Question about GE (PSS26MSRSS) Side by Side Refrigerator
Our frige and freezer keep warming up. The Ice in the ice maker melts and then refreezes, causing our freezer to fill up with icicles. This has been happening for about a week now. We moved about two weeks ago, but nothing happened to it on the move, that I know of. It is a side by side that is probably about 3 years old. Please let me know if there is a solution. Thanks
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Posted on Aug 29, 2010
Sometimes ice melts in ice maker. Water drips down and refreezes.
There is a heater built into the ice maker bottom to help release ice cubes from the machine. Under normal conditions the heater only come on when the ice maker starts to run and then jambs against the frozen cubes. When it stalls and jambs against the frozen ice cubes, the heater comes on to melt the cubes enough. I think you have a defective ice maker and the heater is coming on to much or at the wrong time, Since your temps go back to normal with the ice maker turned off, I am almost sure thats your problem.
Mar 16, 2015 | GE Profile PSC25MSWSS Stainless Steel...
I have a Kenmore top freezer. Every few days the freezer will get warm enough to cause the ice in the ice maker bucket to melt a little and then it will refreeze into a big block of ice when the...
Hi, It is sticking in the defrost mode...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 13, 2011 | Kenmore Top Freezer Refrigerator
Clicking noise in freezer I am assuming to try to make ice, no ice being made?
Hi and welcome to FixYa, I am Kelly
Ice makers can stop ice production due to poor air flow though the evaporator coils or through the failure of the ice maker module. If your certain the clicking noise your hearing is from the ice maker itself here is are some steps that you can use to troubleshoot the ice maker:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
This step from the above link is important:
TEST PROCEDURESIce Maker Plugged In To PowerShut-Off Arm Down-Freezer Cold
Test points L & N will verify 120 volts to Ice Maker module.(Make sure your test probes go into the test points 1/2".)
Test points T & H will verify if the bimetal thermostat is open or closed.
Short T & H with an insulated piece of wire ( 14 gauge) to run the motor. If the motor doesn't run, replace the module assembly. If you leave the jumper in for a half of a revolution, you can feel the heater in the mold heat up..if it's good.
Remove the jumper and the water valve will be energized in the last half of the revolution.
Once you insert the jumper between T & H touch the bottom of the ice maker and check for any signs of heat within the first minute. No heat = bad mold heater. It can 3 - 4 minutes for the sweep arm to harvest the ice.
Stick your finger back in the ice maker fill tube area in the plastic rectangular funnel area and check for ice build up. If the funnel is blocked with ice also pinch the ice maker fill tube for an ice block.
Should you notice ice in the funnel and the fill tube most likely the inlet water valve is bypassing water into the ice maker causing an over fill and ice build up condition. The remedy here is to replace the inlet water valve. They are NOT repairable. (Most of the time if the inlet water valve is bad your ice cubes will be fused into an ice block in the ice bin.) Also... if the ice maker fill tube is frozen full of ice... it can take up to 30 minutes using a hair drier to melt the ice as the insulation in the back of the freezer compartment keeps the ice maker fill tube from warming up enough to melt the ice in a timely fashion.
If you discover that the ice maker has over filled you can use a hand held hair drier and melt the ice in the ice maker.
If the ice maker seems to work fine then the freezer may be above 18 deg F. This is usually caused by ice build up on the evaporator coils as a result of either a defrost circuit problem or a slow running evaporator fan.
Thanks for choosing FixYa,
Kelly
Feb 20, 2011 | Maytag MBF2258HE Bottom Freezer...
I have a problem with a GE Profile PSS26PSSASS. The ice maker barely makes any ice. The ice that is made, is melting, dripping, creating icicles in the freezer, and then re-freezing in the ice bin as a...
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker
Refrigerator Parts
Feb 17, 2011 | GE PSSS3RGZSS Side by Side Refrigerator
The ice maker makes ice and fills the ice bin but every few days the ice melts and creates a frozen ice scicle path to the lower tray and all the ice has melted and frozen again below the ice maker.
The problem with the ice melting points toward a cooling problem in the freezer. This could be caused by several different problems. Dirty condenser coils below the refrigerator could be contributing to this problem. I recommend checking and cleaning these coils if necessary.
Check the door seal on your freezer. A leak through the freezer door seal may be allowing warm air to enter the freezer and melt the ice.
Make sure that your temperature control is set properly.
If these tips do not help resolve the problem, it is likely that you have a component failure or a sealed system problem. The thermostat could be bad. You could have a condenser or evaporator fan problem. You could also have a defrost system failure that is causing your cooling problem. A weak compressor would also cause this symptom.
Jan 17, 2011 | GE Profile 23.3 Cu. Ft. Counter-Depth...
Subzero freezer with ice maker. Ice melts and refreezes, into blocks of ice. What could be causing this?
Good day,
In most cases it is the water valve that feeds water to the ice maker well. The valve is energized by the ice maker to fill for 7 seconds and then shut off promptly.
The valve will many times dribble water into the well after shut off, causing an overflow problem.
The fix is a new water valve kit.
The only other possibility is the freezer temperature going above freezing from time to time, but is a rare problem.
Mar 27, 2010 | Sub-Zero Bottom Freezer Refrigerator
The ice melts from the ice maker forming icicles down below.
Just had this same issue repaired yesterday, the defrost element was out allowing the freezer to freeze up stopping the fan which moves the air and in turn causing the upper part of the frezzer to become warm and melt the ice. This is a common problem for the GE profile and I recommend finding a service company cheaper than GE and quit letting GE make more money off their CRAPPY appliances.
Oct 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
Unit doesn't work when icemaker is on- Kitchen Aid Superba
that is unusual for the ice maker to cause it not to cool, but definitely not unheard of. if the fill tube to the ice maker, or ice maker itself, is leaking down the back of the freezer, behind the evaporator cover, it would form ice around the evaporator fan motor. this would cause the fan not to run, and the temp in the freezer and frige would rise. the ice would melt when it went into defrost, but then build up again. you should remove the rear panel in freezer and see if you see any ice build up around the fan blade, and if so, find where it is coming from. I hope this is the case for you. much cheaper than a compressor or new frige if it is. let me know if you have further questions. good luck, shane.
Sep 10, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice-maker thawing-refreezing into block of ice
Your defrost system may be out on this unit.
Aug 13, 2009 | Refrigerators
My GE Profile makes ice but then the ice cubes melt!
repl main board and make sure your out let is properly wired and grounded those main boards are sensitive when not grounded
Oct 29, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
66 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
