Question about Norelco 8170XLCC Electric Shaver
My shaver head broke! PLEASE HELP ME!
The entire head of my shaver pretty much just fell off. all the parts are together but i dont know how to put them together. PLEASE HELP ME!!
  • Anonymous Nov 20, 2008
    same
I just fixed my husband's razor. I took everything out and washed it all. Then I took the three things that touch the skin and put them in the three holes so that they fit comfortably. Then I put the sharp parts inside those thin parts. The I took the gray thing with three holes and snapped the little brown thing to it and turned the arrows on the brown thing so it snapped it securely to the things with holes. Then I put the head onto the handle by sliding the hook into it's hole, than brought the head onto the handle and snapped it shut. It fell apart the first time I tried it but I put it all back together and after that it worked like a charm.
Posted on Oct 15, 2009
MY DAD DROPPED HIS PHILIPS 7300 SERIES AND THE SHAVING HEADS FELL OUT NOW WHEN WE THINK WE'VE PUT IT BACK TOGETHER , THEY WONT SPIN ANY IDEAS PLEASE.
Sounds like one of the heads are damaged or something is not put together correctly causing it to jam. Watch the video below to make sure that you have the heads in correctly.
http://www.shaveroutlet.com/philips_norelco_heads_replacement
If you have everything in correctly and it stll jams, one of the heads is likely damaged. You can remove them individually and turn the blade clockwise inside the comb with your fingers. Each should turn freely. If any will not turn, you will need to replace them. You will find replacements for 7300 series shavers at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq8-spectra-sensotec-replacement-heads-p-251.html
May 04, 2011 | Philips Philishave Cool Skin HQ6760/HQ...
The spring has fell out of the head when i was changing top i dont know how it goes back together
pull the black thing with the little blades until it detach, put the spring inside the hole, reassemble
May 09, 2010 | Braun Silk-epil 3370 Epilator
I dropped the razor and the 3 heads fell off, nothing is broken, but I can't figure out how to put it back together Help!
all you have to do is put them back in there place you should have two legs that spring out from the blades align them with the 2 holes on the shaver and push them in
Oct 21, 2009 | Philips Philishave HQ8150 Electric Shaver
Fell apart..help please!!!
The larger white pieice that has holes in it should be connected between both the spring and the smaller razor, The bottom of the larger white peice has to be able to fit in the peice of medal that moves in a circular motion inside the top part.
First, Try to make the hooks of the spring go in pretty securly inside the small holes. The flat side of the white peice has to be connected to the flat side of the smaller razor. They should kinda snap together on the top hole. I had to gently place the parts together and push the larger white peice in the medal by placeing the larger razor peice right on top and pressing down really hard. You might hear some snapping but the peices should all connect together and the large medal peice should connect to the black groves and press hard. Hold in place while putting the screws back in.
Jun 21, 2008 | Conair GMT182CS
Norelco 8170XLCC Electric Shaver Logo
526 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
