Question about Husqvarna Designer I
Is there a paper manual for the designer I sewing/embroidery machine? Can I download it somewhere?... I forgot everything I learned 6 years ago when I bought it! I have the VHS tape, but would like it on paper so I can have it by my machine. Thank you!!
  • 201 Answers
Not that I am aware of, sorry. At least not one available to the general public. Maybe your nearest Husqvarna dealer might let you photocopy the pages you need the most or they should have access to the manual in .pdf format which they could print out for you for a fee, no doubt. Or try eBay and Craig's list - you never know - someone might have a machine that no longer works and is willing to sell or give away the manual.
Posted on Sep 26, 2010
How do i remove the embroidery unit from the topaz 40
Do you mean the Husqvarna Designer Topaz 40? If so, first make sure that the unit is in Park. You need the sewing machine on to do this. Select the Park Position on the Embroidery Stitch-Out menu. This screen is accessed after you choose a design and press Go (at the bottom of the touch screen on the left). Then press the release button on the bottom of the left hand side of the embroidery unit.
The directions to remove the embroidery unit are in the manual on page 6:3 (page 69 of the PDF). The manual is available from the product page: http://www.husqvarnaviking.com/en-US/Machines/DESIGNER-TOPAZ-40 . Scroll down and look on the left side of the page. The direct link to the manual is http://www.husqvarnaviking.com/SiteMedia/Products/Machines/DESIGNER-TOPAZ-40/Manual/Topaz40-manual-EN.pdf .
I hope this helps.
Dec 31, 2016 | Sewing Machines
Sewing machine sews only when the light is on
sounds like there is a short somewhere in the machine and needs to be checked
Jul 16, 2014 | Brother PE770 Embroidery-only Machine with...
Where to buy another creative blank pfaff 7570 card
try contacting pfaff customer & ask them if a pfaff dealer would carry them
also try
sewingpartsonline.com
May 02, 2012 | PfaFF Creative 7570
Where can I locate the fuse<
The Pfaff 7570 Creative Designer is a computerized sewingand embroidery machine that has the ability to connect to the computer, andhave embroidery designs sent to the embroidery machine. The sewing andembroidery machine has many features, including hundreds of general sewingfunctions, a separate embroidery module, and on-screen editing features. TheCreative Designer 7570, manufactured in the 1990s, was the first sewing andembroidery combination machine ever made by Pfaff.
1. Usingthe Sewing Machine
1 Turn on your sewing machine using the "On"button located just below the turn wheel on the right side of the machine.Thread your Pfaff 7570. Note that Pfaff sewing machines thread from left toright, not right to left like other sewing machines. The upper tension discsshould be raised at their highest position while threading, and the presserfoot should be raised up until you thread the needle. Drop the presser footright before you thread the needle. The prevents thread problems during use. 2 Insert a full bobbin and retrieve the bobbin threadthrough the thread plate. Raise your sewing foot and needle to its highestposition; hold the needle thread taught with your left hand, lower the needleinto the thread plate using your right hand, and then raise the needle. As youraise the needle, the needle thread will catch the bobbin thread, and pull itup. There should be a loop of thread intertwined with the needle thread. Usetweezers, your finger, or a straight pin to retrieve the bobbin thread that isvisible through the thread plate, and pull it through the plate. 3 Place the fabric under the presser foot, and drop thepresser foot. Choose the stitch you want to use from the top stitch display,right above the top thread feed. Press the '0-9" button located on thesewing machine's front panel, and a display screen will come up. Input thethread number, and press the 'OK' button located on the sewing machine's frontpanel. The stitch will display, and you are ready to sew. Repeat Step 3 foreach stitch you want to use.
2. SettingUp the Embroidery Unit
1 Turn the sewing machine off. Take out the embroiderymachine unit, locate the connection bushing on the back of your embroideryunit, and match it up with the connection bushing on your sewing machine. Theconnection bushing should be located next to a yellow sticker on yourembroidery unit, and somewhat resembles a serial port on a computer. Slide theembroidery unit onto the sewing machine with the sewing machine turned off. Connectto the bushing carefully as you slide the embroidery unit onto the sewingmachine. Use your embroidery unit manual if you need assistance. 2 Insert an embroidery card. Your embroidery unitshould contain an embroidery card labeled embroidery card 1. Use that or useanother Pfaff 7570 card that you own. Turn on the sewing machine. 3 Open the bobbin case area just below the threadplate, and lower the feed dogs by pushing the feed dog switch to the right.Press the card button located on the front face of your sewing machine. Adisplay with pop up; choose embroidery designs or monogram and a new screenwill pop up with your design choices. Choose the design you want, and press"OK." A checklist screen appears. Do everything on the checklist, andpress "OK." Use your embroidery unit manual if you need help. 4 Start embroidery by pressing the foot pedal. At thistime, your hoop should already be attached to the embroidery unit becauseyou've already gone through the checklist. Your embroidery manual displayscolored picture diagrams that are very helpful in understanding everything inyour checklist menu.
