Question about Kenmore Kitchen Ranges
Purchased a kenmore electric range around 1 and 1/2 yr ago ( 790.9437370) and i heard a pop. The heating element appeared that it was burned. My hubby just installed a new one, and again, the oven does not heat up. The stove top does heat up.
  • 139 Answers
Check the circuit breaker for the house ..the breaker prob. blew ..if not ..unplug range ..remove the back panel to view all them wires an switches ..look at all of the wires an connections for burt or broken wires ..if all looks good ...their may be a thermal fuse located where the switches are .. look real good with a flash light ..you will find the problem ..you may need a volt/ohm meter to test voltage ..or thermal fuse ..let me know an good luck../joe/
Posted on Aug 29, 2010
Kenmore electric range model 911.95875790, no heat to either baking and broiler elements.
Hello. I looked carefully at the service manual for your unit--surprisingly, there is no thermal switch inline with the bake/broil elements. Usually, if the bake or broil elements pop, this blows out the thermal switch, killing power to the elements for safety. The main control board can get damaged due to the high current draw during a short-circuit. The part number for the main board is WB27T10008. The overlay(the decorative sticker with the button/names on it) numbers are as follows: almond WB27T10022, black WB27T10023, and white WB27T10021. I hope this helps you!
Sep 18, 2015 | Kenmore Ovens
Oven does not heat up
That pop could have been the element. Check all around the element for a bubble or a large pit/hole. If you don't find anything then check for a burned wire in the back (please unplug the range). Does your range have fuses? If so then check the 30A fuses, but if one is blown you'll have to find the short that caused it, usually a burned wire fused to the chassis or a burned out element. There are many things that could have caused this but these are the most common. Cheers
Nov 09, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I was baking and heard a pop sound and saw a spark before the oven lost all power? What happened?
OOOPPs - not good , If you saw or heard a pop noise + spark then something blew or shorted.
If the 'loss' was quiet then a fuse or circuit breaker can blow without noise or sparks.
This oven has 4 Heating elements (2 on Grill) 2 inside oven , as you were baking it sounds like a heating element.
As this is a US model I'm assuming you are close to a SEARS somewhere, because they advertise parts made for Kenmore -- try this link http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Evaporative-coil-Parts/Model-867813350/0582/1610510/00007536/00001
Ray
Jan 19, 2011 | Kenmore 94210 / 94211 / 94212 / 94214 /...
While using stovetop had turn oven on for a few minutes heard a pop and smoke from back of stove. fuse blown?
It's unlikely to be a fuse. Those are the classic signs of the heating element burning out, in which case you will need a new element. Burnt out elements can't be repaired. If the fan still runs but the oven doesn't heat up, it's your element.
Regards,
BElectric
Nov 30, 2010 | Frigidaire FEF336BC Electric Kitchen Range
I have a 4 yr old kenmore glasstop electric range. Problem exists with the broiler as it comes on when I set the oven to bake.
this is normal
about 8 years ago manufactures started to include the broil element in the preheat cycle to heat the oven faster
it should cycle down once the set temp is reached
Sep 27, 2009 | Kenmore Kitchen Ranges
Parts left over after replacing element!
here is a link to pictures of the assemblies. http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=GJP84902&pop=flush Eric
Sep 14, 2009 | Whirlpool GR399LXHS Electric Kitchen Range
Kenmore 790.9641240, while using stove top power burner (front left) a loud pop was heard and I thought I saw a blue flash (like an arc) above the pan, the next day received a slight electrical tingle...
Tom (Tchange): I also had arc/pop/short of SSB like g_royer. This was preceded over a few days by the Element ON indicator always ON (with all surface select switches OFF). I found the arc marks and burns on the SSB and replaced it. Element ON indicator went OUT, but like you, element no longer heats. I just checked continuity for each of the relays on the Lockout Board. In spite of the error designation on the Wiring Diagram (swapping P3 with P6), I found an OPEN relay for that element. Now to order the Lockout Board, just like g_royer.
Jun 25, 2009 | Kenmore 96422 / 96424 / 96429 Electric...
Oven shuts off
It possibly incompatible heating element installed on the oven that's why it pops up when you try to turn on and heat it..
Feb 24, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Kenmore range
If this range has electric elements in the oven, you may have blown one of the heating elements. Do any of the oven functions work? If you were attempting to BAKE when this occurred, have you attempted to turn on the BROILER to see if it works? If the BROILER still heats up, you may just have a bad heating element. If both features quit working, the problem may be with your Electronic Range Control (ERC) board. Post back with comments and let me know.
Feb 18, 2008 | Kitchen Ranges
Kitchen Ranges Logo
168 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
