Question about Whirlpool Refrigerators
My Whirlpool side/side model # GD5RHAXTSO1, inside refrig. sweats,bottle/can items warm. Please help me, thanks.
    Sergeant:
  • 252 Answers
You have a very simple and enexpensive problem your thermostat dial or the the thermostat itself is bad. Most likely your thermostat need replaceing not the one for your freezer but the one for your fridge. You can call whirlpool during the weekdays order it an install it youself very quickly. Just give them your make and model.
Thanks
Posted on Aug 29, 2010
Whirlpool model et18tk and the side of the fridge gets hot? It it junk?
This is normal unless the refrigerator is not cooling properly. There is a pipe that goes around the door that carries hot Freon to keep the doors from sweating where the cold inside meets the warm air outside. This area will become extremely hot should the airflow below the refrigerator become obstructed or the condenser fan below the refrigerator not be working properly
APPLIANCE 911
Aug 15, 2016 | Whirlpool Refrigerators
I have a Whirlpool refrig./freezer. I have no problem with the ice dropping in the bucket,but when I try to dispense it under the chute,it wil not dispense. The water works fine. This is a side side ...
Sometimes the ice will collect, melt, and freeze into a giant headache. If you have the one where you can get ice out of the holding bin inside the freezer, see if the ice bin will come apart from the rest of the dispenser. If it doesn't come easily, get as much ice out of the bin, get a wet vac ready and pour warm water on the ice. It will run through the dispenser. Once things come apart easily, you can take it over to sink and get rid of the ice blockage with warm water, let it dry, reinstall, and check to see if it works. Hope this helps.
Nov 03, 2013 | Whirlpool 21.8 cu. ft. Side-By-Side...
What does the condensor coil look like
Your model has the condenser below the refrigerator and the condenser is the item number 3 in this photo=> GC5SHEXNQ00_Unit_Parts It is the warm side coil that you feel warm air coming from below refrigerator. The evaporator coil is inside the freezer on your model. Thanks Sea Breeze
Feb 17, 2012 | Whirlpool Gold® GC5SHEXNQ
The molding inside each door is very warm, the outside of the refrigerator is cool. I have a side-by side whirlpool, model ED22PQ. The center strip inside is very warm as well.
That is what is known as "Anti-Sweat" heaters to prevent moisture accumulating on the doors.
Usually there is a switch labeled "Energy Saver" which allows you to turn them off.
Nov 14, 2010 | Whirlpool Refrigerators
Whirlpool Refrig. stopped cooling with no warning. Freezer is freezing with ice build up on back wall. Thanks, Mike Strickland
Mike, Please send the complete model number so I can help you better. If your refrigerator has a defrost timer this could be the problem. You also can visit my site below and enter model or part number in the search feature. We also offer free help and assistance. , Thanks, Sea Breeze seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Mar 29, 2009 | Whirlpool Refrigerators
Condensation in my Whirlpool/Conquest refrig.
the refrigerator has a switch that says something like energy saver or something similar. move the dial or lever off the energy mode and that will bring on a low voltage strip heater around the frame of the unit. it may take a day or two to see results but if you place your hand on the plastic door liner you will see that it is warm and working. in the summer you need this on until the wreather gets cooler in areas where it's warm all winter you may have to keep it on allyear. what this does , when the heater is on it warms the plastic mouldings around the unit so there is not so much of a difference between the fridge/freezer and the room temperature. hope this helped
Jan 27, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool ultraease warm on left side, dispenses warm water
not dangerous, i would recommend vacuuming coils under and behind refrig, make sure the fan behind the unit( cooling for compressor) is running full speed. the water is probably "warmer" then usual because the waterline runs across the bottom of the refrig, which appears to be overheating as it is. this should rectify your issue
Nov 20, 2008 | Whirlpool ED2FHEXNS 21.8 Cu. Ft....
Ge refrig model ziss480dmbs
hi thanks for the question there is a switch inside the fridge called a humidity switch it must have been shut off its located by the freezer fan cover thanks please accept with a positive feed back thanks the appliance doc
Sep 23, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Old GE refrig is sweating /dripping inside
If you run a 5 inch or so piece of aluminum wire from the defrost heater into the drain hole after you defrost the freezer that should fix the problem for good!
Nov 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
71 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
