Re: kenwood kc-206 preamp - when there is any vibration (loud base etc.) there is a loud electrical/feedback type sound. after closely checking for the source of the problem it appears as though it is coming from the jacks that connect the preamp to my kenwood basic m2 amp. as stated above this happens when there is vibration and also when the wires are disturbed at the preamp jacks. i took the cover off and saw nothing wrong at the jacks. any ideas as to whats wrong and how to fix it?
    Genius:
  • 1,175 Answers
Hi....
Audio connectors should be resoldered
Posted on Sep 01, 2010
Pertaining to my Kenwood stereo control amplifier kc-206
Turner password was activated by remote.
Try downloading using the model number the deactivating password.
Oct 23, 2016 | Audio Players & Recorders
I have a Kenwood KC 105 preamp and the volume is stuck on high. I turn the volume knob but it does nothing. Any suggestions?
Looks like you are going to have to replace the potentiometer, AKA volume control. It must be shorted out inside (probably) or knob came off the shaft. (doubtful)
Feb 02, 2015 | Kenwood Sc-75 Av Surround Processor...
I just got a Kenwood system, i would like to know how to hook it up, it has, Kenwood power amplifier km207, kenwood stereo control amplifier kc 207, disc player dp-m 97, cassette deck ky-77 cw, stereo...
That's a pretty standard setup. RCA cables from the KM207 to the preamp (KC207), and RCA cables from all of the other components into the KC207. Speakers connect into the KM207
Nov 01, 2012 | Master DE Kenwood with Housing...
Action is a bit high. Everyone is saying the DC16RGTE guitar sounds great and gives good volume. I found the one I have is not loud and it has too much boom. Is there a problem with this guitar?
Make sure the guitar CANNOT "HEAR" the amp you are using. Local regeneration (feedback below the level to sustain full feedback) will give a boom sound like in a cave. If you get near enough to the amp for feedback to build up, you can actually see the string vibrating and building up. The loudness has much to do with the amp you connect this too and the settings
Aug 30, 2011 | CF Martin DC16RGTE Aura Drednought Cutaway...
While playing, my Roland KC-550 will make a loud pop and the sound will stop for a moment. It then starts right back playing. Sounds almost like a short???
Sounds like some solder / component connections have failed
Have a tech check solder joints on the power supply and output amp
I see this on a reg basis
Jun 29, 2010 | Roland MMP-2 2-Channel Amplifier
Poor sound/ Unable to play anything load without distortion.
i can tell you right now base on the vehicle you have a bad system hook wosrt if you are using factory head unit
Mar 25, 2009 | Kenwood KAC-8151D Car Audio Amplifier
Kenwood stereo control amplifier KC-206 doesn't work
I was able to use an universal remote control that I have, a Radio Shack Kameleon 6 in one remote control which I was able to program to run the audio portion of the Kenwood KC 206 control preamp. By adjust the remote sensor volume to max, I was able to get maximum volume out of the unit and drive the power section very nicely. Now I have to get up and manually turn the manual volume control for addition volume adjustment.
Hopefully Ken can find a remote that he can control the Kenwood control preamp the same way I did. Good luck here.
Dec 02, 2008 | Audio Players & Recorders
I found this thread when I was having the same problem with mine. Turns out that it's sort of a problem, but not really. Looking at the manual (which I found in another google search) I believe a "4" on the volume level corresponds to a default remote control setting. The remote varies the level between 0 and 10, but the "10" corresponds to the maximum volume setting on the preamp. So it actually works, it's just that the "4" reading doesn't change. There's probably a pin you can short somewhere to make that default to "10" which would be ideal. But I'm not sure where that is. Now on to my other problem. This particular preamp has a subtle 120 Hz hum...
Nov 15, 2008 | JVC RX-E100 5-Channel Amplifier
Kenwood control amp KC-206
Sounds like a low voltage to the front panel as the indicators are there such as control window illumination is dim and the remote does not function.
The remote sends an invisible signal to a detector just behind the front panel and if the signal from the remote is nice and strong from your new batteries in the remote then it must be the panel electronics.
I have found that if you clean the output panel of the remote with a damp cloth and the same to the front panel glass you may be lucky. Just Damp please not dripping in water!!!!!
If ypu keep the amplifier system very clean then this wont be the problem...But this action has worked on TV's with remotes...
If this doesnt work then a service is due....sorry....no quick fix..
Cheers YOU BEUT
Oct 26, 2007 | Audio Players & Recorders
216 people viewed this question
 Grubhead
Grubhead
