-51G44 51" Rear Projection...
Verticle
Please reset to factory settings, if problem still there check the v-sync IC. all the best, kindly rate this solution.
Sep 12, 2007 | Panasonic PT-51G44 51" Rear Projection...
Panasonic PT-51G44 51 transporting?
No you should only transport it standing up to ensure the optics do not get messed up. I have seen peeps do this and nothing happens. I have also seen pros do the move on the back or the sides and it tears up the TV set. Good Luck
Aug 30, 2007 | Panasonic PT-51G44 51" Rear Projection...
Picture distortion
hope u still have warranty call a pro windman
Jan 30, 2006 | Panasonic PT-51G44 51" Rear Projection...
Panasonic PT-51G44 51" Rear Projection Television Logo
80 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
