Question about Dell Dimension 4600 PC Desktop
Hooking up a microphone to a computer
Hi Mark - I'm having trouble hooking up a microphone to a computer. I can't get any sound from my speakers when I do and no one can hear me when I call on Skype. I have a Gembird microphone. Is this the right one? Thanks.
  • 472 Answers
Any mic is fine. You will have to enable it in the sound mixer though.
Goto..
Start - Control Panel - Sound
Select Recording and then select Microphone.
Select Configure at the bottom of that window.
The next window will open and you will see Set Up A Microphone.
It will walk you through setting it up and making sure it is active.
Posted on May 08, 2008
Front 4 usb ports and microphone and headphone jacks don't work but the rear usb and speaker jacks do work. I've had the computer new since 2009 and they have never worked.
it sounds to me like the wires from the front panel connectors are not connected to the motherboard inside the computer case, open the case up find the front connectors wires inside and find out if there are any connectors on the motherboard to plug them into.
the reason the rear ones work is because they are soldered directly to the motherboard.
good luck.
Jun 28, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
Tip
How to identify speakers on surroud sound system whe hooking up.
Most people will try there best to mark the speaker wires on their speaker system when they run them. That can be a big pain and if you don't mark the with a simple system it can be confusing. It will be more trouble if you did'nt mark the wires when you ran them. I have a very simple solution that works well. You don't need to worry with marking the wires at all. The easy way to identify the spearker you are hooking up when you are installing a system is to use a 1.5 vdc D cell battery. You may ask, why a D cell battery? It is pretty simple. If you have connected the wires to the speakers.With the + (possitive)terminal connected to the side of the speaker wire that is marked with a stripe. Sometimes the stripe is white or black and sometimes no stripe at all. If it does not have a stripe it will have small ridges along the side of the wire. Stripe or ridges we call that the tracer. Place the wire with out a tracer on the - (negative) terminal of the speaker. On the other end of the wires youwill need to strip the insulation from the two conductors of the speaker wire. Hold one of the wires to the - (negative) end of the D cell battery. the +/- indications are located on the side of the battery. The bump on one end of the battery is normally the + (possitive) end of the battery. Touch the other wire to the + (possitive) side of the battery for a second and remove. Repeat this several times and note the poping sound the speaker make. Listen for the location of the speaker that is poping. Hook the speaker to the terminal on the amp that matches the location of the speaker that pops. Move to the next speaker and repeat. Do not worry this action will not harm the speakers. They will see much more than 1.5 vdc when you drive them with the amp. The next time you need to install speakers try this tip. You can use it in every installation and it will speed the install process. I hope you find this very heplful.
on Aug 30, 2010 | Audio Players & Recorders
How do i hook up speakers? the light on the speaker is green and when i plug them in i get some pop up asking what device i plugges in.. in and out, line, mic, headphones.. help
you will need to connect your speakers to your computer then you will need to install them to your computer
usually at the back of a desktop computer there is three input plugs blue green pink/red or a usb connection depending on your speakers on a laptop usually a usb connection
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
also click start control panel sounds and audio devices then select voice then select volume from the microphone you can increase the volume or you can test your hardware in XP in W 7 click start control panel hardware and sound manage audio devices recording right click on microphone you can configure speech recognition
or you might have to boost
hope this helps you
Aug 30, 2011 | Acer (90.18612.36B) Computer Speakers
Having trouble hooking up logitech surround sound system
Hi , just make sure that your PC has a 5.1 Channel Sound Card that can handle that Surround sound system
Thanks
Dec 28, 2009 | Logitech G51 5.1 Multimedia Surround Sound...
My Dell AS501 does not produces sound. I have
make sure the power is hooked to the back of the monitor, and that the speakers are hooked into it. make sure it is switched on and volume is at 50% or higher. if it still doesnt work, try hooking an mp3 player to the speaker jack. if they work, its the computer. if it doesnt work, replace the speakers.
Dec 12, 2009 | Dell AS500 Sound Bar Computer Speakers
Where is the sound in./out for hooking up external speakers
Look at the front and sides of the laptop for the headphone and microphone jack ports.
Some of them are coloured Pink for the microphone and green for headphone (audio out). some of them are also black.
Good luck.
Sep 30, 2009 | Dell Latitude D600 Notebook
Trouble with speakers (Samsung 2.1) to 52" sony bravia lcd
that is the simplest way. please rate, thanks and have a good day
Aug 25, 2009 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
Hooking up speakers.
Speakers do not normally connect to a microphone jack.
But if it has a headphone jack usually has a symbol like one of these.
http://symboldisco.wordpress.com/2009/02/
Then you could use that as the output to your speakers.
also if it has phono outputs on the back similar to these
http://www.smcelectronics.com/AUDCONN42.JPG
and they are marked nearby as OUTPUT you can also use those
Quality of sound will vary depending on the speaker quality itself.
if you have surround and any of the outputs as shown then with a little care it is still possible to hook up to that.
Don't try to connect INPUT sockets to speaker it will just not work.
You didn't give a specific model so I have only been able to give a generic answer.
Aug 18, 2009 | Emerson Televison & Video
Install cd for monsoon
What makes you think you need special drivers for your Monsoon speakers? Do other speakers work properly when hooked up to your PC? Borrow a pair from somebody else if you don't have any other speakers you can try, and check. If they don't work either, Monsoon drivers are not your problem. I'm not saying nobody ever needs drivers for speakers to work with a computer, but normally, drivers for the speakers are not the issue if you're not getting sound through them.
The sound card driver and sound settings in BIOS, sound settings in Windows and for the sound card, and physical issues about the way the speakers are hooked up or whether the speakers themselves are functional are much more common sources of trouble than drivers for the speakers.
Start your troubleshooting process with this webpage:
http://www.computerhope.com/issues/ch000034.htm
If that one doesn't seem to address your issue, try websearching for other options with a phrase such as: troubleshoot no sound PC speakers.
May 31, 2009 | Audio Players & Recorders
Logitech Z-5500, no sound coming out
Hi there, Mr Dan
Happy Holidays
well, you can change, the coaxial cable for another optical? is better, if you got an optical input. or optical output to input on your SPK. that should work.try the test with a movie on.or sound continue.
Dec 18, 2007 | Audio Players & Recorders
Dell Dimension 4600 PC Desktop Logo
670 people viewed this question
Alun Cox
