Question about Samsung LN32A450 LCD Monitor
I have a Samsung series 4 450 model code LN32A450CIDXZA. The picture is a color negative, all inputs and menus are negative. The over all hue is white. I called Samsung and they gave me a service order of 4007121176 and said someone would call, that was about a week ago. Do you have any idea what is wrong and how much it will cost to fix? I purchased the TV Dec 2008.
The romote is locked up how do you unlock it
Posted on Sep 05, 2010
How do I set the picture to full screen?
What are you trying to watch? If you are looking at a cable TV box or DVD player through an HDMI input, you will have to adjust the settings in the cable box or DVD menus to match your tv's HDMI input capabilities.
Aug 02, 2016 | Samsung HU8550 Series UN55HU8550 55" 4K...
What part needs replaced when the picture looks like a photo negative?
T'Con board fault. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 08, 2015 | Samsung 6350 Series UN55F6350 55" LED...
How can i adjust colors in konica c450
HI ganesh,
Instructions
    • 1Go to the Application screen on the LCD panel located on the printer and press on "Edit Color." Press on "Color Adjustment."
    • 2 If unhappy with the hue of your copy, press "hue." Look at the 'hue" screen and press the arrow keys in the direction you wish to change the color hue. Press "Sample Copy".
    • Sponsored Links
    • 3 Take a sheet of paper and place in the top left corner of the glass surface of the Bizhub. You will see that the area is marked "Sample Area" alongside the glass area. Press the "Start" button on top of the Bizhub.
    • 4 Wait for the Bizhub to produce a sample sheet. Look at the finished sample sheet -- there are six options showing three incremental "plus" hue options and the three incremental "negative" hue options. Select the one you like and press to confirm the required hue adjustment on the "Hue" screen. You have now calibrated your colors as desired.
Read more: http://www.ehow.com/how_7590176_calibrate-colors-konica-bizhub.html#ixzz316wHLgOK
May 08, 2014 | Office Equipment & Supplies
Samsung DLP model#HLP4663w.green hue on the screen,what is the solution to my problem.
Hi,It sounds like it could be the color wheel or DMD.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises. The DMD is another possibility.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q One simple test is to display menu and if it's affected then most like will be an issue w the DMD board.Found the complete set with color wheel and DMD included here: http://www.discount-merchant.com/SAMSUNG-30407272050-Light-Engine-w-Color-Wheel-p/1139314.htm Have a blessed one!
Apr 05, 2010 | Televison & Video
Color section in tv receiver
can I know what is the answer for that question.
Feb 23, 2010 | SAMTRON 96B 19" CRT .22MM 1600X1200...
Green hue
Hi,If you are experiment hues,color distortion ,black and white picture,hear buzzing high pitch sounds, it could be time to replace the color wheel.Your part # will be BP96-00250A you can find it here: http://www.discount-merchant.com/Samsung-BP96-00250A-ColorWheel-Assembly-p/bp96-00250a-color-wheel.htm? and here's the instructions to replace it: http://www.fixyourdlp.com/guides/samsung/bp96-01579a.php Have a blessed one!
Feb 19, 2010 | Samsung HLN467W 46" Rear Projection HDTV
Toshiba 65H80 has yellow hue.
Check you HD inputs or source. Sounds like the red stream is missing; maybe a loose cable.
Nov 17, 2008 | Toshiba 65H80 65" Rear Projection...
Screen color is purple
if you have access to another monitor use if to verify the monitor is the problem and not the video card of the computer.
does the monitor allow you to adjust color and tint(hue) because the tint or hue control changes the overall color from green to purple. or the color control circuit has failed leaving you stuc with a purple screen.
Dec 26, 2007 | Dell E176FP 17" LCD Monitor
Samsung 61 inch DLP
Needs color wheel. What's the model #?
Oct 27, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Samsung LN32A450 LCD Monitor Logo
494 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
