Question about Philips 60PW9363 60" Rear Projection Television
Black Screen When I turn on my TV all I get is a black screen. The sound works just fine though. Can someone help me? Galex22
    Novelist:
  • 142 Answers
Can you press the menu button on the set and see the menu? This would rule out power supply board and lamp.
If you can't get the menu screen to come up, try removing the bulb and re-installing it. When you remove it, visually check to see if it's fried. Don't touch the glass on the lamp itself, cuz if it's still good the oils on your fingers will cause it to overheat and pop.
If after you've re-installed the lamp you still get no pic, check the power supply board for a fuse. Replace with the same size if necessary. Remember, fuses blow for a reason... if it blows again, have the set serviced.
Let me know what happens... Please rate accordingly.
Posted on May 08, 2008
I have a RCA L32HD31YX12 TV. The TV works fine for a half hour and then the screen flickers and goes black. The sound continues. If I turn the set off for a half hour, it works again for another half
You have answered your own question, someone needs to open it and find a loose plug or broken solder connection--if it reacts to being tapped on that is the issue- a physical problem inside.
Dec 05, 2012 | RCA Televison & Video
TV was working fine and then the picture has totally gone, just a Black screen as though it is switched off, Audio on all channels are fine and turns over as normal. No Text no nothing on the screen...
solution
step 1 : at first test your fly back transformer
step 2 : A.C. transformer test
step 3: adjust TV yoke coil
Send report :babul_jpi90@yahoo.com
Jul 28, 2011 | LG 50PS60 50 in. Plasma HDTV
How to reset tv. Have sound but black screen
LCD's use a colorful crystal see through display which only visible when light is shining through it. if you have sound and no picture it's always a faulty PSU. Very easy to change out actually.
Mar 27, 2010 | Vizio GV42L 42 in. LCD Television
VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Jan 13, 2010 | Vizio VW42LF 42 in. LCD HDTV
Sharp aquos 32" LCD tv - screen black (no picture) but have sound
Typically if you have a backlight and no video image it's going to be the T-Con board. We do know it's most likely not the powersupply board because the back light comes on. Could also possibly be the main board, but typically the T-con boards are cheaper and I'd say you got a 70% chance that's the issue. Good luck.
Sep 11, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Black screen
you mean no picture just sound?
lost high voltage...... check Horizontal output transitor and flyback.
Sep 14, 2008 | Orion1934 19" TV
No picture but sound works.....
  • adjust brightness setting when playing tv.
  • adjust screen control located on flyback transformer.
  • hope this will help.
Oct 23, 2007 | Sony KV-36FS16 36" TV
Sony WEGA KV-36HS500
you may have cracked the circuit board when moving , sounds like a bad vertical circuit. look for bad connections around vertical ic or flyback transformer
Aug 19, 2007 | Sony FD Trinitron WEGA KV-36HS500 36" TV
LG LCD Tv picture goes black but the sound still works
Next time it goes dark do a flash light test to see if your inverter board is fubar.
May 03, 2017 | LG M4200C 42 in. HDTV-Ready LCD Television
Lcd monitor screen stays black
there may have been some kind of damage to the lcd. sounds like you are going to have to send it in to have it fixed.
Jun 13, 2006 | Casio Exilim EX-S500 Digital Camera
Open Questions:
Philips 60PW9363 60" Rear Projection Television Logo
108 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
