Question about Bosch Dishwashers
We bought a Bosch SMS63M08AU dishwasher and are currently installing the product. We have connected everything, however the unit comes up with an error "E17" after a few minutes of running the unit. Can you advise what an E17 is and how the error can be rectified. Regards Kevin Brown
2 Suggested Answers
SOURCE: Display has error code h01
h:01 means 1 hour delay. Press the delay button repeatedly to get to h:00 then hit start.
Posted on Sep 19, 2011
Display has error code h01 and dishwasher won't run model is SMS63M08AU
Mar 06, 2011 | Bosch Dishwashers
My bosch dishwasher has a terrible from day one. I have tried running vinegar through a wash cycle. My dealer I need to run it a few times. I have had this machine for well over a year and still gives...
Hello and welcome to Fixya.
It "smells" ( just kidding ) like you might have a problem with the way your drain hose is connected by your description.
It is crucial that your Bosch dishwasher have a siphon break or "hi-loop" installed in the drainage between the dishwasher and where it enter's your homes plumbing.
If it does not you can try different cleaners until the cows come home with little effect because the odor is coming from the drain line itself.
Was this unit installed by yourself or someone you know ? Or was it installed by a plumber/professional installer.
In the end it actually makes little difference, I'm just curious. I see professional installers as well as plumbers fail to include this crucial feature over and over.
Let me know. I'll watch for your post. If you are unclear as to what I'm referring to, check your installation guide that comes with all Bosch dishwasher's.
If you do not have any instructions regarding the proper drain/install I can email you a copy, but I would need your email address.
Good luck.
macmarkus :)
Jun 17, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
I have a bosch sgs53c12 dishwasher and the water light keeps comming on after about 20 seconds into a programme. I have switched it off and on, reset it and checked the inlet hose where it connects to the...
Hello- Bosch installed an anti-flood device in bottom of unit. If water gets into this area ( from a leak, usually). To get water out, tip backwards, then forward. Use a couple of towels- water should come out. Common problem with these units. Let me know if this info helps- have more if needed.- Thanks- Ed
Mar 12, 2010 | Bosch 24 in. SGS43C12 Classixx...
Bosch Dishwasher (SHE44C05UC) won't turn on
Just had the same problem, same model. Found the wiring below the front cover fried. So now I'm checking to see if anyone else had this happen.
Jan 13, 2010 | Bosch 24 in. SHE44C05UC Stainless Steel...
SHU5315UC control panel
I've heard this song before.You are on the right track.the solder joint that burns out feeds the heater relay which draws the most current.make sure you got a good connection at main feed.use ceramic wire nuts.possible bad heater but have only changed 1 out of hundreds of bsh repairs.lousy boards !!!
Jun 24, 2009 | Bosch SHU5315UC Dishwasher
I bought this dishwasher 5 years ago and was kept in the box until last month. I installed it, turned on the water and no water is being pumped into the unit from the water release valve in the dishwasher....
You will have to check all the connections visually. Since you know how to use a meter, see where the current stops. See if there is current coming from the control board to the pump. the water inlet solenoid valve should "free flow" water into the machine. the pump recirculates the water for the wash and rinse cycles and pumps the water out of the machine to the drain. It is more likely that that water inlet solenoid valve is where the problem is.
Mar 17, 2009 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher won't drain -it's only 3 months old
Yes they do have a drainage problem! I worked for a Sear install team. You need to have the installer come back out, if they did the install correctly and you still have problems then sears needs to send a service tech out. If they can't fix it or tell you it is a install error then be persistent and tell them you want a BOSH TECH out. You more than likely need a stronger pump as Bosh DW work off a gravity type pump system. Keep in mind Sears installers guarantee there install for 1 year and all products come with a 1yr MF warranty. If you purchased a warranty or PA agreement the you will be entitled to a new unit if that one is not fixable. If you have a garbage disposer, they work best when routed into one.
Jan 17, 2009 | Bosch Evolution 300 SHE43M05UC Stainless...
Bosch 3000 dishwasher
Don't. Just attach your hose and the end of the Bosch hose together. Just wind up the Bosch hose and tape it to the back of the machine.
Jan 15, 2008 | Bosch 24 in. SHU66C05 Stainless Steel...
Dishwashers Logo
106 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
