Question about Kenmore Refrigerators
The pan underneath keeps filling up with water and over flowing. I can't find a leak anywhere
  • 593 Answers
Your looking for a water leak and what you have is a air leak. One of the doors are not sealing right. Check the door gaskets for a good seal, clean the edge of any dust. Also pull the fridge out from the wall good remove the rear cover and vacuum out the coil on the bottom. Having a good clean coil helps to evaporate the watter in the pan. If not enough air flow over the coil the pan may stay full longer. Humid air gets pulled into the fridge thru the door seals and during defrost drips into the pan, where the heat from the bottom coil helps to evaporate that water. Other causes are too many door openings, keep that freezer door closed as much as possable in the heat of the day.
Posted on Aug 29, 2010
Its leaking water from underneath I have cleaned out the condenser but still happening can you help
underneath the door? the drain pan? unless ur pan is over flowing it may be due to condensation due to either bad door seals or a clogged drain plug
Mar 15, 2015 | Refrigerators
Why does kenmore side by side model 596.50004100 leak water from bottom?
1. there is a condensation pan under refrigerators, pull front bottom grill off & you should see pan. if pan is full it will overflow, pull forward to remove & empty. also check to see if something spilled in bottom of fridge & is running into drain hole into pan. most of the time condensation is so slow that it will evaporate before the pan fills up, but I've had them fill up on me in the past, not too often though.
2. if fridge is equipped with ice maker & clod water dispenser, connections on bottom back side could be leaking ( not likely, unless they have been disturbed).
there is not much else that it could be unless it is not the fridge & is coming from some where else & running under the fridge.
Oct 09, 2014 | Refrigerators
When i turned off water supply it stopped leaking
there should be a shut off switch that might be broken or blocked in the open position when the water gets to the correct level this switch should stop the water flow. if it is broken or jammed the water will keep flowing. I hope this was useful.
May 28, 2014 | Whirlpool Gold White-on-White 21.9 cu. ft....
I have a Whirlpool refrigerator. Model # ET1CHMXKBO3 and it leaks water into the bottom of the refrigerator. Water also freezes on the bottom of the freezer compartment. I checked for a clogged hole o
When your refrigerator defrost the water runs into a drain pan in the bottom/underneath the refrigerator, You will need to first unplug and remove contents from freezer and proceed to remove the air tower in the center of the back panel, underneath the evap. coil in the center is a hole that leads to the drain and it is iced over and the water is not able to flow.What i do is get a hair dryer (be careful not to melt the plastic) and defrost/melt the ice. You will need a towel to start and once you think you have the ice removed get some hot water and pour in the trough to make sure it flow's to the drain pan. When the flow is good put the part's back and make sure the refrigerator is level from side to side and slightly tilted towards the back (front to rear)!
Dec 24, 2013 | Whirlpool Refrigerators
My evap pan keeps overflowing
The pan in the inside of the unit or the one underneath for collecting and evaporating the water?
If it's the one inside take the front bottom panel off and blow out the drain line leading down there. If its the pan underneath and it cant keep up with the water flow check to be sure it has some white cotton looking panels in the pan. They are an accessory called a wicking kit designed to absorb the water and as the air blows over them they help evaporate the water. If those are present and in good shape but its overflowing there you may need to get an electric condensate pan.
Aug 28, 2013 | True GDM-33-SSL-54 Refrigerator
Water collecting in the pan underneath the fridge.
it should do this but the water should evaporate from the heat from the condenser and compressor,when the machine goes into defrost a heater comes on and melts all the frost off of the coil,the water drains down into the pan where the water will evaporate,when was the last time you cleaned out the condenser coil?remove the front bottom kick panel and check the coil,if it's filled with dust it has to be cleaned out at least once a year especially if you have a cat or dog,then pull out the machine unplug it or shut off the control and remove the bottom back panel,the easiest way to do this is to vac up as much dust as you can with a shop vac,then set it for blow by putting the hose on the other end of the shop vac and blow the dust out of the coil,you can buy a condenser brush that will remove dust thats stuck inside the coil but the shop vac works great,through the condenser this is how the heat escapes out of the machine,also clean off the fan motor in the rear,also there are plastic water lines that come out of the water valve that could be cracked going to the ice maker and water dispenser or the valve itself could be cracked causing this problem or the pan could have a crack in it,very unusual for the pan to overflow,when you're done cleaning it plug it back in,make sure the fan is running fine and have someone fill a cup of water and check the plastic lines coming from the valve to see if it leaks,pull out the pan and check it for cracks,fill it up at the sink and check it,if everything looks good you can shut off the water valve that goes to the fridge for a few days and keep an eye on the pan,like i say it's unusual for the pan to overflow just from the defrost water,if the water is evaporating with the water shut off then you have a crack in one of the water lines going to the ice maker or dispenser
Aug 05, 2012 | Amana ASD2522WRS (251 cu ft) Side by Side...
We have a hotpoint RLA 34 ( MICROBAN ) FRIDGE . water keeps seeping into the bottom , under the crisper box tried turnining temp down , made sure it's level , no blocked drainage hole . door shuts tight...
You said no blocked drainage hole, where was the drainage hole that you checked located? Did you pour water down this drain, and furthermore did you check that the water you poured into the drain flowed into the condensate pan on the outside of the fridge? Unless you have a problem with an ice maker leaking water, it sounds very much like you do have a blocked drainage hole, otherwise known as a defrost drain. the drain system begins underneath the evaporator coil inside the freezer, this is where the water that is collected in the defrost cycle flows into a drain tube that leads the water down to the condensate pan. The best and safest way to clear out this drain is to blow it out with compressed air, after you remove any and all ice at the beginning of the drainage system, in other words, the hole located underneath the evaporator coil.
Nov 09, 2010 | Hotpoint RLA31 Compact Refrigerator
Whirlpool refrigerator leaking from top of unit
Listened to other posts and figured drain plug was clogged. It was with ice. Removed bottom pan and back panel of freezer, removed ice on bottom, put hot water in drain to thaw ice until it flowed into pan underneath fridge. Thanks for the ideas.
Jun 02, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Eco button keeps flashing, cycle not starting
If its a dishlex global then flood switch is activated.soak water up from flood pan middle front underneath.then it will restart.but you will probably find its leaking or over filling.hope this helps.
Mar 07, 2008 | Dishwashers
Asko 1605 cycle stopped, pump keeps running, water pumps out but will not progress to the rinse and wash cycles. Timmer will turn and detergen dispenser will open. Pump keeps running
Thanks my Asko did the same and tilted it forward, drained excess on the floor, even though I thought i'd bailed the whole lot and woolaa fixed - thanks x
Oct 18, 2007 | Dishwashers
Refrigerators Logo
108 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
