Question about Whirlpool GEW9250 Electric Dryer
The control lock light stays on an dryer does not do any thing
  • 347 Answers
Push and hold the cycle volume selection button on bottom right side of the control panel for 3 to 4 seconds to unlock the control panel.If this does not work repost with what happens after unlocking the panel Hope this helps
Posted on Aug 30, 2010
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
Control Panel Kenmor Elite HE4
that sounds weird to have all those lights on...
first thing is to try and remove the "lock"light...
push and hold the button, for 5 seconds, below the "lock" light,
that should get the control back to normal operation. then if you still cant get the unit to turn on, try to unplug the dryer for a few minutes.
if you still cant get it to turn back on, call sears "customer service" and complain since your machine should not have failed at this early in its life.
Sep 15, 2009 | Kenmore Elite HE4 Electric Dryer
Controls locked status light stays on and dryer cannot be used
To enable the control lock feature:
Press and hold the CYCLE SIGNAL button for 3 seconds. The
CONTROLS LOCKED icon lights up, and a single beep tone is
heard. To unlock, press and hold the CYCLE SIGNAL button for
3 seconds. The indicator light turns off.
Jul 11, 2009 | Dryers
Control locked
should be a small button on the left at the bottom of the controls, should say to hold it for a few seconds to unlock i know this because i did the same thing good luck
Mar 30, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Kenmore HE 2 Dryer
sounds like the problem is in the user interface(pushbuttons and knobs)check your warranty some models came with 2 yr warranty on electronics
Aug 25, 2008 | Kenmore Elite HE4 Electric Dryer
The controls locked light will not go off and I cannot get the dryer to turn on or get any controls to work. Help!
look closley at the far right buttons on control panel, the very bottom far roght button says control lock. hold in for 3-5 secs and the control lock will turn off. its a child satefy thing
Mar 13, 2008 | Whirlpool GEW9250 Electric Dryer
The Control Locked Light stays on and nothing else works
Is this like a child lock?? if so holding the appropriate button down for upto 10secs is the fix. is the control locked? it not its just the diode circuit which is faulty and will not effect the operation
Jan 01, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Dryer GEW9250PW0
the control panel is bad / it is also called a user interface
Nov 20, 2007 | Whirlpool GEW9250P Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
53 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