Thanks for using fixya
Jul 31, 2011 | PfaFF Creative 7570
I need the cd that teaches you how to use the brother pe150v embroidery machine do u know where to buy please? Thank you.
You will have to contact a Brother dealer to see if they can get a DVD for you.
The operation of this model is very straight forward, if you need a manual, you can download a free one here - http://www.brother-usa.com/manuals/default.aspx?PGID=3&R3ModelID=PE150V
You can also find free tips and tutorials at http://www.embrloderylibrary.com
The easiest way to learn how to use this machine is to gather your supplies: embroidery thread (choose a few basic colors), machine embroidery bobbin thread (important to use this and not the top thread), medium weight cut away stabilizer and scraps of fabric.
Open the manual right next to the embroidery machine.
Read and follow each step.
Hoop the fabric and stabilizer and then stitch out a few of the built-in designs. The select a frame and stitch that around the design. Bump up the position of what you have stitched out and select a few letters to put under it.
It may not be perfect the first time, but if you keep playing you will soon be very proficient.
If you need more assistance as you learn, visit on-line embroidery forums such as Ann The Gran or SewForum.
Relax and enjoy a great craft.
Mar 02, 2010 | Brother PE-150V Computerized Sewing...
Pfaff creative half-speed and thread breaks
YIKES - what a nightmare! We can approach your problem two ways, but to determine whether the problem is your machine or your design, I need to know if you have been using one design, or if you've tried to embroidery several different designs and are getting threadbreaks about every 10,000 stitches, no matter what design, needle, thread, and bobbin you use.
Here are some rules you should following whenever you embroider on your machine:
  • Change your needle and insert a newly wound bobbin every time you start a new project
  • Use a size Embroidery Needle - size 90 for most projects
  • Check the backside of your design - you should see alot more bobbin thread than embroidery thread. If you don't see enough bobbin thread, loosen your top tension. If the tension is set automatically, change it manually.
  • Your design might be the problem. Some designs have WAY to many stitches. If you haven't already, choose several different designs with different styles - for example, a monogram, a design that is mostly satin stitches, a design that is mostly straight stitches, and so on. Sew one or all over and over so you determine whether your thread will continue to break about every 10,000 stitches.
I hope this helps. Machine embroidery is so much fun once you've learned and practiced. I hope to hear from you - machine embroidery is not hard to learn, but there is a lot to learn. Thanks.
If you want to get right to work, skip the troubleshooting and answer as many questions as you can or have time for. It is possible that your problem is the design and not the machine. Try one suggestion at time so you what helps and what doesn't. Questions first:
  1. Is the machine brand new, or new to you?
  2. Do you have your manual?
  3. Do you been embroidering by machine for a while, or are you just learning?
  4. Does this problem occur with every design you sew, or is it one particular design that you are having trouble with?
  5. How many total stitches are in the design you are trying ot sew?
  6. What kind of thread are you using (rayon, poly, sewing?)
  7. Did you buy the machine from a dealer, and if so, does it have a warranty?
  8. Have you taken lessons on how to use your machine for both sewing and embroidery?
  9. Are you familiar with embroidery backings, needles, and threads and how to choose which to use for a particular project?
Feb 01, 2009 | PfaFF Creative 7570
Pfaff 7570 program
I have somewhere that installation diskette (with the old SW version). If I'm not mistaken it was not included with the sewing machine but sold separately with the embrodery arm that we bought together with it some 10 years ago. Email me to azach@kci-medical.com if you need more help.
Jan 08, 2009 | PfaFF Creative 7570
Learning to operate my new singer futura ce - 150 sewing machine & embroidery unit and can't get to work
UR INSTALLATION SHOULD HAVE A USER MANUL ON IT FOR INSTRUCTION. IF NOT VISIT THERE WEB SITE TO SEE IF U CAN DOWNLOAD IT OR GET ADDITIONAL SUPPORT
Aug 11, 2008 | Singer CE-100 Futura Computerized Sewing...
Sewing Machines Logo
48 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
