Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
The carpet and floor vacuuming function is really weak. It pushes the dirt around more than it picks-up. The hose attachment has lots of vacuuming power. Scott Macaulay
  • Dyson Master
  • 43,501 Answers
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
heatman101
Posted on Aug 29, 2010
Why is it not picking up dust and dirt from carpet. pipes clear. Can you help
How to Fix a Vacuum That Lost Suction - Quick and Dirty Tips
www.quickanddirtytips.com/.../how-to-fix-a-vacuum-that-lost-suction
Oct 3, 2013 - It's true, a vacuum that doesn't have suction is not very useful ... The first and most basic reason a vacuum isn't picking things up off the floor is if the ...The lower your carpet, the closer the dial or lever should be to the bare floor setting. ....it off and shaking the dust off put the power right back in my vacuum!
Common Vacuum Issues - and what you can do to solve them
blog.mchardyvac.com/.../common-vacuum-complaints-what-you-can-do...
Oct 4, 2013 - Your vacuum's job is to pick up dirt, dust and debris - so when it stopsdoing ... Often when your machine is not picking up it is due to loss of suction. If yourvacuum cleaner turns on but won't pick up on carpet or bare floors, ...
Is your vacuum cleaner not picking up dirt and debris ...
https://www.mrright.in/.../is-your-vacuum-cleaner-not-picking-up-dirt-a...
Jan 7, 2015 - But many times it does not pick up or suck the dust as effectively as it is supposed to do. ... If the vacuum cleaner fails to pick up dirt and debris and has no ... Deep clean your expensive carpets to restore their original look.
Jan 24, 2016 | Vacuums
My dc07i has power to hose but isn't picking up when hovering carpets or hard floors the roller is going round but there is no suction
I would guess that the line is plugged between the pick-up where it goes to the dirt tank. Lots of time when something big gets sucked in, it still lets the dirt in the tank. However over time dirt collects around the wedged object and gradually over time plugs the passage way. It may take a little time to pick out the blockage. You may have to somewhat take it apart. to get at it. This happens to my shop vac a lot.
Dec 31, 2014 | Dyson DC07i Bagless Upright Vacuum
My dyson will not pick up but has suction when using hose only
I have had Dyson All Floors model,( the one with the clutch adjustment to allow transition from carpet to hard floor) for a number of years. Recently pick up from carpet particularly poor. Went through all the solutions as recommended on Dyson website. No blockages, no broken sole plate, bristles (should be around 7mm to 8mm long) protruding ok from soleplate ( these can wear slightly over time but not usually the problem), belt not broken nor slipping. Filters cleaned/ replaced, but still poor pickup. Checking for strength of suction, as recommended by Dyson, both at top of hose and at bottom right inlet revealed no problem there. It turned out the clear inlet hose coming from the soleplate to the underside of the machine was the problem from two viewpoints. Firstly, as can be expected, the clear hose can develop splits after a number of years due to wear and tear. The other, not so obvious, problem is that the hose is also a form of straight spring which is designed to be compressed to a certain degree to an S shape when the machine is in the upright position. Upon pulling the handle back, whilst pushing on the footrest at the bottom results in pressure from the hose/spring being applied to the rear of the sole plate, pushing it on to the carpet. Thereafter the suction takes over, keeping the soleplate firmly fixed to the carpet. The existing hose on my machine had settled in to an S shape over the several years I have had the machine, thereby not pushing firmly enough the rear of the soleplate on to the carpet ( I noticed a significant gap at the rear whilst using the machine). For the couple of splits I had effected a temporary repair using a couple of very narrow strips of Gaffa tape, whilst awaiting the new hose/spring, but only a marginal' if any, improvement. Upon receiving and attaching the new hose/spring the solepate was properly pressed onto the surface of the carpet and pickup was like new.
May 09, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuum not picking up dirt
The neck in your power head is likely clogged. Disconnect from the wand and look inside. Also check the wand.Since you have suction on the bare floor the hose is likely not blocked.
Sep 11, 2009 | Kenmore 22512 Bagged Canister Vacuum
Hoover Tempo Widepath Blows Dirt Out Back on Hard Surfaces
lots of times switching to hard surface floors you need to slow down because the air flow that does the actual picking up of the dirt can't work as fast as the spinning brush so the brush is throwing the dirt out the back before the suction can pick it up. Try slowing down
Jun 11, 2009 | Hoover Tempo Widepath Upright Vacuum -...
Dirt devile featherlite vacuum pushes extremely hard on high pile carpeting
the dirt devil featherlight has a automatic height adjustment for carpet and bare floors.check the wheels and see if there is something wrapped up around the wheels
Apr 28, 2009 | Vacuums
The brush does not spin when making contact with carpeting
I tried the electrical-tape-around-the-wooden-spindle technique. After a minute or so, it's back to functioning normally.
Mar 14, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
No suction
I'm not sure what model you have, but the most common problems I've seen with these are that the hose gets clogged. Usually the hose is removable. If you can get it off, you may be able to push the clog out with slender rod or yardstick. If you are fortunate enough to have another vacuum with a hose, you can also **** or blow the clog out of the dirt devil hose with the other vacuum. Good Luck!!
Jan 02, 2009 | Dirt Devil Vacuums
Not sucking up dirt in upright position
if there is dust flyin around the vacuum u might try lookin for clogs on the bottom where the beater brush pushes the dirt in and maybe where the dirt goes into bag ive used wire clothes hangers to free em up works..hope this helps
Dec 06, 2008 | Dirt Devil Vacuums
No suction when carpet cleaning. Also won't stand upright
Its possible that it may be blocked in the foot of the vaccum. try going through your instruction manual to locate details on how to disassemble the suction brush and connecting ducts. If you dont have one then use this link to download it. http://ubermanuals.com/node/1870
Let me know how you got on
Cheers
Jun 10, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
79 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
