Question about Goodman PHKJ048-1 Air Conditioner
Fan not running - Goodman PHKJ048-1 Air Conditioner
  • Goodman Master
  • 43,501 Answers
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Aug 29, 2010
My coolin fan wont come on wat should I do
Cooling fan is controlled by a relay and a temp sensor. You need to check that each piece is working.
Run power to the fan. fan run? fan ok.
Bridge the relay. Fan run? run power to the relay coil. Fan run? relay good.
find temp sensor. replace.
May 29, 2015 | Cars & Trucks
Heater fan runs for a few min then shuts down
Check the afc Automatic fan control is shut off too soon .
Apr 29, 2017 | Vulcan Heating & Cooling
Compessor is running hot, fan is not running
need to know brand and model. which fan was replaced ( evap or cond ) . if evap fan it may be the door sw as some model only run fan wth door closed. if it's the cond (fan) motor then ck wiring at compressor . or borken wire. in or about the compresser area .. hope thes help . mm
Jul 05, 2010 | Refrigerators
Fan will not come on.
The fan has to run if the compressor is running as the fan assists in removing the heat from the condenser coil. Can you spin the fan by hand? If there is full power(120 volts) to the fan and it isn't running then the fan motor is bad. Also, if the fan motor has a run capacitor this could keep the fan from running(if the capacitor is defective) so look for this first.
Nov 15, 2009 | LG LHD45EL Dehumidifier
I have a 2005 Jetta 2.5 and it seems like one fan runs to fast
One fan should run when engine is running. Other fan should run when AC is on.
Jun 28, 2009 | 2005 Volkswagen Jetta
My condensor fan is not running. I looked in the
Hi, Check voltage to the fan. The fan will only run when the compressor is running. If you have voltage to the fan whilr the compressor is running, replace the fan.
I hope this helps. If I can assist you further, please let me know.
Thanks
Vic
May 14, 2009 | Frigidaire FRS26R4A Side by Side...
03 Mini Cooper Power Steering Fan will not run
2006 mini cooper s power steering fan seezed. replaced with new fan won't run?
Mar 30, 2009 | 2006 Mini Cooper
Cooliant fan not running
The tempature switch for the fan will be located on the radiator tank, most likly near the bottom or mid way up. It will have two wires in most cases.
With the key on but the car not running, connect these two wires together. If the fan runs, replace this radiator switch.
If the fan does not run, pull the connectors apart going to the fan itself. Jump power and ground to each of these two wires. If the fan does not run, the problem is the fan. If it does run, the problem is most likely the relay for this fan
Good Luck!
Feb 09, 2009 | 2001 Kia Rio
2001 Jeep Grand Cherokee Radiator Fan Doesn't run
Have you confirmed the fan has a good ground, sounds like you have eliminated the issue of 12 volts, when you turn on the fan then the AC does the compressor run? if the compressor runs pull the plug to the fan motor and check to see if has 12 volts with a test light, wait for moment because the fan may not run until the AC system pressure reaches a certain pressure point, this means that even though the compressor is running the fan may not always run, There is a quick test for the fan circuit, disconnect the fan sensor at the thermostat housing, the fan should come on, this is failure mode, so if the switch goes open the fan will run to keep the engine from overheating , let me know after the tests are run.
Dec 01, 2008 | 2003 Jeep Grand Cherokee
Heating & Cooling Logo
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
