Question about Intel Motherboard
GA-8S648FX-L MOTHERBOARD HI,WHEN I HAD 2GB OF MEMORY AT STARTUP IT WAS DDR400 AND I PUT ANOTHER IGB OF MEMORY ,TOTAL OF 3GB ALL KINGSTONE AT STARTUP ITS 333DDR????HOW CAN RESET IT OR REPAIR THIS MATTER.THANKYOU
  • fuck 2253 May 08, 2008
    hi,the 3 of them are pc3200 kingstone???
Was your 1gb stick DDR PC2700? Most likely that is why. Although the pin set are both 184 pin, you will be downgraded to the lowest speed available, meaning PC3200 (DDR400) will downgrade to PC2700 (because PC2700 can't be upgraded to PC3200).
Posted on May 08, 2008
Necesito el manual de la placa base 8s648 fx-rz
you find it at: www.gigabyte.com or in www.gigabyte.eu
Mar 27, 2012 | Intel Gigabyte GA-8S648FX-RZ Socket 478...
I have a toshiba satellite A135-S4467 laptop, using two memory slots, totaling 1G. I've bought a Kingston ValueRAM - 2GB PC2-6400 DDR2 Laptop Memory Module. What is the best way to install my new 2G...
Hi, Yes, it would be best to take the old RAM out. I am assuming that this is 1 stick totalling 2GB. Optimally it would be good to have 2 x 1GB modules totaling 2GB, so they could work together. Otherwise, yes, just remove the the old ram and install the new module. If you are running a 32bit operating system, 3GB is all the system can use anyway. Hope this helps!
Jul 13, 2011 | Computers & Internet
Hi Could you please advise the type and size of
According to the manual, to max out the board's RAM you'd need to install 2 1GB sticks of DDR RAM. It can support DDR400/333/266. 2GB is it's maximum capacity.
Jul 09, 2011 | Intel Motherboard
DOES GA-945GCM-S2C SOCKET LGA775 SUPPORTS 500GB HARD DISK AND DOES IT SUPPORTS 2GB DDR2 RAM
GA-945GCM-S2C
Memory Support:
__2x1.8V DDR2 DIMM sockets supporting up to 4 Gb of system memory.
Note:Due to Windows Vista/XP 32-bit operating system limitation, when more than 4 GB of physical
memory is installed, the actual memory size displayed will be less than 4 GB.
__Support for DDR2 667/533/400 Mhz memory modules.
Note:Use of a 1066/800 MHz FSB CPU is required if you wish to install DDR2 667 MHz memory!
Storage:
South Bridge:
- 1 x IDE connector supporting ATA-100/66/33 and up to 2 IDE devices
- 4 x SATA 3Gb/s connectors supporting up to 4 SATA 3Gb/s devices
iTE IT8718 chip:
- 1 x floppy disk drive connector supporting up to 1 floppy disk drive
Dec 03, 2010 | Gigabyte GA-945GCM-s2C socket LGA775...
Where do i put he memory
From the manufacturer's web-site:
http://www.msi.com/index.php?func=proddesc&maincat_no=1&prod_no=557
look at the "green" slots in the picture of the motherboard.
That's where the RAM goes -- note that the RAM has a "notch" that is *NOT* in the "centre" of the stick; so, the RAM only fits *ONE* way into the slot.
On that web-page, it says:
• Supports six memory banks using three 184-pin DDR SDRAMs.
• Supports up to 3GB memory size.
• Supports DDR400/DDR333/DDR266/DDR200 SDRAM
Note: PC3200 (DDR400) maximum 4 banks only.
So, if you buy DDR400 RAM, the maximum is 2GB (2 sticks @ 1GB/stick); if you buy DDR33 RAM, the maximum is 3GB (3 sticks @ 1GB/stick).
Dec 01, 2009 | MSI Microstar KT6 Delta (MS-6590)...
My PC won't work with 3Gb of RAM
THE RAM CAPACITY OF THIS BOARD IS
DDR266/200, Max. capacity of system memory: 3GB
- DDR333, Max. capacity of system memory: 2GB
- DDR400, Max. capacity of system memory: 1GB
Oct 03, 2008 | Asrock K7S8X-R3 Motherboard
Memory card replacements in two PC-s.
Computer 1 = DDR400 Memory
Computer 2 = DDR400 Memory
Dude, next time you should try http://www.google.com
Sep 25, 2008 | Gigabyte Computers & Internet
3x 1GB DDR400 Problem on booting!
the details for your case can be obtained in this site.....................
http://www.memory4less.com/m4l_results.asp?ref=mem&modelid=800121
read carefully to understand the limitations that arise with your motherboard.
cheers....................
Jan 22, 2008 | ASUS P4S8X Motherboard
Intel Motherboard Logo
57 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
