Question about Kenmore Kitchen Ranges
We have a ceramic top kenmore stove with self cleaning oven. I turned on to clean and it started smoking. I turned it off. Later cooked some ribs. Then tried to turn oven off and it would not turn off. F1 showed in the window where temp. shows.
We just had the same problem. We've had previous problems with this oven (the power cord actually burned and had to be replaced). We have decided not to have it serviced and just bought a new oven of a different maker. What happened to yours? Did you get it serviced?
Posted on Sep 05, 2010
How complicated is it to fix the control panel on a Kenmore self cleaning oven with ceramic top stove? It was bought in 2003 and I'm not sure of the model# I'm trying to decide if it is something I should...
if u try putting in ur question in google or youtube, with ur brand name and what u want to do? replace top panel in kenmore stove? u should get several results
Mar 05, 2015 | Kenmore Ovens
How do you start the self cleaning oven process on a kenmore stove purchased from Sears in 2009?
  1. Empty the Oven
    • Take everything out of the oven. Remove the racks and clean them with soap and water in the kitchen sink. Look for any loose debris such as foil or charred food and remove that as well.
    Oven Cleaning
    • To operate the self cleaning mode, find the switch on the range marked "Clean." The oven door will lock once the cleaning operation has started. Do not open the door until after the self-cleaning process has completed. It will take between two and three hours.
      During the cleaning process, you may see and smell smoke. This is normal because the oven is operating at a higher temperature than when it is cooking. The high temperature is reducing all the organic matter in your oven to ash. You will also sometimes hear popping sounds from the oven that is caused by the expansion of metal under extreme heat. This is normal for a self-cleaning operation.
      After the oven has completed the cleaning cycle, allow it to cool for a couple of hours. Once cool, take a damp dish cloth and remove the ash from the bottom of the oven. Wipe down the interior of the oven door and around the seal. Be careful around the seal so you do not damage it. Replace the racks back in your oven, and the cleaning operation is complete.
    Other Considerations
    • Clean your oven at least once every three months. If your oven gets heavy use, consider cleaning it once a month. Always run the self-cleaning cycle when you are home. Because it uses intense heat, it is best to perform this operation later in the evening or early in the morning.
Aug 10, 2011 | Microwave Ovens
Ihave a ge ceramic top stove,everytime I self clean the oven it stains in the front of the oven get worse.I have tried everything.My stove is bisque and the stains are an ugly yellow.
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Jan 06, 2010 | KitchenAid KESC307 Electric Kitchen Range
Kenmore Elite Oven/Stove Fire Hazard?
F05 has to do with the self cleaning mechanism. I know it goes with out saying, but sparks and smoke are a bad thing. i would strongly suggest turning off the breaker and calling in a service person.
Smoke means extreme heat or FIRE is melting something..
Please be safe and have it fixed..
Oct 23, 2009 | Kitchen Ranges
Have a GE Electric Cook Top oven with digital
Unplug the stove. plug back in and program a short clean cycle. If this does not fix it is eithe the selector switch or the electronic control. Verifying the switch contacts with a meter is the only way to be sure.
Eric
Jun 21, 2009 | Ovens
Accidently started clean, food inside,hit cancel,can't open
you would have to disassemble the cook top in order to get the the locking mechanism to manualy unlockit
May 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Self cleaning oven directions
MAKE SURE OVEN IS EMPTY LOCK OVEN DOOR AND TURN OVEN SETTING TO CLEAN, IF YOU HAVE A VENT TURN IT ON THERE WILL BE SMOKE! LET RUN TWO HOURS,TURN OFF,LET COOL BEFORE TRYING TO UNLOCK IT (WILL NOT UNLOCK WILE STILL HOT!) OPEN DUST OUT ASH ITS CLEAN!!!
Dec 07, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
My KERS 807 SSS Stove works fine but not oven
sonds like a bad hightemo thermostat, loacted on the back wall behind the rear panel, common issie for ovens ,espessially after going through a self-cleaning,part number 9759242, part is about $50 turn off power before attempting to change, LIVE WIRES!!!!
Nov 30, 2008 | KitchenAid KERS807SSS Electric Kitchen...
Frigidaire ceramic top self cleaning stove
Have you thought about reading the manual, it states that the heat goes off and on to maintain the proper heat while cooking, You should turn the burner off a few minutes before done because even on off the burner is still cooking while it is cooling down to go off. And you do not need to have as high of heat to cook that's what so great about this ceramic tops you save time and energy.
Jun 26, 2008 | Kitchen Ranges
Kitchen Ranges Logo
127 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
