Question about Linksys Wireless-N WRT150N Router
While cleaning my room I unplugged my Linksys WRT54G router and my high-speed modem, and unplugged all the ethernet and power cords as well from the backs. After I plugged everything back in, I no longer had internet access. My wireless network was still broadcasting, but the local area network was gone. In an ignorant effort to fix things, I pressed the "reset" button on the back of the router, which didn't help. I then called RCN (my internet provider) and they found that my computer was running a bad IP address. They helped me reset the IP address, which fixed the local area connection, but only as long as I plugged my computer directly into the high-speed modem. As soon as the wireless router is made part of the loop, the connection fails and the computer again assigns a bad IP address. I've called Linksys and they seem to think the problem is fixable, but since my warranty just expired they want to charge me for over-the-phone support. Please help! Thanks.
  • elchoclo Aug 30, 2010
    Problem solved! I reset the wireless router to factory settings (by holding the reset button for 30 seconds--something I hadn't known to do when I fiddled with the 'reset' button the firs time), and then reinstalled the router and accompanying CD-Rom software from scratch.
    Scholar:
  • 121 Answers
If you unplugged your modem then you will have to set it back up which includes putting in your current IP address. The steps are in your user manual and you will need the following information to set it up. If you know the web address for your router you can get the info from that, if not then you will have to contact RCN again. You will need the IP Address, the Gateway address, both primary and secondary, also the subnet mask. But all of that should be explained in the user manual. I would suggest reading it first, writing down the numbers needed and then set it up.
Posted on Aug 29, 2010
    Thank you, fish8037! I managed to solve the problem by resetting the wireless router for real (this time I held the reset button for 30 seconds, which did the trick), and then reinstalling the router and accompanying CD-Rom software from scratch. But if I ever have modem trouble I'll know what to do.
HOw do I connect my linksys router to my Motorola modem and computer?
internet cord> motorola modem> lynksys router> computer via ethernet cords
i have the same set up
dont be afraid to mess around alot and repeatedly pull out put back in cords and reset the modem and router...also internet explorer will help you troubleshoot and fix poblems for you
Apr 21, 2011 | Linksys Wireless-G WRT54G Router
How to configure Linksys WRT54G router with BSNL's C2110 modem?
The Linksys WRT54G broadband router is one of the most popular consumer routers there are. Linksys makes configuring your router easy. This article will walk you through the initial setup options for this particular model, but many of the basics we talk about here can be applied to any router setup. Setting up the router consists of four basic steps, such as Testing your Internet connection, connecting your hardware, setting up the connection and power cycling the entire network. Aside, from setup, we'll also describe some security concerns so you can make an educated decision on the administration of your home network.
Test Your Internet Connection First While this seems like something you would not need to be, make sure your Internet connection actually works. If you haven't already, plug the cable modem directly into the back of the computer and make sure you can get onto the internet. You may need to reboot the machine first.
Connect The Modem and Router to the PC Now that we have confirmed the Internet connection works, the next step is to connect the modem to the router and the router to the PC. The modem will attach to the router's Internet Port. You will then attach the router to the PC via any of the four Ethernet ports in the rear. Check the LED lights in the front of the router to confirm all of the connections are properly made. The Power, WLAN, Ethernet Port to PC and the Internet should all be lit.
Configure The Linksys WRT54G Settings With all connection made, you will now need to login to the router via your web browser. Type 192.168.1.1 and hit enter. You should see the login screen. Leave the username blank and type admin as the password and hit enter.
You will now need to configure the router's connection to the Internet. Under the Setup / Basic Setup section, make sure the router is setup to Automatic Configuration - DHCP. This allows the router to receive an IP address from your Internet Service Provider.
Next, go to the MAC Address Clone tab in the same area and enable Mac Address Cloning. This allows the router to clone your PCs MAC address, as the ISP may require this.
Power Cycle the Router and Modem Now that everything is configured, you'll want to power cycle everything. This is done to make sure everything has an IP address from the modem all the way through to the PC. To power cycle, shutdown everything. Unplug the modem and router power source. Shutdown the computer. Plug in the modem and wait for all green lights. Next, plug in the router and wait a few minutes until its lights are also green. Lastly, boot up the PC. You should have an Internet connection.
Change the Linksys WRT54G Router Password You noticed when setting up the router, that there was a default username of nothing and a password of "admin." Be sure to log back into the router once everything is running properly and type in a username and change the password. If you don't, a hacker that sees you have a WRT54G router could login to the router with the default credentials.
Jan 10, 2010 | Linksys Wireless-G WRT54G Router
Linksys wrt54g SRX200. I can connect to my router
It appears the connection between the Linksys and the modem is not working.
Try a different LAN cable.
Check the LAN cable from the modem to the Linksys, it should be connected to the WAN/Internet port on the Linksys.
Dec 19, 2009 | Linksys Wireless-G WRT54G Router
Ethernet won't reconise modem for xbox live
Once you have everything hooked up:
Ethernet cord going from modem into wireless router in port labelend internet or wan, and an ethernet cord going from the router to the xbox you should try these steps:
Unplug the power cord on the modem and plug it back in- once all the lights come back on
Unplug power cord on router and plug it back in-
Hope this helps.
Apr 07, 2009 | Linksys Wireless-G WRT54GS Router...
How do i reconnect linksys
Oh man your going to have to help me out a little on this one. Do you mean you had to unhook it and connect directly to the modem and now you want to hook the router back up? If thats the case Unplug all the devices (Pc's modem and router) connect an Ethernet cable from the ethernet port on the back of the modem (not the linksys) to the internet ethernet port on the linksys (usually set a little apart from the rest) then connect all the computers to the routers ethernet ports (usually labeled 1-4) then turn on power to the devices starting with the modem, wait for it to completely boot up all the lights like they're supossed to look. Then turn on the router and wait for that to finish booting up then all of the computers. If you have wireless devices that will take a little more help.
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Can't connect Motorola sb5100 to a Linksys wrt54g
Make sure that you have the ethernet cord from your modem plugged into the WAN/Internet port on your router. Then unplug the power cord from your cable modem and plug it right back in. After the modem fully comes back online, unplug the power cord on the wireless router and plug it back in. wait 30 - 60 sec and then try and connect.
Most cable companies only allow one active"CPE" at a time for internet access. All this means is when you change what is connected to the cable modem you must always reboot the cable modem to allow access.
Hope this helps. Let me know if it does not work.
Please Rate
Jan 29, 2009 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
After successful instn of my linksys wireless router i cannot access to wireless online connection
Whenever you connect a different device to the cable/DSL modem the modem itself must be reset. Dont even waste a phone call to linksys. Its useless.
If you are using DSL depending on your ISP you may have to enter your account info into the router's PPoE section
Cable users should have the router set to "Obtain IP aadress automatically"
Use the reset button on the back of the router and start from scratch.
Unplug the cable/DSL modem power
Hook up your router WAN/Internet to the Cable/DSL modem Ethernet/LAN jack
Power on the Cable/DSL Modem first, wait about a minute, then power on the router.
Sep 25, 2008 | Linksys Wireless-G WRT54G Router
Wrt54g
To setup your router manually click here
Dec 17, 2007 | Linksys Wireless-G WRT54G Router
Linksys Wireless-N WRT150N Router Logo
328 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
