Power usage the convector heater i bought is powered at 2400watts. there are 3 power settings. i usually use power 2. does this mean the heater is still going to run at 2400 watts which means i'm using more energy comapred to if i had bought a 2000 watts one?
  • 1,512 Answers
Hi YiXin
It will only use 2400 watts when on full. On settings lower than full, you will reduce the heat generated, and thus use less power. The amount of watts(energy) used is directly proportional to the heat the unit puts out. Hope this helps. A FixYa rating would be great for my solution. Thanks for using FixYa. Stay cosy :)
regards
robotek
Posted on May 08, 2008
How do i wire a baseboard heater
therte is no neutral wire when wiring 240v ( 2 black 1 ground usually)
Sep 20, 2014 | Fahrenheat Electric Convector Baseboard...
Dimplex Convector Heater EPX1000 turns off by itself
I have the same problem with 3 of the 5 EPX1000s I have fitted in my flat, although mine don't even warm up. They just immediately turn themselves off. My only conclusion is that they are rubbish. Specifically, the so-called overheat protection doesn't work. Avoid.
Jan 16, 2010 | Dimplex Heating & Cooling
How old is my Rinnai Convector 516 TR?
2000 is the year of manufacture
Nov 09, 2009 | Heating & Cooling
Rinnai tankless water heater code 12
12 - Flame Failure or Poor Ground
1. Immediate code 12 is usually a defective gas valve, power supply problem, or defective fan motor wiring harness.
2. If code 12 occurs after a few seconds it indicates that proper operation was established, but then stopped unexpectedly.
3. Verify that fuel is being supplied to the unit.
4. Check for proper electrical ground. Unit must use a grounded power supply.
5. Check for flue blockage on inlet or exhaust.
http://www.foreverhotwater.com/service-codes.php
Dec 31, 2008 | Rinnai Webstone The isolator EXP tankless...
220 POWER TO BASEBOARD HEATER
copy and paste this link into your browser and it will help you. http://www.qmarkmeh.com/Develop/prod_pdf/2500wiring.pdf
Dec 03, 2008 | Fahrenheat Electric Convector Baseboard...
Fixing lg whasher
??? not enough information, what do you mean by this? the clothes are still wet when they come out the machine does not spin at all?
the machines have a set time to drain before they spin usually three minutes if the water has not dropped below a level before the set time the machine will stop, check the drain
Clothes begin to get wetter than before? how old is the machine motor brushes usually last 2-3 years depending on usage when they wear down the parts of the program that put the most power through the brushes can fail first (Spin)
Nov 21, 2008 | LG WM-2277HW Front Load Washer
Can't find replacement parts
Hi google intertherm furnace parts they sell parts on line you may find what you need on there
Oct 22, 2008 | Fahrenheat Electric Convector Baseboard...
Wire connecting
You dont need the white wire. you only needed 10/2
Oct 06, 2008 | Fahrenheat Electric Convector Baseboard...
Installing tandem baseboard heaters
Yes, you should use only one thermostat per power source.
Nov 13, 2007 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
83 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
